Prius causing other cars to malfunction?
Discussion in 'Gen 2 Prius Main Forum' started by RinMI, Aug 2, 2007.
  1. RinMI
    RinMI New Member
    132
    SW Michigan
    A coworker of mine asked me today if I had heard of other cars acting strange around my car. At first, I thought he was trying to say he had a modern day Herbie. His story was as follows:
    He was driving along on a state highway and his radio started acting strange. Eventually, his radio volume reduced significantly. He looked around and there were nothing around save for a silver Prius behind him. As the Prius passed him the radio got worse and then as the Prius continued ahead of him the radio volume got better the farther away the Prius was from him. He stated that his radio has never done this before and hasn't done it since.
    Any ideas? If it is true, which he swears it is, I could only think of possibly the Pri in question giving off a very significant electromagnetic field (possibly the result of a shoddy fully electric upgrade?). Or maybe his car is receiving interference from the Pri due to a flaw in his own radio's installation?
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Prius had a Ham radio installed?
    Prius had an iPod FM transmitter?
    I've never heard of this.
  3. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    This has never been reported before.
    Because the guy was moving, he doesn't know if the cause was something in the area. It's most likely he just drove out of the interference area.
    Even if it's an area in which he normally drives, the cause could have been some construction or maintenance equipment in a nearby building.
  4. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    What would be totally cool is a Prius that could kill the horrible base sound from nearby car stereos.
    One of the worst aspects of living in the city are the *@# idiots who sit in their cars in front of our house killing their hearing while driving us nuts. I heard one in the Battery Street Tunnel here in Seattle; he was a full ten car lengths ahead of me, but his stereo reverberated through the tunnel.
  5. Darwood
    Darwood Senior Member
    5,259
    268
    I'd guess the Prius next to him had either a fuzzbuster or an iPod tuner.
    We have an iPod tuner and it basically emits the iPod output to the radio frequency you want, so that you can pick it up on your car radio.
  6. RinMI
    RinMI New Member
    132
    SW Michigan
    <div class='quotetop'>QUOTE(Rick Auricchio @ Aug 2 2007, 02:29 PM) [snapback]489431[/snapback]</div>
    The area where he was driving is an area where I also frequently drive and is rural area with very few to no buildings near the roadway. He also corrected me on one thing, he stated that he was playing a CD, not listening to the radio as I mistakenly posted before.
  7. TonyPSchaefer
    14,816
    2,501
    66
    I think we need a Mythbusters episode dedicated to Prius and hybrid myths.
    They can start with this one, move on to EMF, and conclude by blowing something up. I'm not sure what, but I only watch the show to see what they blow up. :D
  8. RinMI
    RinMI New Member
    132
    SW Michigan
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Aug 2 2007, 02:36 PM) [snapback]489442[/snapback]</div>
    Forgive my ignorance ... EMF?
  9. christob
    christob Member
    183
    Arlington, VA
    EMF: Both a British band awhile back (think "Unbelievable") and here, Electromagnetic Field. (At least one previous poster had a high level of concern over the potential effects of EMF produced by the battery, as it concerned seating children in the back seat.)
  10. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(RinMI @ Aug 2 2007, 12:33 PM) [snapback]489438[/snapback]</div>
    Prii do give off a lot of electromagnetic radiation, but only in certain parts of the radio spectrum. Ham radio operators know this, its difficult or impossible to work below 30 mhz in a Prius without extensive extra shielding of wires and components in the car. AM/FM frequencies are apparently not in Prius offending frequencies, too low and high. If it was a CD player I doubt if it would be affected by a Prius even if you were using an FM modulator to play through it through the radio. Interesting... the Prius should be considered an unintentional radiator by the FCC, I'll have to look in the owners manual to see if it has the required disclaimer:
    "This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation."
  11. ohershey
    ohershey New Member
    632
    It's just silly to associate the problem with the vehicle model. I have noticed a similar effect once - when I was following a limosene. Each time I got within 40-50 feet, some bubblegum pop music came through every FM channel. It's a problem with some badly installed transmitter of some type - ham, cb, or commercial. When the guy across from my buddy's house fires up his ham transmitter, you can here him clearly from the stereo speakers - whether they are on or off.
