Attaching digital photo
Discussion in 'Gen 2 Prius Main Forum' started by lenjack, May 26, 2007.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    How do I do this? I have an image to post with a question and I can't seem to get it right. I can copy, but not paste?
  2. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    First, "Fastreply" doesn't include images unless you select "More Options" at the bottom. So select "Addreply", or full edit with a new topic.
    Scroll down, and you'll see a box where you can select "File Attachments".
    Click the "Browse" button, and it will allow you to find the image on your computer.
    Once you have selected the image and its' path shows in the file attachments box, click "Add This Attachment" beside the "Browse" button.
    Then you will see a box further down with your filename in it. Click on "Add into Post" and the image will be added into the message. Note that it can be important -where- you add it, so use your normal text editing skills to move the "image" (just a name in brackets at this point) exactly where you want it. Text above, text below, etc.
  3. lenjack
    804
    114
    Pennsylvania USA
    Many thanks, but how do I add the image on a new post, not a reply?
  4. David Beale
    5,963
    1,988
    Edmonton Alberta
    <div class='quotetop'>QUOTE(lenjack @ May 26 2007, 07:32 PM) [snapback]450593[/snapback]</div>
    I think you've been a member long enough and have enough postings to have file attachment privileges. The same steps apply with a new posting. The posting places are below the text box where you type your message.
  5. priussoris
    priussoris New Member
    1,005
    "Click the "Browse" button, and it will allow you to find the image on your computer.
    Then you will see a box further down with your filename in it. Click on "Add into Post" and the image will be added into the message. Note that it can be important -where- you add it, so use your normal text editing skills to move the "image" (just a name in brackets at this point) exactly where you want it. Text above, text below, etc."
    copied from above just do this
  6. lenjack
    804
    114
    Pennsylvania USA
    Got as far as finding image and "Add This Attachment". Followed your directions exactly, but nowhere do I get the option to "Add into Post" afterwards. Maybe I'm thick! Thanks for trying.
  7. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    <div class='quotetop'>QUOTE(lenjack @ May 26 2007, 07:46 PM) [snapback]450625[/snapback]</div>
    I want to add an image below this text.
    [attachmentid=8379]
    Now there's the button on the bottom right, "Add into Post".
    [attachmentid=8380]
    JPEG pictures seem to work best.
      File size:
      100 KB
      455
      File size:
      116.2 KB
      414
