Electrical Noise
Discussion in 'Gen 2 Prius Technical Discussion' started by piusg, Jun 17, 2007.
  1. piusg
    piusg New Member
    Hey gang! This is my very first post on PriusChat!
    My wife and I picked up a 2007 Barcelona Red Package #1 Prius from Earl Stewart Toyota in West Palm Beach, Florida. We love the car and could not be happier with it--and have been putting up a respectable 42.5 miles per gallon since we took delivery (I'll read the forums more to better that--but my wife has a bit of a lead foot I'm trying to get her to calm :) )
    In any case, here's my question:
    My wife has an XM Tao that she'd like to use in the Prius. When I power it through the cigarette-lighter adapter it into either one of the accessory jacks--either under the dash or in the armrest--the electrical noise coming through the unit is enough to tear your head off. It is no different whether the Tao uses its FM transmitter to broadcast to an empty radio station or plugged into the AUX jack in the armrest. The problem is abated a little on battery power, but not much.
    I'd like to know how I can quell the electromagnetic interference flowing through my Tao.
    Help! What do I do? Local radio in South Florida is terrible! We need our XM!
    Thank you so much in advance!
    Gregory Pius
    Wellington (like the beef), Florida
    2007 Barcelona Red #1 Prius
  2. Sufferin' Prius Envy
    3,998
    Hi Piusq/Gregory,
    WELCOME TO PRIUSCHAT!!!
    By "on battery" do you mean the XM Tao battery (and not plugged into the Prius power) or do you mean when the Prius is running on battery (gas motor not burning petrol) ?
    Does the interference get worse when the ICE is running?
  3. piusg
    piusg New Member
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Jun 17 2007, 08:49 PM) [snapback]463665[/snapback]</div>
    Thankies!
    By "on battery" I mean when the Tao is running on its internal battery. Doesn't wmatter a whit what the Prius is doing.
    Being a PriusChat.com newbie, I'm not entirely sure what ICE is--I'll assume you mean the Internal Combustion Engine--but as I mentioned above, it matters not what the Prius is doing. I get the hideous interference either way.
    Thanks in advance!
    Gregory
  4. Sufferin' Prius Envy
    3,998
    Another question:
    Does the Tao make the same noise in other cars, or with home stereo receivers?
    If not, then I would ask the dealer's service department what the dilly.
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Unfortunately, this may be a difficult problem to solve. The FCC requirements for rejecting noise in your XM Tao are minimal. (This is the reason airlines need to turn off electronic gear, a few items out of 100's actually jam radios.) Please consider this a dual problem of a car that makes more EMI (Electromagnetic Interference) than usual and a radio that does little to nothing to reject EMI. The major cause of the noise is the DC/DC converter changing the HV battery output voltage to 13.5 Volts to power the Prius electronics, lights, windows, etc. This is always operating, hence it will always be present as long as the Prius is on. That said, here are some possiblities.
    1) If at all possible, borrow another XM radio and try it in your car. All it takes is a bad ground wire or bad filter capacitor in the power filter. If the problem is still present then.....
    2) Try the XM radio in another Prius. (Go the dealer and ask if this radio works in a Prius, and actually find out.) This "double disassociation" is very important if you get really serious about the problem. Please document everything (date, serial number and model, VIN of the Prius's used, etc.). It may seem like overkill now, but some engineer at either XM or Toyota does care, but cannot do anything if no details are preserved. If you do discover something, then you are armed to go to the service department or XM with specifics.
    3) Look amoung all the battery powered items and computer cables you have in your house or at work. If you are lucky you will find a big "weight" that clamps on the end of one of the cables. This is a ferrite choke that is meant to filter some EMI. Snap it on and see if it makes a difference. http://www.tdk.co.jp/tefe02/e9a15_zcat.pdf is a data sheet of what these look like (so you know what you are looking for). I do not see this solving the problem, but if one is lying around, it is worth a try.
    4) At this point it has become too painful of a science project since specific EMI filtering is necessary (but may not be sufficient) and all you want to do is listen to your radio. Since even I am too dumb to go past this point, I would see if I can charge one battery while operating with another.
  6. piusg
    piusg New Member
    Thanks for the tips, FL_Prius_Driver.
    One of the first things I tried was a ferrite choke, but I didn't have one big enough, I don't think (I cannibalized one from a disused VGA cable). Since the cable is going to be hidden anyway I don't really care how big the choke is going to be. Maybe I'll order a bigger one from DigiKey or something.
    To Answer Sufferin' Prius Envy's question, the Tao worked great in the previous vehicle it was installed in (a 2005 Chrysler Pacifica). So I'm thinking the problem is specific to the Prius.
    I wonder if anybody else has had the same difficulty with their XM/Sirius equipment, or perhaps their iPod/MP3 players...?
    Cheers!
    Gregory
  7. keerock
    keerock Junior Member
    Bridgewater, CT
    2013 Prius Plug-in
    I have a 2007 Prius and using the Sirius Stiletto. I have a low hum at higher volume. Looking for answers as well.
  8. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    I've had an intermittent variable buzz since I bought the car, on both my XM Roady 2 getting DC from the center console lighter plug and my Ipod on internal battery. By intermittent I mean I hear it maybe once a week, and it is also short-term intermittent when it is there, coming on a couple times a minute on the day it's there. When it does it it's only for a duration of 5-6 seconds. You would think it would be a consistent problem, but it's not... most trips I don't hear it. I also have a vhf/uhf ham radio installed and do not get any interference there, High Frequency (world-wide bands) ham radio is nearly impossible in a Prius so I haven't even tried. Radio Frequency interference is darn-near impossible to track down without spending a lot of time experimenting, including installing the ferrite chokes mentioned before on both the audio wire and power wire. You might also try simply routing the wires on the other side of the car. Sounds like you pretty much covered the bases already though, the device itself might be picking up the RF. If you are using an external antenna, try wrapping some aluminum foil around the unit itself and see if it helps. That would tell you if the circuits in the device are picking it up directly. Good Luck and keep us posted!
