Techs Need Input!
Discussion in 'Gen 2 Prius Main Forum' started by Bear68, Jun 6, 2007.
  1. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    I am a Toyota Tech, (Hybrid Certified) I have just been reading the thread about the Prius owners who have had brake issues. As a general tip when dealing with any and all dealers with any and all concerns..... DON'T GIVE UP!! Keep being the squeaky wheel. One of the resources I have available to me as a Tech is the ability to file what is known as a Dealer Product Report. If I encounter an odd problem with and Toyota less than 5 years old, I am requested by Toyota to file a report explaining what the problem was and how I solved it. These reports are the beginning of such processes as Technical Service Bulletins (TSB) and Special Service Campaigns (SSC or the dreaded word "recall").
    Most Techs don't want to spend the time to do this. Why? Because Techs are paid flat rate. We only get paid for the work we do. We are not reimbursed by Toyota or the dealers we work for for the 30-60 minutes it can take to gather all the necessary info and file a report. Why do I file them then? Because I am stupid and somewhat idealistic. I believe in Toyotas and Prius and other Hybrids in particular.
    There for, my advise is to keep shouting at the dealer until they get the technical specialists that REALLY DO EXIST involved in your situation. TMS WILL STAND BEHIND PRIUS! I have seen it happen time and time again. Don't let them tell you that there is nothing they can do. Keep going higher to the next level until your get satisfaction.
    Btw, as for the brake issues that I read about, I have not seen any in my shop with that concern, but as a long distance guess, I would start looking at the ABS actuator. Even in the event of an ABS failure, the normal hydraulic braking system should still function to stop the car. If it does not, the fluid pressure must be bleeding off somewhere. Possibly an environmental issue that I will not see here in South Florida.
    I will no step quietly down from my soapbox.
  2. chinalfr2
    chinalfr2 Member
    234
    New England
    <div class='quotetop'>QUOTE(Bear68 @ Jun 6 2007, 04:53 PM) [snapback]456815[/snapback]</div>
    Thanks for your good work and info. We, as a consumer, need a person to stand out and help us. You're the right person. :)
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I had mine done when the brakes started to make the barking noise. It is gone now and the dealer performed it without question. It was because I had the TSB printed out probably from the result of the hard work you and other techs put in. Thank you. The process is working.
  4. robincx
    robincx "Fear is the mind killer"
    1,294
    North Boston, NY
    Thank you for the insight!
  5. Magnus1
    Magnus1 New Member
    Michigan
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Jun 6 2007, 05:07 PM) [snapback]456833[/snapback]</div>
    excuse me, but i have a 2006 prius as well, and i have experinced this "barking" in my brakes as well.. last time i took it into the shop they gave my car back to me with "no problem found" even after i showed them exactly what the car was doing!.. the service manager said that they couldent do anything because there was no TSB and no part has actually failed yet.. i insisted, however i didint get anywhere with them. could you tell me where to find this documentation so this problem finally gets fixed
  6. FloridaWen
    FloridaWen New Member
    573
    Plant City, Florida
    At this point, this is where a good SERVICE MANAGER should step-in-and-take-over and "offload" the burden from you, at least 50% of it.....................
    ;) THANKS for being "honest" with us and contributing to this fine forum, GREATLY appreciated !!!!
  7. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Having seen a bit of this from the independent side and heard a few
    other horror stories, I really feel for how techs are caught between
    a rock and the side of an engine block. Everybody's rushing, trying
    to crank as much finished work and maximize the bottom line as
    possible, at the expense of work quality in too many cases. Typical
    problem but it seems to nail auto techs particularly hard. One thing
    everyone seems to agree on is the importance of *training*, so that
    guys [and the occasional gals!] know what they're looking at and how
    best to proceed, even if it's a routine tire or brake job or oil
    change -- there are enough little caveats about working safely that
    a lot of places are *still* throwing up their hands about hybrids.
    It really sucks when you *want* to do a good, competent job, and
    someone's effectively preventing it... on the flip side they're
    probably getting a lot of pressure from above too, so yeah,
    continued escalation is key.
    For what it's worth...
    _H*
  8. Bear68
    Bear68 Member
    373
    72
    Hi FloridaWen,
    No Offense, but I feel nervous enough having the average Tech playing with Hybrid systems, even for oil changes. I find that due to the technological challenges involved with Prius make it difficult enough to talk to the engineers who already understand the system. Explaining a problem and fix to a manager ad hoping nothing gets lost in translation would actually add to the difficulty.
    Ah well, thats why they pay me the big pennies.....LOL.
  9. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(robincx @ Jun 6 2007, 02:14 PM) [snapback]456839[/snapback]</div>
    This website is for Toyotas, not Hondas.
