Another Frt Window Tint Question
Discussion in 'Gen 2 Prius Technical Discussion' started by John6012, May 23, 2007.
  1. John6012
    John6012 Member
    134
    2018 Prius Prime
    I'm getting tint in my Prius this week and I really like the top of the front windshield tinted, but I have the GPS and don't want intermitent signals or any interference at all. I wonder if the tint shop can cut around the area where the antenna is like kind of a "U" and still retain all GPS capabilities?
  2. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    I have a 5% strip across my windshield. They just tinted over the antenna. it dosent interfear with it at all. I've had no problems and its been on for over a week now. I use my GPS every day. Unless your getting a tint with metal ie. silver mirror, I think you'll be ok.
  3. fd143
    fd143 Junior Member
    south fl.
    No problems with the navigation after tinting the windshield.
  4. John6012
    John6012 Member
    134
    2018 Prius Prime
    <div class='quotetop'>QUOTE(fd143 @ May 24 2007, 07:55 PM) [snapback]449475[/snapback]</div>
    They tinted the window yesterday. I asked the screwball to cut around the area where the GPS gets the signal and of course, they didn't but the GPS works just as well with or without the tint. I feel good and I believe the car does too from the milage it renders.
  5. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I think the GPS antenna is actually in the dash and just "looks" out the window. It can also get signal from the side windows, though it would be weaker from there. The GPS antennas are tiny, about 1" square. I don't know which one the Toyota system uses, but they often also have an amplifier built in, to compensate for the loss in the tiny cable they use.
