Perfect Bass and Trebble & Midrange for the JBL Stereo?
Discussion in 'Gen 2 Prius Main Forum' started by macreative, Oct 7, 2004.
  1. macreative
    macreative New Member
    151
    Los Angeles, California
    What settings do you all use?
    I have found that the JBL stereo needs some fine tuning. Do you have preset Bass, Treble, and Midrange adjusted to a specific setting?
    I haven't quite tuned mine in yet.
    Thanks for any input.
  2. Kev1000000
    Kev1000000 New Member
    271
    Livonia, MI
    I have mine in a V shaped
  3. Ryomatic
    Ryomatic New Member
    35
    Scotts Valley, CA
    Re: Perfect Bass and Trebble & Midrange for the JBL Ster
    The JBL system is the one place where the Prius has some problems. The highs are very tinny to me, and the low end is not tight. It's kind of blatty. I used to have a VW Jetta and I got spoiled with the stock Bose sound system. :cry:
    I've been listening to alot of different music in my Prius and have settled with the following settings:
    Bass: 2-3 notches up. Any more and it starts to sound like a pillow.
    Mids: no change or down 1 notch
    Highs: Down 2-3 notches. Helps to get rid of the tinfoil highs.
    Fade: 1-2 notches toward the back just to give it some spacial effect.
    Hope that helps. It goes without saying that it is ultimately up to the individual listener's ear.
  4. Dion
    Dion New Member
    128
    Jersey City, NJ
    I use to own a Pontiac that let you set different equalizer settings for the tape, CD and for each radio station. And they would change automatically when you changed station. That was great and I miss it. That's the way all cars should work. More bass for hiphop, more treble for rock. The Prius just does not have that sweet spot for all types of music. I'm still in the process of adding a sub to the back.
  5. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(Dion\";p=\"43894)</div>
    My Buick Regal did the same thing. I really miss that. NPR was set to talk radio settings while rock stations were set appropriately. I agree with Ryomatic in that while there are many mechanical advances in the Prius with appropriate software control there are also many areas that seem to have been overlooked while the other stuff was being developed.
    One other feature that I would like to have would be the radio text for the stations I'm NOT listening to in addition to the one I am. Wouldn't it be great if while a song is ending on one station you can look to see what songs the other stations are playing and switch directly to the one you want?
  6. Ryomatic
    Ryomatic New Member
    35
    Scotts Valley, CA
    Maybe we need to push for Prius Console version 2.0! :p
  7. macreative
    151
    I haven't yet been capable of getting the settings just right. I have the treble up 3 notches. The midrange in the middle and the bass is in the middle.
    I listen to all sorts of music. The JBL system is realitively the same as the one that my Camry had, My camry also had the nav. But the sound quality seemed to be much improved in the camry. I wonder why there is a difference? Maybe because the speakers are in different locations.
    Question: How high does the volume go? To 50?
    To get any audible pleasure out of this system, I crank it to 30 - but I don't want it that high if it will damage the system. Any input?
  8. Kev1000000
    271
    Livonia, MI
    ^^ goes to 65 i think....
    and anything below 55 will not harm your system at all
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    60 is the max, I've had it up to 50+ at times. The numbers are "arbitrary" of course.
    I usually keep mine at ~30 unless the CD is a bit quiet.
    As for EQ, it's 2 up on bass, middle on mid, and 1 up on the treble.
  10. krooster1234
    krooster1234 New Member
    72
    Glenview, IL
    Before I added a sub, I would use +1 bass, middle for the mids, and +1 treble. Now that I added a sub, I can turn down the bass to -1 or -2. This is really good for the sound quality, because it clears up some of the muddled sound that the bass has if you turn it up (with the door woofers trying too hard to pump out the bass), and lets the sub do all the work on the low stuff.
    I wouldn't recommend installing a sub yourself unless you really know you're doing... the design of the sound system (at least the JBL one) SUCKS for any sort of modification. Although, I can't blame anyone other than myself for slipping while pulling on a wiring harness and slicing my finger open...
  11. Ryomatic
    Ryomatic New Member
    35
    Scotts Valley, CA
    krooster,
    what kind of sub did you add? where did you place the speaker, amp, etc? Is it working out for you?
  12. krooster1234
    72
    Glenview, IL
    I added an Infinity 10", with an Alpine amp (something-350 I think, it's a mono-channel). I wired speaker wires from the amp under the passenger seat, to the compartment under the hatch area where I put the mono-channel amp for the sub. To do this, you either need an amp that accepts speaker-level inputs, or you need this thingy (forget what it's called) that converts speaker-level signals to preamp-level signals. Then I put the sub in the hatch area. It's a pretty big sub enclosure, so it does cut down on storage space, but it's easy to just unplug the sub and put it somewhere else (or even move it to the back seats if necessary). Plus, the amp is out of sight and doesn't take up much space.
    There have been many threads in the audio/electronics forum about adding a sub, and all the information is there (including electronic schematics for the JBL system), but you have to poke around for awhile to find all the pertinent information. Also, I can't stress enough how much of a pain in the nice person it was to install everything, and I wouldn't have known how to run the speaker wires from the JBL amp to the hatch area if I hadn't previously installed the XM radio kit. But then again, I have never installed a sub in a car before, so I'm sure if you've done it before it's a lot easier than I'm making it sound.
    The sub definitely helps the sound quality of the sound system, although depending on how much music you listen to it's arguably worth the money.
  13. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    The system goes up to 62.. then it says Max after that.. So.. techincaly it's 63.. and it sounds as if it's just hitting the peak of RMS sound at 62. The speakers handle it well though. I'm a music nut.. and classical sounds awesome at 45.. my bass and treble are up. If i want more bass, i but the fade back a notch or two. Treble is 1 notch higher (sometimes 2) than the bass. Treble is almost maxed.