  9. piusg
    piusg New Member
    <div class='quotetop'>QUOTE(abq sfr @ Jun 21 2007, 02:21 PM) [snapback]465872[/snapback]</div>
    Rats... I just ordered an XM Roady XT to see if that'll cure the problem...maybe I'll ground and shield the wires and that plus a ferrite choke or two... maybe that'll cure the problem (I hope)...
  10. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(piusg @ Jun 21 2007, 12:29 PM) [snapback]465880[/snapback]</div>
    Just modified my post... it also does it on my Ipod. I almost never use the cd player/am/fm... wonder if it's coming directly from the sound system? Some day when it's there I'll start up a cd and see if I still hear it.
  11. Glint
    Glint New Member
    I have the same problem. My wife's TAO works great in her first generation Prius, but makes a horrible high pitch noise in my 06 Prius. My first generation XM raido works great in both of our Prii.
  12. christob
    christob Member
    183
    Arlington, VA
    Not sure at all about XM, and whether this solution may help...
    But I had the hum CONSTANTLY, when using my iPod plugged into the AUX jack, and powered by the AC outlet in the armrest.
    I believe it was Darell (forgive me if it was someone else!) that had a post elsewhere here, mentioning using a ground/line noise filter---I ordered one from Crutchfield (Item# 127SNI135), it arrived 2 days ago, and the difference in sound quality is astonishing. Here's the link, hopefully:
    http://www.crutchfield.com/S-1zvxmCtoCf5/c...amp;i=127SNI135
  13. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I've seen 12V power noise filters at Radio Shack. These solutions will work well if you don't connect the device to anything else, but when you connect the audio output to the car's system you -could- reintroduce the noise on those wires. I suspect the Crutchfield one would solve that problem.
  14. Wazoo
    Wazoo New Member
    Hi folks.
    I just purchased a Roady XT for my 07 Prius. I am having the exact same problem. High pitched, horrible noise when using the AC adapter when using the AUX jack. Also, the FM modulator seems too weak to get a good signal to the antenna (unless you hold your hand on the XM radio, then it works ok :blink: ). I tried another XM portable radio that works fine in other cars, same result. I plugged in an IPOD to the aux jack without using the AC adapter and it worked perfectly, no noise. I love the car but this is very disappointing. :( I live in a small town with 2 radio stations....this is gonna be torture.
  15. piusg
    piusg New Member
    Thanks for all the help on this topic. I sincerely appreciate all the response. I ended up solving the problem--but it requires a bit of effort.
    I was able to get the Tao to work without any noise at all.
    I took the dash apart and installed an XM FM Modulator inline with the Prius's antenna. That cured the noise problem, even when the Tao is plugged into the 12v outlet.
    It would seem that the AUX jack is extremely noisy--an annoying defect in such a technologically advanced vehicle.
    Thanks again, everyone.
    Winston Wolf likes this.
  16. dallas2727
    dallas2727 New Member
    I have the same problem with the ipod in the console AUX jack. High pitched sound. Haven't worked it out yet.
  17. piusg
    piusg New Member
    <div class='quotetop'>QUOTE(dallas2727 @ Jul 11 2007, 10:25 AM) [snapback]476780[/snapback]</div>
    It would seem that if you plug your accessory (iPod, XM Radio, etc.) into the AUX jack without plugging your accessory into the 12v outlet--either 12v outlet--then it works okay; there's still a little bit of noise. But when you apply 12 volts from the car's electrical system, the noise appears with a vengeance.
    This smells like an engineering issue that Toyota needs to address. Not really TSB-worthy, i guess, but if enough people complain...
  18. Suna
    Suna New Member
    I had a similar noise problem in my Prius with a Delphi SkyFi 2 XM radio. What worked for me was a Radio Shack Ground Loop Isolator, part #270-054. This is similar to the one Crutchfield sells that was mentioned by another poster.
    The Radio Shack model comes with male phono plugs on each end, plus a phono to 1/8" adapter which will plug into the aux in jack on the Prius. I had to buy another phono to 1/8" adapter to plug into my XM radio.
    The problem is caused by a small voltage difference between the ground connection at the aux in jack and the ground (negative lead) of the 12 volt cigarette lighter jack. This small voltage causes a small current to flow in the shield of the audio cable, which in turn generates a small voltage between the ends of the audio cable. This voltage (or noise) gets added to the music, so you hear it.
    A ground loop isolator contains a couple of small transformers which couple the signal magnetically between the input and output. There is no wire between the input and output, so no current can flow in the shield of the audio cable.
    A ground loop isolator isn't likely to help if you are using a modulator to send the signal to your FM radio, nor if your audio device runs on its own internal battery. It will only help when you are using the aux in jack of the Prius AND plugging your audio device into the 12 volt cigarette lighter jack.
    Hope this helps.
  19. Wazoo
    Wazoo New Member
    <div class='quotetop'>QUOTE(Suna @ Jul 11 2007, 10:10 AM) [snapback]476810[/snapback]</div>
    I just tried using this part from Radio Shack and everything works perfectly now, thanks alot )
  20. quotemstr
    quotemstr New Member
    Bufalo, NY
    Thanks for the helpful explanation.
