My Prius needs a battery, Toyota denies warranty due to EV button
Discussion in 'Gen 2 Prius Main Forum' started by naterprius, Jul 19, 2007.
  1. naterprius
    naterprius Senior Member
    1,843
    Lo and behold, ladies and gentlemen, I present to you the first Prius in need of a battery. Mine.
    Okay, so here's the story. At 3,900 miles, in the fall of 2004, the ICE shut down on my Prius. I drove it to the dealer on electric, and they flashed the ECU with new code, and told me it was all beter. After that, I noticed the car drove differently, and that the MPG was never quite as high. I concluded that it was the new software to blame, and there was nothing I could do about it. Over the next two years the car continued to behave reasonably well, but would suffer sometimes in the heat. It would get sluggish, the battery would drop to one bar (normally six, with a high of 8) and I would hear the battery cooling fan running. This would cause the MPG's to drop into the high 30's. I assumed it was the heat because it was only there in the summer. I had the dealer check it out in 2005 and they couldn't find anything wrong with it. Two months ago, the car really started giving me trouble, MPG's in the 30's all the time (even a whole tank at 38!), one bar on the battery, and the cooling fan running to cool the battery pack even when the interior of the car wasn't hot. I brought it to the dealer, who couldn't find anything wrong with it. I insisted that they keep checking. Finally, they concluded that I needed a new battery. I was shocked. 20,000 owners on PriusChat.com, and not one has needed a battery.
    Then the bombshell: Toyota corporate denied the warranty claim because I had added the "EV" button from Japan which gave you about a mile of all-electric operation. They claimed this damaged the battery, even though they supply this button in Japan and Europe!
    Anyway, I proceded to appeal my case with Toyota corporate, explaining that the trouble started at 3900 miles, through no fault of my own, and they finally came back and agreed to buy me the $4500 battery if I would take out the $40 button. I did, and finally got new battery today.
    I now have a new battery and a full warranty. On the way home the car got about 56 MPG. We'll see what happens on the daily commute.
    I donated my EV button to Hybrids Plus, who does PHEV conversions and kisses the warranty goodbye.
    I suggest the rest of you take out your EV button. It has really sucked the last two months.
    Nate
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    <div class='quotetop'>QUOTE(naterprius @ Jul 19 2007, 08:24 PM) [snapback]481997[/snapback]</div>
    Bummer. But at least you got the new battery.
    I want to install an EV button, but I was wondering if they might try to deny warranty claims based on modification of the system. Now we know.
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    There's always one guy who goes and ruins it for the rest of us!
    :D
    Just kidding. Wow. So they seriously were denying the warranty on the grounds of the button. How come this is the first I'm hearing about it? Did you intentionally keep it hush hush until you had a resolution?
    I suppose I'd have to ditch the button in the same situation. Though I admit that I would spend the next year poking the dashboard from time to time.
  4. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    :eek: who would've guessed? well now we know... and if we do have trouble guess what's coming out of the dashboard?
    glad they worked something out with ya but damn, that was an unexpected story.
  5. naterprius
    1,843
    Yes, Tony, I kept it quiet until they installed the new battery and gave me back the car. I have already signed off on the Repair Order, so they can't change their mind.
    I was prepared to enlist the help of PriusChatters if things went south.
    There is now a blank where my EV button used to be.
    Meh.
    Nate
  6. TonyPSchaefer
    14,816
    2,499
    66
    OH oh oh. That would be a great place for an \ \ \ EJECT / / / button.
    I'm willing to bet that you can find/buy a plug somewhere but you're sure as shootin' not getting mine (just in case).
  7. naterprius
    1,843
    Yes, I have a plug in there now. A blank plug. So very sad.
    Nate
  8. jrmgkia
    jrmgkia Wish I was cycling
    53
    Campbell, CA
    Nate,
    How did they discover that you had the EV mod? I realize that the button is in plain sight but most Prius techs aren't smart enough to know what the EV button is and where to find it. Did you disclose the EV button up front or did they notice it? When did they notice it?
  9. naterprius
    1,843
    The District Tech asked the Dealer tech to check for one, then declared the warranty void, then flagged my VIN so I couldn't take it to another dealer.
    Nate
  10. Tideland Prius
    16,505
    ouch!
    Well, glad to hear Toyota came through for you. $4,500 eh? Must've been after labour and taxes...(that's a lot of labour and taxes!).
    Well, I mean it could very well mean they're just covering themselves, you know? "just take it out and we'll replace it".... unless I'm being naive :ph34r:
  11. naterprius
    1,843
    Tideland, I thought so too, I just couldn't believe there was anything wrong with the battery.
    It seems to be working well. To think, all these years I could have been getting in the 50's.
    I'll report back tomorrow if the MPG's and power remain high.
    Nate
  12. Frank Hudon
    Frank Hudon Senior Member
    4,147
    this is maybe the reason to use the CC EV mod. No button. This isn't the first battery replaced Tempus had one replaced about a year and a bit ago.
  13. silver-machine
    silver-machine New Member
    51
    Sheffield UK
    Hi thats a scary story, and Im glad its worked out for you.
    But ... the toyota dealer response doesnt make sense, as you say outside the US priuses, like mine, come with the EV button. Id say they were trying to scare you into going away. Well done for sticking to it.
  14. naterprius
    1,843
    The dealer is the one who helped me get the battery covered. It was Toyota Corporate who pre-emptively denied the claim.
    Nate
  15. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    If they knew in advance to look for it, don't you think they would find the cc ev mod too?
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(silver-machine @ Jul 19 2007, 11:38 PM) [snapback]482087[/snapback]</div>
    How long is the battery warranty in the UK? I'd also be curious how long it is in other countries w/the EV switch.
    In the US, it's 8 year/100K miles for most of the US and 10 years/150K miles for Cali and a few CARB states.
    The OP was lucky that they were willing to foot the bill on the condition of removing the EV switch.
  17. NoMoShocks
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(naterprius @ Jul 19 2007, 11:12 PM) [snapback]482080[/snapback]</div>
    Wow! I think they really owe you some gas!
    I realize, they have the "no consequencial damages" cluse.
    I just mean morally, they owe you some gas.
    They should give you some compensation just to be sure you continue leaping up into the air and feezing in mid air as you sing;
    "Oh what a feeling"
    "To drive a Toyota"
    "Oh what a feeling"
    "to dri-i-i-i-i-i-i-ive"
    "Toyota!"
    "Toyota!"
    "Oh oh oh what a feeling to dri-i-i-i-i-i-i-ive"
    "Toyota!"
    Sorry, I don't have a copy of the sheet music, and I never learned how to read and write sheet music either. I am a music note illiterate.
  18. T-spirit
    T-spirit New Member
    Bristol, UK
    <div class='quotetop'>QUOTE(cwerdna @ Jul 20 2007, 08:49 AM) [snapback]482107[/snapback]</div>
    In the UK, 8 Year/100,000 mile for the Synergy Drive bits and 3 year/60,000mile warranty for the rest of the car.
    That's why we decided to buy - if the Synergy had been 3 year/60,000 I would have needed to think very hard about the risks.
  19. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    wow scary story..
    I'm glad it all turned out fine..
    Good luck with the MPGs... again
  20. priusmaybe
    priusmaybe New Member
    314
    Atlanta
    <div class='quotetop'>QUOTE(JaviNOS @ Jul 20 2007, 05:01 AM) [snapback]482120[/snapback]</div>
    I have 1200 miles on my car and have been getting in the high30's. I do a lot of short trips. I sure hope my mpg improves.
    Isn't there a way to check the battery or run code to see if it is "bad"?
