ReChargeIT
Discussion in 'Gen 2 Prius Technical Discussion' started by LYLUVLY, Jun 21, 2007.
  1. LYLUVLY
    LYLUVLY New Member
    150
    Huntington Beach, Ca
    This article was in Google today. Does anyone know how to join in this program?
    By using hybrid cars to contribute to the power grid, it could reduce the amount of coal-burning power plants which contribute a large amount of greenhouse gases.
    You can check out the information on rechargeit.org and learn more about this vehicle. This is the specs listed on google.org for this modified Toyota Prius vehicle:
    73.6 MPG
    1.4 gal/100 mi, 3.2 liters/100 km
    113.9 Wh/mile
    Watt hours used per mile
    68% fewer
    CO2 emissions
    vs. the average car in America
    This car is called a plug-in hybrid electric vehicle which gives you an extra ability to charge or uncharged the car like a traditional electric car. The vehicle also has the ability to use gasoline to power it as well so you won't have to worry about running low on battery juice during a long drive, and your car will also charge the battery off of the gas engine.
  2. mcsj
    mcsj Member
    125
    Earth
    <div class='quotetop'>QUOTE(LYLUVLY @ Jun 21 2007, 09:28 PM) [snapback]466161[/snapback]</div>
    It is not a project that others can join. They don't take donations either. The only thing you can take part in is get your Prius upgraded to plug-in, and then register your car on their web site.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Google's RechargeIT.org program is completely experimental. They have four Prius, two of which have been converted to PHEV. They are not making a serious contribution to the grid.
  4. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Bill Merchant @ Jun 21 2007, 10:22 PM) [snapback]466215[/snapback]</div>
    Nor do I want much emphasis put on contributing to the grid through gasoline-fired generators!
  5. mcsj
    mcsj Member
    125
    Earth
    <div class='quotetop'>QUOTE(darelldd @ Jun 22 2007, 01:39 AM) [snapback]466233[/snapback]</div>
    I agree. I don't know why the RechageIt.org gets more attention than their solar project
  6. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(darelldd @ Jun 21 2007, 11:39 PM) [snapback]466233[/snapback]</div>
    That's not what they're talking about. Like CalCars, they want to use the PHEVs as distributed energy storage for peak shaving, to reduce the need for more electric generators: Charge the cars at off-peak times, when there is excess generating capacity on the grid, and then feed some of that back into the grid, at peak times, when generating capacity is at or near its limit.
    I'm a bit skeptical, because you can find your car less than fully charged when you want to do a lot of errands. But at least they're not talking about using the car's gas engine to generate electricity for the grid.
  7. Tyrin
    Tyrin New Member
    272
    Correct me if I'm wrong, but won't any electricity sent back into the grid mean MORE gas used the next time you drive? The electricity has to come from somewhere.
  8. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    <div class='quotetop'>QUOTE(Tyrin @ Jun 22 2007, 09:21 AM) [snapback]466296[/snapback]</div>
    From the sun, perhaps?
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(zenMachine @ Jun 22 2007, 11:22 AM) [snapback]466367[/snapback]</div>
    Some of the High School kids that build EV's have a wind powered generator on a tower that they use to recharge the vehicle away from home.
  10. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Tyrin @ Jun 22 2007, 07:21 AM) [snapback]466296[/snapback]</div>
    I think you did not see my post immediately before yours. You were probably typing when my post appeared. The electricity the car sends to the grid came from the grid in the first place. The car acts as storage for peak shaving. The car does not generate the electricity it sends to the grid.
