Dead MFD
Discussion in 'Gen 2 Prius Technical Discussion' started by StuartS, Jun 12, 2007.
  1. StuartS
    StuartS New Member
    34
    Carlisle, UK
    On Saturday while driving the MFD “frozeâ€. The consumption screen showed no info apart from a new full bar every 5 minute period. Switching to the A/C screen showed a message†Check air condioner connection†and the audio screen announced “Audio Off†even though the radio was playing. The display & info screens seemed to work OK. After about 20 minutes the MFD came back to life, turned the radio off and showed apparently correct miles travelled and average consumption.
    The problem’s become more frequent until now (Tuesday) the same thing occurs when staring the car, the MFD coming to life after about 10-20 minutes, turning off the radio.
    While a temperamental MFD is generally liveable with if annoying, loss of heating/cooling controls is a pain! It certainly added a certain amount of hilarity to our holiday.
    Has anyone experienced similar problems or are there any service bulletins for this problem? My Prius is a NHW 20 T3 with cruise control added, registered in March 2004 so just out of warranty.
    Stuart S
  2. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(StuartS @ Jun 12 2007, 04:16 PM) [snapback]460406[/snapback]</div>
    Yeah, there's a TSB. If you search "MFD" under the care/maintenance troubleshooting forum you'll see a number of threads on this failure.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(MegansPrius @ Jun 12 2007, 02:30 PM) [snapback]460414[/snapback]</div>
    That TSB is for the 2004.
    He has a 2003 that was registered in 2004.
    Not sure if there was a TSB for the Classic Prius.
  4. StuartS
    StuartS New Member
    34
    Carlisle, UK
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(seasalsa @ Jun 12 2007, 06:22 PM) [snapback]460463[/snapback]</div>
    He said:
    That's a 2nd gen Prius...AKA 2004 MY. Sounds like the classic 2004 MFD issue.
  6. hill
    8,790
    Better hope to God you got one of those Extended Warranties (tho some here say they're a waste :lol: ) because somewhere around $1,500 U.S.D. will get you a rebuilt one. Thankfully, even though ours was out of warranty (it began to freeze just after 36K miles), we got the extended warranty ~ so it was replaced at no additional charge. BOOM, the extended warranty just paid for itself, and THEN some :)
  7. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(hill @ Jun 13 2007, 12:26 PM) [snapback]460916[/snapback]</div>
    For a new display module (not rebuilt) the part is ~$4200 USD list and $3032 discounted:
    https://www.trademotion.com/partlocator/ind...p;siteid=213804
    (part number lookup using the TSB). Try seeing if Toyota will foot part of the bill, they have for other big expense problems on a car just out of warranty.
    - Tom
  8. aaf709
    3,862
    2022 Prius Prime
    Right, a rebuilt (if you can find one) is closer to $400.
  9. MegansPrius
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(aaf709 @ Jun 13 2007, 11:57 AM) [snapback]460950[/snapback]</div>
    And in case the OP hasn't seen it, there is a thread on a refurbished MFD source:
    http://priuschat.com/index.php?s=&show...st&p=342719
  10. StuartS
    StuartS New Member
    34
    Carlisle, UK
  11. hill
    8,790
    <div class='quotetop'>QUOTE(aaf709 @ Jun 13 2007, 12:57 PM) [snapback]460950[/snapback]</div>
    $1,500 - $400 ... so the tech made a little extra scratch off the warranty company. (s)he'll have a merrier christmas! Oh well :p
  12. efusco
    19,891
    1,196
    Nixa, MO
    Alternatively, if not already purchased, get the extended warranty before the 3/36k warranty period ends.
    But yea, the first hint of a glitch with my display and I went in to get a replacement after learning of the issue. Not even 100% the "blink" I saw was related, but I didn't car, I wasn't going to get stuck with a $400-$3000 charge for a new display. I'm pretty disappointed with Toyota on this issue. The interface is absolutely necessary to fully access all the features of the car an they know it's faulty. While replacing them all for free probably would dramatically cut into the narrow profit margin on the Prius, it still seems like the smarter move to reassure people that they're going to stand behind their cutting edge cars when they discover flaws.
    Perhaps it's worth a few posts to TMS USA's blog. Politely worded with emphesis on maintaining customer confidence and loyalty of course.
