Bad case of mood swing & unplanned spending
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Speedracer, Sep 15, 2004.
  1. Quickster
    Quickster Junior Member
    Cumberland Cove - Monterey, TN
    <div class='quotetop'>QUOTE(naterprius\";p=\"45431)</div>
    Thanks Nate. I look forward to the information and when I do get it I will get on the Prius stick and get them ordered. It will be an interesting adventure.
    "Curiouser and Curiouser" replied Alice.
  2. naterprius
    naterprius Senior Member
    1,843
    Okay, here is the response on the mirrors. I recommend you refer to the parts the same way I did, by referring the to the item numbers on each web page.
    Dear Nate,
    Unfortunately I do not even know the parts number for these parts.
    But I would quote them for your friend if you can let him know my E-mail
    address.
    Best Regards,
    KOJI
    ----- Original Message -----
    To: <[email protected]>
    Sent: Saturday, October 16, 2004 10:34 AM
    Subject: Re: Toyota Parts Question
    > Koji, I am not ready to order, but I have a friend who would like to order
    > from you. Do you have part numbers for these accessories so I can relay
    the
    > information to him? If not, what should he ask for?
    > Can he email you at this address?
    > Also, if he is successful with his installation, many more of will be
    > ordering these!
    > Nate
    > >From: "JAPANPARTS.COM" <[email protected]>
    > >To: "Nate"
    > >Date: Sat, 9 Oct 2004 19:18:03 +0900
    > >Dear Nate,
    > >Thank you for getting back to me.
    > >Here is the estimation for Toyota parts.
    > > *TOYOTA Mirrors with Turn Signals: 37,200JPY
    > > *TOYOTA Mirror tilts angle in Reverse: 14,400JPY
    > >Sub Total: 51,600JPY
    > >Shipping to U.S.A Via EMS: 2,000JPY
    > >*It will take us about 10-15 days for preparation and delivering the item
    > >after we receive your payment.
    > >(Estimated days are until it arrives to U.S.A
    > >and domestic delivery would take some more days)
    > >Mail Order Card Sale (5%) for Credit Card Company: 2,830JPY
    > >Total: 56,430JPY
    > >Universal Currency Converter
    > >http://www.xe.com/ucc/
    > ><How To Order>
    > > Please read about the payment at
    > > http://japanparts.com/Howtoorder.htm
    > > and fill out our Secure Server Order Form at
    > > https://www.japanparts.com/partsorder.html
    > >Thank you very much.
    > >JAPANPARTS.COM
    > >KOJI
    > >From: "Nate"
    > >To: "JAPANPARTS.COM" <[email protected]>
    > >Sent: Saturday, October 09, 2004 5:45 AM
    > >Subject: Toyota Parts Question
    > > > Koji, are these parts (accessories) available to be shipped to the
    > >United
    > > > States?
    > > > http://www.toyota.jp/dop-prius/dress.html
    > > > Item #6: Mirrors with Turn Signals
    > > > http://www.toyota.jp/dop-prius/functional.html
    > > > Item #3: Mirror tilts angle in Reverse
    > > > Nate
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I like most of those products on the Dress and Functional pages. It would cost me about 2k usd.. if i calculated it all up right. all i need now is 2k.. and i'm pretty sure some of those items do not work together.. or do they?.. hmm
  4. Tideland Prius
    16,508
    oh wow! I would love a set of those aluminium door scuff plates =)
  5. Quickster
    Nate,
    Thanks for the information. I have already sent an eMail and am anxiously awaiting a reply.
    Will keep you appraised of the progress.
  6. Speedracer
    Speedracer New Member
    378
    Nagoya, Shanghai
    Dont forget to check the part number.... The mirror is already painted with original color.
    Also, no seaside Blue untill recently,
  7. Speedracer
    378
    Nagoya, Shanghai
    But its expensive 18,900 Yen, like 180bucks... But its really nice,,, I never had time to install yet
  8. Tideland Prius
    16,508
    USD? wow.. anything special e.g. it's illuminated? or is it just a regular scuff plate and I can't read Japanese but it's for a set of 2? or 4? or dare I ask.. each?
  9. Speedracer
    378
    Nagoya, Shanghai
    Its a set which means front and back door,
    Its really nice and I dont think grow in nite, I wanted #11 but I dont want spend another 100bucks for it.
    Do you want one? :mrgreen: At this time $175U.S, plus shipping to your door step.
  10. naterprius
    1,843
    Quickster, keep us informed with your results. As far as tapping in the wiring for turn signal, you are going to need to push the wires for the turn signal through the boot to get from the door to the body. I suggest you do them one at a time (remove the connector) and use wire lubricant. This is commonly available at Home Depot, it is designed for just such a purpose. (It is designed not to damage the insulation and to dry completely, leaving no problematic residue like grease would).
    Also, as far as tapping into the wiring for the turn signal, it is possible that Toyota left the connector on the harness inside the fender well just behind the wheel. If they did, that would certainly simplify the connection. If not, you will need to find a place in the harness to splice. This will be challenging, and you should try to splice inside the vehicle, safe from exposure to the elements. I'll see if I can help you with this by looking at the wiring diagram.
    Another issue, the flasher may flash too slowly because there is too much load. If the flasher is traditional style, these are all the same form factor, very cheap to buy, and plug right in. If not, a good cheat would be to replace one of the bulbs on each side with a low draw LED. If we are really lucky, the lights in the mirrors might already be LED, in which case this is a non-issue.
    Nate
  11. Speedracer
    378
    Nagoya, Shanghai
    If I recall correct the installer told me tap the wire from fender turn signal
    I dont know what Toyota dealer did, but now mine flash slightly faster than before :roll:
  12. Tideland Prius
    16,508
    oh really? wow.. that's abt $230cdn... + s/h... I'll have to see first cause I'm still waiting for my Prius.. should be here any time now...
    how do I order later if I want to purchase it?
  13. Speedracer
    378
    Nagoya, Shanghai
    Just PM me if you decided to want one,
  14. Tideland Prius
    16,508
    cool thanks...
    one other question, #9... is that an electrochromic auto dimming wing mirror? or just an anti-glare type that has blue tint?
  15. Speedracer
    378
    Nagoya, Shanghai
    Are U talking about #7?
    If so, its anti-glare mirror A.K.A "Blue mirror"
  16. Tideland Prius
    16,508
    yeah #7... sorry not #9 lol
    ahh... ok then thx
  17. Quickster
    Nate,
    Since I do plan on keeping my Prius for many years, and also like having owner manuals and tech manuals for my cars, where is a good source for the wiring diagrams and other Prius specific references?
    Are these available from Toyota, I am sure for a price, or some place online?
    Thanks much,
  18. naterprius
    1,843
    Speedracer, we don't have a fender turn signal here in the US (All the more reason to want turn signal mirrors!) I am hoping the connector is still there, but I doubt it.
    This tells me the lights in the mirrors are likely LED's. This is good news for USA, since we shouldn't have to change the flasher to achieve the same flash rate. For you, you may wish to change the flasher to slow down the signals to the proper rate. Ask your dealer if one came in the kit that they forgot to install.
  19. Quickster
    My wife called me last night and informed me that my new side marker lighted outside mirrors had arrived from Japan. When I am home for Christmas, the last three weeks in December, I should be able to install them. She told me that look pretty cool and came with lots of instructions, all in Japanese. They actually arrived in only two weeks after I finally got the order placed.
    Soon as I get them installed I will post pictures.
  20. Speedracer
    378
    Nagoya, Shanghai
    <div class='quotetop'>QUOTE(Quickster\";p=\"52915)</div>
    If you need translation let me know :mrgreen:
