Dangerous voltage???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by capc, Oct 9, 2004.
  1. capc
    capc New Member
    Portugal
    I was wondering if a 500V circuit and a 200V battery were dangerous in case of accident, when driving a Prius? A friend of mine said it could blow up!!! :roll:
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(capc\";p=\"44229)</div>
    It's not a bomb, it's a battery. If a spark jumped to spilled gas that might explode. In theory, yes, those voltages can cause harm. But there are redundant safety systems built in to the Prius to reduce risk of injury to passengers and rescuers. All high voltage cables are bright orange. There automatic shut offs that occur in case of accident.
    Your friend is ilinformed.
  3. GreenSteve
    GreenSteve Web Hosting Provider
    89
    Palm Springs, CA
    If you do ever have an accident, it would be a good idea to power down the car - if possible. This would cut the voltage supply to the electric motors, greatly reducing the risk of shock.
  4. toolbox
    toolbox New Member
    72
    St. Louis
    voltage isnt what kills you. its the amperage.. walking across a carpet with only socks you build up static electricity (meaning electricy that is not moving) you pick up electrons. when you touch your best friend lip and dischare you just put 10,000 to 50,000 volts into there body with only a very small .001 amp but enough to get you popped. usualy high votage carries high amperage but not always. i use to have a chart that showed what different amperages did to the body and i think it was like 3 amps will kill you but might be wrong on that it might be a little lower.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Ok your right LOL about the amperage. Just like it's not Hot it's the Humidity LOL
  6. toolbox
    toolbox New Member
    72
    St. Louis
    if it makes you feel any better Toyota is spending Millions of dollars in the U.S. to train firefighters how to extract people from their hybrids. I think firefighters were getting hurt in the past from using the jaws of life to extract people and getting ahold of the hot wires. yea they are dangerous from a certain point of view ....but so it having a sheet of glass in front of your face doing 75 mph P
    the battery itself is i think 56 indivual cells (correct me if i am wrong on that)and each can be replaced individualy but is not done at your Toyota dealer but a district office. i have heard of some small battery issues and it does get hot hence the cooing fans to keep it cool. i am unaware of any of the Toyota hybrid batterys having an exploding issue. the battery does have a service plug that you can remove to shut down the hybrid
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    3 amps??
    hmmm 250 ma will easily kill a person who has wet feet, and a voltage of "just" 250...
  8. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Go to http://techinfo.toyota.com/ and check out "Emergency Resopnder Information." This is a free download area where you can get Toyota's documentation for first responders.
    I checked with my fire station and found that they did not have Prius information, so I printed it and took if over.
