PM archival question
Discussion in 'PriusChat Website Questions' started by hobbit, Aug 2, 2007.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Having reached the "full" point on my PMs, I'm trying to archive
    them offsite before deleting. It appears that the only archive
    mechanism is for the site to batch up an HTML or CSV file and mail
    it to me. I'll spare you the gory details of all the special-casing
    I had to do to allow that to get through my mailserver, but even
    after doing that it seems like the "archive messages" function only
    allows 50 at a time to be batched. In the process of trying to work
    through that, 50 at a time, I just noticed that those 50 are RANDOMLY
    CHOSEN and OUT OF ORDER, thus eliminating my ability to just recover
    the archive and then mark a convenient range of held PMs for deletion
    and then let the system delete them. With this, I'd have to carefully
    pick and choose which messages I'd successfully received via email
    and then just delete *those*, which seems way more work than it's
    worth.
    Is there a means of simply dumping all of one's PMs as straight HTML
    output viewable ON the site, like most other forum systems do? Then
    the user can simply download that as HTML or text and save it off
    however they want. Going through the overhead of batching it up for
    emailing to [possibly broken] recipient addresses is klunky at best,
    and now coupled with a nondeterministic selection process [with no
    option for "just give me everything"] is a true pain in the tuchus.
    Advice welcome. I really am trying to clean up, but it's not making
    it an easy process.
    _H*
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    I'm only at 2/3 full, but I'd like to know how to clean up too.
  3. hobbit
    4,089
    469
    Bahstahn
    Okay, I think I have a partial solution. I wanted to archive the
    "sent items" folder, which when mailed to myself originally contained
    a random, out-of-order selection of what was in there [since I could
    only pick 50 msgs at a time].
    What seems to straighten things out is to create a new folder, and
    then select and move all the messages in the original folder over
    to the new one. Then archive. That seems to linearize it in the
    database, so "first 50" becomes meaningful.
    _H*
