Installing Cruise control
Discussion in 'Gen 2 Prius Accessories & Modifications' started by claremontprius, May 21, 2007.
  1. claremontprius
    claremontprius New Member
    Hello All,
    I just ordered the engine block heater and the cruise control from here:
    http://www.metrotpn.com/ProductDetails.asp...amp;SortIndex=1
    Before I go about messing with the installation, I wanted to ask people here for their advice. Have you installed this ? If yes, how exactly did you go about it. I take it some of the instructions outlined here : http://www.ozonehouse.com/prius/ apply to me as well (except for the drilling part).
    Thanks.
    KBP
  2. tochatihu
    tochatihu Senior Member
    9,765
    3,766
    Kunming Yunnan China
    2001 Prius
    [attachmentid=8233]
    Welcome, KBP, to the select group of classic Prius!
    The ozonehouse page and instructions that come with the kit are both good so read them thoroughly. See also:
    http://www.kluge.net/~felicity/pics/index.php?group=2
    and a Graham Davies pdf attached here. Now you're all papered up. A few other hints, possibly repeats:
    If you have a 'gear puller' or can purchase a cheap one, it is the correct way to remove the steering wheel. Otherwise, remove the nut and bang on the backside with a mallet.
    My trick to remove the welded nut on the brake switch bracket worked well. Use an abrasive wheel and a Dremel mototool (or similar) to nick each of the welds, then they can be turned more easily. Eye protection for flying sparks.
    When you install the new steering wheel, you have to 'hit' the splines correctly so the steering wheel is level when the wheels are straight ahead.
    I did this on a low-humidity day and scared of static sparks vs. the airbag. Wore wrist grounding straps and was a bit scared.
    Your new brake light switch must be adjusted to the correct depth so that the lights come on with the slightest pressure on the pedal.
  3. claremontprius
    <div class='quotetop'>QUOTE(tochatihu @ May 22 2007, 07:19 AM) [snapback]447288[/snapback]</div>
    Useful information in the pdf file, tochatihu. Thanks a lot.
  4. bobdavisnpf
    bobdavisnpf Member
    149
    <div class='quotetop'>QUOTE(KBP @ May 22 2007, 09:41 AM) [snapback]447373[/snapback]</div>
    You could check with your dealer too, they might do it. Mine did an install using all stock Toyota parts (from Canada, where the '01 had cruise option) and volunteered to cover it along with the rest of the car.
  5. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(bobdavisnpf @ May 25 2007, 04:43 PM) [snapback]450042[/snapback]</div>
    I had an aftermarket stereo shop install cruise on a car once and it was fairly inexpensive.
