3 weeks and it won't go!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zoozoo3, Jun 28, 2007.
  1. Zoozoo3
    Zoozoo3 New Member
    46
    So I head outside this afternoon to run errands in my new toy, get the dog loaded in the back seat, and the car won't go! Initially I got the regular display (except for the "READY" light,) then I got an icon that I later learned was an engine. I powered off, and powered on again. The windows were very sluggish and this time no blue things came on, only all the red/orange warning letters/icons. I powered off again. The owner's manual told me that icon means take it to the dealer! Since I couldn't make it go, that was not possible. So I went inside, called the nearest dealer's service department and was talked through the loose gas cap issue (which I don't think this was because I had been driving on that tank of gas for 2 days with no problem and thanks to this site knew about making sure the cap was tight.) I reseated the cap just to make sure and tried to start the car again and this time everything flashed on the dash, including all the P/N/D/R/B letters with boxes around all of them! Then - nothing! When the tow truck driver arrived, we spent about 30 minutes trying to find and use the battery terminals first under the hood, then in the hatch so he could get it into neutral. Again, thanks to this site I knew where to look and how to get the fuse box cover off. The terminal under the hood was so small that the driver couldn't get the jumper cable connected so we decided to try the battery in the back. However the hatch door was locked. I thought this was odd since I had unlocked everything right at the start with the fob and all the other doors were unlocked. Finding the inside hatch release was not easy, even with the hints on here, but I did get it open eventually and we found the battery, however we couldn't get to the positive terminal because of the red cover over it. (How does that come off??) The driver tried the terminal under the hood again and was successful this time. He powered up and the dash display looked normal, with a few extra things illuminated like the triangle. He was able to get the car on the flatbed under its own power, and I noticed the ready light was now on and no warning icons.
    :( Does anyone have any idea what could have happened? I drove it yesterday and it was fine. I had been using the auto headlight setting with no problem since I got the car. And when I got in today that was the position it was in. However, there were no headlights on after I shut the door last night and locked the car and nothing beeped to warn me of a problem then. Did I do something I shouldn't have? I really miss my car!
    Also, is there anything I should make sure the dealership does/checks/resets that might not happen automatically? (It is still under the original 3 yr/36,000 mile warranty - it has just over 17,000 miles on it now, with less than 1000 logged by me.)
  2. Zoozoo3
    Zoozoo3 New Member
    46
    Whew! Just heard from the dealer - not my fault! :D Failed auxiliary battery, replaced (I expect under warranty.) Is this a common occurrence or a fluke?
  3. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    Fluke as far as I know.
  4. 1x1
    1x1 Member
    147
    45
    You sure you didn't leave something on that drained the battery? Are you sure you powered off the hybrid system before exiting the car for the night?
    I've heard you should turn the SKS off (button under steering wheel) if you're not going to use the car for more than a few weeks, to avoid draining the battery, but that's about it.
  5. Zoozoo3
    Zoozoo3 New Member
    46
    Dealer said this was nothing I caused - just a failed auxiliary battery. I asked if this was something that was common that I could expect to happen again and he said no. He had never had this happen before. Sounds like a fluke after all. I do know the hybrid system was off and nothing beeped or binged to warn me anything was amiss when I put "Tink" to bed Tuesday night. I am absolved!
  6. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Just to let you know, by leaving on the headlight switch and using the auto-off there is a slight extra current draw with the car off. Nothing to worry about if the car is driven daily, but I bet your 12 volt was marginal to begin with and that may have pushed it over the edge. A new 12 volt battery is nice though.
    Wayne
  7. Zoozoo3
    Zoozoo3 New Member
    46
    <div class='quotetop'>QUOTE(FireEngineer @ Jun 29 2007, 09:00 AM) [snapback]469987[/snapback]</div>
    Good to know. I will not use the auto-off any more just to be safe. Is 12 volt battery failure common?
  8. FireEngineer
    1,247
    124
    <div class='quotetop'>QUOTE(Zoozoo3 @ Jun 29 2007, 11:25 AM) [snapback]470078[/snapback]</div>
    According to Toyota no. However I am seeing more failures on '04-'07 Prius in all the groups I monitor.
    Wayne
  9. Zoozoo3
    Zoozoo3 New Member
    46
    <div class='quotetop'>QUOTE(FireEngineer @ Jun 29 2007, 01:38 PM) [snapback]470165[/snapback]</div>
    Verrrrry interesting! For future reference could I have driven the car safely after jumping the 12 volt when the display said "READY" in order to get it to a dealer? Actually the display looked normal after the tow truck guy jumped it - if it looks normal, is it?
  10. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(Zoozoo3 @ Jun 29 2007, 09:38 PM) [snapback]470395[/snapback]</div>
    there are a few instances where the headlight auto off doesn't work. One that I know of is if you were to pull the door handle before you hit the power button. If left overnight it would surely drain the battery. A good suggestion is to find some jumper cables that will fit the boost terminal in the fuse / relay box. From my understanding it only needs a little bit of juice from the 12v to boot up the system.
  11. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    if i open the door and then turn the car off, my lights still go out. i do that somewhat often.
  12. qbee42
    3,081
    <div class='quotetop'>QUOTE(Zoozoo3 @ Jun 28 2007, 01:06 PM) [snapback]469484[/snapback]</div>
    It's not common, but keep in mind that the auxiliary battery is small compared to normal car batteries. Leaving a door ajar or an interior light on can drain it pretty fast, in which case the battery hasn't so much failed as been killed. I always lock my Prius just to make sure all of the doors are properly latched.
