Real Newbie question: Jumpstarting?
Discussion in 'Gen 2 Prius Main Forum' started by GoEco, May 29, 2007.
  1. GoEco
    GoEco Red Prii Rule
    94
    I'm wondering, can jumper cables be used on a prius to start another car? Can they be used on a prius to start it?
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    If the Prius' 12V battery is dead, the car can be "jumped" from another car or 12V power source. The + terminal is under a red cap in the fuse box on the driver's side under the hood, in LH drive cars.
    You can not assist other conventional cars with dead batteries since the puny 12V battery in the Prius is only used to boot the computers and close the HV relay, not crank the cold engine. You might be able to give another Prius a "jump".
    It's detailed in your owner's manual.
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    from my understanding of the manual, the only way a prius can jump start another car
    is to :
    1) keep the other guys car off
    2) connect both vehicles
    3) turn on prius
    4) take the other guys car keys*
    5)wait 5 minutes or more
    6) disconnect jumper cables
    7) give the keys back and try to start the other car
    * - if the other person tries to actually start his car, this can seriously fry your prius.
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< I'm with rigormortis... in a sense... HOWEVER,
    If someone needed a jump start, I would offer them the use of my cellphone to call for assistance. The chances of serious damage to the Prius is too great to convenience a driver in need. The Prius' 12-volt auxiliary battery is about the size of a motorcycle battery, not nearly large enough for a jump.
  5. GoEco
    GoEco Red Prii Rule
    94
    Thank you oh knowledgeable Priites. :)
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(GoEco @ May 29 2007, 01:40 PM) [snapback]451578[/snapback]</div>
    IMO you are better off with a portable jump start battery. The Prius will pretty much send a trickle charge to the other car.
  7. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Charles Suitt @ May 29 2007, 10:11 AM) [snapback]451510[/snapback]</div>
    This is what I do! I tell them, this car is different, It has no alternator and cannot jump another car. And I offer to make a call for them, or perhaos to let them use my phone.
    Of course, now that I almost never drive my Prius anymore, if someone asked for a jump from my Xebra, I'd be able to tell them, This car runs on 84 volts. It would fry yours. :) And then I'd offer the phone.
