Battery issue...stumped!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by trumpetart, Jul 25, 2007.
  1. trumpetart
    trumpetart New Member
    Hi everyone. I've got a little situation with my 2001 Prius.
    It has had difficulty starting for a long while: When I would turn the key, the dash lights would come on faintly, a soft "whirring" sound was heard, and after 20-30 seconds, the dash lights would finally "click" on and I was free to start the engine. I was just living with it this way for some time, but it took a turn for the worse, taking much longer to start and giving me the /!\ warning light.
    So I took it to the dealer this morning. He first said the battery would need to be replaced with an updated one, then later said, "oh, you have the newer battery: we'll just charge this one and you'll be fine." He attributed the drained battery to the fact that I have an after-market navagation system installed. He suggested either removing it or having it re-installed correctly.
    So I drove it home, went to work, and when I got out to the car after work, it was even worse than before I took it to the dealer! Now the battery is so low only a few lights come on, and even the power locks seem to be responding sluggishly!
    Thank you for reading my :( story. I'm unfortunately pretty ignorant about my car and if anyone can offer any suggestions, I would be most grateful!
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Is this the 12V battery you're having problems with? I would guess so, since the lights run off the 12V battery. Have you ever replaced the 12V battery? Your "newer" battery could still be a few years old in a 2001.
    Welcome to PriusChat, I'm sorry you're having problems. We'll try to help.
  3. trumpetart
    The service guy at the dealer assured me that only the 12v battery was involved. How does one determine the age of the battery?
    This forum is great by the way.
  4. tochatihu
    tochatihu Senior Member
    9,647
    3,721
    Kunming Yunnan China
    2001 Prius
    I do not believe that your Toyota shop is being helpful. Some other shop can test the battery to see if it has lost its original capacity. Visually inspect the battery connections for corrosion. They can also see if there is a high current drain when the car is off, which may or may not be due to your aftermarket electronics.
    There have been previous discussions here on 12 volt battery replacement options, in case you need one. I suspect that you might.
    As you are in the Bay area I will (once again) make a plug for Art's Automotive in Berkeley. If you can get that far :(
  5. trumpetart
    Over the phone this morning, the fellow who looked at the car yesterday recommended going to a car-stereo place to have the nav. system completely disconnected, then getting a jump, and driving around until I'm charged. Seems like a reasonable plan, though I will miss the navagation. Thoughts?
  6. qbee42
    3,079
    <div class='quotetop'>QUOTE(musician @ Jul 25 2007, 11:59 AM) [snapback]484698[/snapback]</div>
    Navigation shouldn't be a problem, unless it stays on when the Prius is turned off. Check the wiring.
    A new 12 v battery is not a huge investment, so if you continue to have problems, get rid of the old one. You may want to check the 12 v charging system.
  7. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(musician @ Jul 25 2007, 10:59 AM) [snapback]484698[/snapback]</div>
    3 things come to mind:
    1) Something is draining the 12V battery while the car is off (Incorrectly installed navigation system?)
    2) The battery is faulty and doesn't hold a charge.
    3) The charging system is failing to charge the battery.
    I don't know much about the pre-2004 Prii, but I didn't think the Prius had an ICE driven alternator, therefore is shouldn't be necessary to "drive around until you're charged". If the 2001 has an ICE driven alternator, then I suppose this is good advice, otherwise you need a service tech to look at it who understands that the electrical system in a Prius isn't the same as in a non-hybrid car (find a new service tech).
    A reasonably good tech should be able to determine rather easily if something is draining the battery while the car is off.
    A reasonably good tech should be able to determine if the charging system is sending current to the battery.
    A reasonably good tech should be able to determine if the battery is capable of holding a charge.
    Such a tech should be able to at least tell you which of these are the problem.
    Come to think of it, I'm a bit confused as to why you haven't been able to get this information yet.
    Perhaps there is some other possibility I'm not thinking of.
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
  9. trumpetart
    <div class='quotetop'>QUOTE(Danny Hamilton @ Jul 25 2007, 03:18 PM) [snapback]485027[/snapback]</div>
    In retrospect, I think I put words in his mouth about "driving around until charged." He probably simply said "get a jump" and then I filled in the rest. Sorry 'bout that.