  12. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    Someone at M5i drives a white 04 or 05. I've seen it several times on season 2 and 3. Grant is the most likely to have one I'm guessing - seeing as how he's an IEEE member and was on the cover of Spectrum.
  13. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(Mad Hatter @ Aug 2 2007, 01:05 PM) [snapback]489461[/snapback]</div>
    The limo undoubtedly had an FM modulator, one of those devices that will let you play your ipod through your FM stereo with no wires. Many of these were transmitting over the FCC limit for these devices and the FCC came down on the manufacturers. Newer modulators are at or below the FCC limit... not sure how many milliwatts that is. Regarding your ham neighbor, work with him to resolve the problem. You can install ferrite cores on your wires to reduce or eliminate the interference. He should know all about that. Part of being a Ham is working with neighbors to resolve any problem... no matter whether he is causing you interference, or you have a device causing him problems (aquarium heater, electric fence controller, etc).
  14. ZA_Andy
    ZA_Andy Member
    219
    VA
    <div class='quotetop'>QUOTE(Mad Hatter @ Aug 2 2007, 03:05 PM) [snapback]489461[/snapback]</div>
    Then he needs to be reported to the FCC because generating that kind of interference is against the conditions of his license - which would be revoked if not resolved at the operator's expense.
    Not all Ham operators are competent, but by far the vast majority are, and take care not to cause this type of problem.
  15. qbee42
    3,081
    It's not silly when the model in question has high voltage power electronics. The Prius has the potential for huge electromagnetic interference; only through good design have Toyota managed to keep it to acceptable levels. There is no question that the Prius gives off more interference than a normal non-hybrid car, but it shouldn't be much of a problem for ordinary FM radio. It's possible that the Prius in question had some defective parts or bad shielding, our the other car a radio sensitive to this sort of interference. It can't be common or the FCC would be on Toyota.
  16. Bill Spransy
    Bill Spransy New Member
    Great Smokey Mountains
    I think it might be a UFO driving down the highway ( see Close Encounters , the railroad scene). Those interdimensional types always have a good eye for design :rolleyes:
  17. orracle
    orracle Whaddaya mean "senior" member?
    441
    Gurnee, IL
    <div class='quotetop'>QUOTE(simplybill @ Aug 2 2007, 02:30 PM) [snapback]489487[/snapback]</div>
    LOL! That's my favorite scene in the movie as he waves the "car" around and the lights rise...
  18. viking31
    viking31 Member
    515
    22
    West Central Florida
    <div class='quotetop'>QUOTE(ZA_Andy @ Aug 2 2007, 03:18 PM) [snapback]489477[/snapback]</div>
    Not true in nearly all cases. In most cases it is NOT the fault of the Amateur Radio operator. Most Amateur Radio stations operate well within FCC mandated specs. The ARRL (Amateur Radio Relay League, an organization which represents the Amateur Radio community) has case after case of neighbors complaining about interference from nearby Ham operators only to discover their electronic devices (TV's, phones, stereos, etc.) are poorly shielded and designed. A properly designed device will not be affected by Ham radio transmissions or other properly licensed transmitters.
    Now with that being said most if not all Hams will offer free assistance to the complaining party with usually the install of a few inexpensive and easily installed chokes which most times eliminates the problem.
    Rick
    #4 2006
  19. oly_57mpg
    360
    <div class='quotetop'>QUOTE(viking31 @ Aug 2 2007, 03:45 PM) [snapback]489502[/snapback]</div>
    Hummm... yeah, no. Those consumer devices were design for 'normal' use. They weren't really designed to be used next to someone who's broadcasting at 50 to 1500 Watts PEP (Peak Power).
    There are a lot of HAMs that push that boundary a bit and it'd be hard to verify. There's always someone selling something at Hamvention that do it.
    Right, so they don't continue being bugged about the interference from the Tx.
  20. thebrad
    thebrad Junior Member
    I have an '06 with package 4 and an '07 with package 6. The garage door opener in the rear view mirror creates interference in the '07 when listening to the i-pod adapter FM modulator. No interference in the '06 without the garage door opener option. So catch up to that Prius and find out if it has the door opener option. Then there is the smart key option that in the owners manual warns about people with pace makers to disabl;e the feature. Even has a little button down by the knees.
    Brad
