Vibration on first engine shut down
Discussion in 'Gen 2 Prius Technical Discussion' started by Winston, Jun 15, 2007.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    Every morning I drive about a quarter mile and then wait at a stoplight. This is when the engine first shuts down. There is always a very strong vibration on this shutdown. All future shutdowns and startups are very smooth.
    Is this normal?
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Mine did that when it was new but it went away with time.
  3. 007Prius
    007Prius New Member
    32
    Same here, guess it's normal.
  4. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Mine does that, too.
  5. dogfriend
    7,512
    1,189
    Carmichael, CA
    Normal. Less noticeable with increasing mileage.
  6. daniel
    14,487
    1,519
    Spokane, WA
    Absolutely normal. My 2004 still does this. You get used to it with time.
  7. justifyd
    justifyd New Member
    60
    Yep, sounds normal. It's more noticeable when the engine is cold. Also, I sometimes encounter that kind of vibration when situations cause the HSD to get a little indecisive about whether to keep the engine running or shut it off.
    For the most part, I experience very little (if any) vibration. That's pretty awesome considering the engine is always engaged and it's the motors that have to compensate for engine RPM changes!
    - Justifyd
  8. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    During warmup, the hybrid system doesn't necessarily manage the
    engine as "tightly" as at other times. When you're in full normal
    operation, the hybrid system also keeps very close track of the
    engine's crank sensor and thus has its own copy of exactly where
    the engine is -- and in fact uses the motors to reposition it about
    9 degrees before top dead center at shutdown, to better facilitate
    spinning up again later! Sometimes the roughness is from when the
    hybrid system doesn't bother to do that in some instances, and some
    is from it taking close control the first time -- sometimes you can
    actually feel the engine shut down and then do another little lurch
    right after that. Guess what, it's actually the electric motors
    doing that on purpose.
    A line from one of my training slides says
    "HV ECU gets NEO copy of CKP for RPM and TDC"
    how's that for alphabet soup? It's true, though.
    _H*
  9. Iancole
    Iancole New Member
    georgetown, Guyana, SOUTH AMERICA
    2001 Prius
    Guys I have the first generation prius. It runs great and I love the car. This vibration issue is something I noticed too but recently I have gotten alot of problems. When I start up the engine idles ar per norm but then after a few seconds the revs seem to fluctuate, my battery indicator (HV) goes from a low level to full green bar in an up and down manner. The vibration sounds and the engine then seem to free wheel, and the revs seems to increase. Accessing drive mode does not result in the car moving. It just seems to be out of gear. I have checked from the aux batteries, the HV batteries, the ECM etc.. even the pedal sensors and cant find a clue. My investigations so far has shown:
    (1)no fault indications,
    (2)the turtle icon is on after a few seconds into start up
    (3)and the knock sensor seems to be the one which is picking up the vibration and sending a signal to the ECU.
    My question is this: is it possible that the transaxle is damaged or some other component in the coupling of the PSD and the ENGINE and MG1, MG2? I need help. Where I live there is no authorised toyota dealer, and the lots of mechanics here not familiar with this baby.
  10. donovanbaldwin
    donovanbaldwin Donovan
    Copperas Cove, TX
    I would also say, "normal". I have had my 2006 for 2 1/2 years and it still does it from time to time. No rhyme or reason that I have spotted yet.
    Don