    Perhaps the reason he didn't determine the problem correctly is that he thought it was a quick fix, just recharge and go. I was not charged a diagnostic fee, just the recharging fee, which he promises to refund as it didn't fix the problem. Then later, over the phone he recommended having the navagation system disconnected. I'm planning to to that today.
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Jul 25 2007, 04:08 PM) [snapback]485053[/snapback]</div>
    This will be tough, as I don't think the screen will power up on my weak battery until I jump-start the car.
    Also in this 2001 prius, the engine always comes on as soon as I turn the key, right? Is the car supposed to run before the ICE kicks in? I know my mother-in-law's newer Prius runs electric first, then the ICE kicks in after, but I didn't realize these older ones were supposed to too...? :blink:
  10. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(musician @ Jul 26 2007, 12:24 PM) [snapback]485467[/snapback]</div>
    If you have reached the point where you need a jump to start, you are right, no screen till started. At least you know you can read the 12V value if the car is on. Go to:
    http://www.elearnaid.com/12vobaforpr2.html
    This is one way you can see how a good 12V battery behaves.
    You are right about the starting behavior. For the early Prius, the ICE always starts at turn on to get the engine to emission control temperature as soon as possible. When the engine has been running, then turning the car and back on again real soon causes the engine to run for just seconds if at all before shutting down. The later models (04 and up) delay the engine start till the hot water tank has warmed up the engine so there is always that delay between turn on and engine starting.
  11. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Just leave it in the driveway in Ready mode for 5-6 hours, if the battery is any good that should bring some life into it. No need to drive and waste gas.
    Wayne
  12. trumpetart
    Yesterday after jumping the Prius, I drove up to have my Nav. System disconnected. They also pulled out the fuse on the car's sun roof, which is another after-market feature I forgot to mention.
    On the drive up, I accessed the Vehicle Signal check screen, and while driving (in stop and go traffic, if that matters) the 12v battery values fluctuated between 13.3-13.6. Is that not unusually high? What does this mean?
    After the uninstall, which took about an hour, it looked like I might need another jump, but it just barely started, and got me back to work. Then after work, surprise surprise, I couldn't get started.
    Thanks everyone for your continuing support. I feel a lot better about all this knowing that there are knowledgeable people to help! :)
  13. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(musician @ Jul 27 2007, 12:31 PM) [snapback]486155[/snapback]</div>
    That is the right voltage for the inverter to be charging the battery. Either you have a bad battery or something is draining the battery after you turn off the car. One way or another someone has to get an reading of how many mA or Amps are being drained when the car is off. Your problem is easily debugged by a good auto technician. Now you just need to find one or become one. Any courage to run the battery test on the link posted earlier?
  14. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Even if it's the "updated" battery for the NHW11, that could be
    gettin' kind of long in the tooth by now for 12V lead-acid. I'm
    even starting to get a little paranoid about my '04 vintage one,
    although it's been successfully running my fan hack during a night's
    sleep without ill effects over the last few days.
    _H*
  15. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Once a lead acid battery gets sulfated, it has a dramatic reduction in capacity. Usually the best option is to purchase a new battery, FULLY charge it with a good automatic battery charger, then install it. Toyota - naturally - recommends their fancy-schmancy 10 amp automatic "Toyota" branded charger, which is made by Associated. This tsb applies to the +2004 but should give a clear idea of what is needed
    The short driving cycle I go through, and the first winter of many -40 nights and constant electric defrost use, left my 12 v battery severely drained. I had purchased several VDC Electronics Battery Minder units at auction, and decided to try one on my Prius. It actually works quite well and I haven't had a problem since. Not sure though if I would pay $70 for a new one, that is a bit steep
    http://www.vdcelectronics.com/batteryminder_12117.htm
    For example, I was gone for two weeks on vacation at my hobby farm. I took the FJ Cruiser and left the Prius in the underground parking. Got in Sat and the Prius powered up just fine.
    If you're curious, here are some photos of the harness from my battery out the hatch. I have flexible plastic conduit covering the wire, but for the photo I removed the conduit
  16. trumpetart
    Update: My car has been in the shop for well over a week now. Apparently, this problem was so mysterious and unusual to them that they "called in expert technicians from the factory" :unsure: .
    Finally yesterday they proposed the theory that the battery is faulty. :blink: If so, I'll be picking up my car and new battery tomorrow.
    At which time, I'll report here, of course.