    :-D
  10. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(Bear68 @ Jun 6 2007, 09:52 PM) [snapback]457030[/snapback]</div>
    isn't that the truth.
    it is hard to get toyota to pay for any time involved in filing these reports. it's hard to get decent pay for diagnostics, period. (or warranty, or extended warranty...)
    still haven't seen a stuttering brakes issue here either, but DH is thinking it's the brake assist function- the pedal doesn't correspond quite the same way in prius vs standard drive cars. maybe it's a little too sensitive? who knows. can't diagnose that over the internet- hold the car closer to the computer...
  11. FloridaWen
    573
    Plant City, Florida
    The Chrysler Dealership (at one time rated 5 star) I worked at (for about a year) as SERVICE MANAGER was a VERY small, "family owned and operated" business (Father handed down to his Sons after his death, Sons getting old and co-handed down to one's Daughter) and employed only two sales persons (one of the Sons <owner> and other the Daughter) and four mechanics (one was part time), one lube and prep person (and lot boy), one office person, one parts guy and ME !! I wore MANY hats, as they say, doing additional jobs like Emissions testing (along with the prep boy helping me), organizing and handing out TSB's as well as making "reports" to Chrysler about "bad products and procedures". Being a small shop, I knew exactly what every mechanic was currently working on and I (in addition to the Owner) would meet and greet nearly everyone that walked in the door. Now when I say "small" I mean that maybe they sold ONE new vehicle a week, or TWO on a very good week. Same for used vehicles, maybe two per week max. They made most of their "income" doing repairs, tire sales, brake jobs, and "guaranteeing" they would do whatever it took for a vehicle to pass emissions tests (at the customer's expense) which usually meant replacing the EGR valve, leaning out the carb, overall engine "tune-up", or in some rare cases, a valve job or new short block (very rare, though!).
    The mechanics were quite "lazy" and "I" ended up doing most, if not ALL of the Repair (S.O.) "paperwork", assigning hours, writing explainations of work performed, etc.
    Being an EX-Auto. Mechanic myself, helped me understand so much more than the "average" Service Manager we see now-a-days !!
    I imagine when working in a MORE "PROFESSIONAL" SHOP, as you do, things are so much different.........
  12. Bear68
    Bear68 Member
    373
    72
    <div class='quotetop'>QUOTE(FloridaWen @ Jun 7 2007, 06:30 AM) [snapback]457237[/snapback]</div>
    Interestingly enough, the dealer I work for is also family owned and operated. I know the owner very well and went to school with one of his sons. When I started here, there were 8 techs, two of them oil changers. I was one of the oil changers, fresh out of trade school, and have worked my way up. Since that time we now have 25 techs a new building with 30 lifts and top of the line equipment. The sales department has also exploded in size. All of the Techs do their own paperwork and are required to keep quality high. We have the luxury of being able to pick and choose at the moment to get only the best Techs for our shop, and the average Tech has been here several years. One of them over 30 years!
    BTW as per Honda...... There will be no more Insight.... Heh, heh,heh.......
    Long live the Hybrid Synergy Drive!
  13. nowatch
    nowatch New Member
    <div class='quotetop'>QUOTE(Bear68 @ Jun 7 2007, 03:55 PM) [snapback]457543[/snapback]</div>
    why should we put in many many extra hrs to get something fixed ? it is a shame that people need to go an extra length just to get decent service.
    like taking our own time to bark up trees to get something looked at.
  14. Bear68
    Bear68 Member
    373
    72
    <div class='quotetop'>QUOTE(nowatch @ Jun 7 2007, 04:51 PM) [snapback]457581[/snapback]</div>
    You are quite correct Nowatch. I guess all we can do is each try to push for change. All I can promise, as a Tech, is that I will do my best to solve every problem that comes to my bay. Life is a learning process, and I expect to be a lifelong student.
  15. galaxee
    9,810
    471
    MD
    flat rate is not conducive to your tech going above and beyond. because he has to do it for free. DH donates a lot of time...
  16. priussoris
    priussoris New Member
    1,005
    <div class='quotetop'>QUOTE(Bear68 @ Jun 7 2007, 02:58 PM) [snapback]457588[/snapback]</div>
    That has been the best comment I think I have ever heard coming from a Tech.
    The ones I have been in contact (before I owned a Toy) was " is it quitting time" and thats it close the bay door'
    Thanks , as you said Life is a learning process, we all can learn something new everyday and since it's all High-tech we need techs like yourself and Galaxee's DH to help us along the way.
  17. brucem5755
    brucem5755 New Member
    Isn't it a shame that 'donating' time is expected these days in many fields.
    Your DH sounds like a man with a passion for his job....a good thing for his customers!
    <div class='quotetop'>QUOTE(galaxee @ Jun 7 2007, 04:18 PM) [snapback]457604[/snapback]</div>
