What is the purpose of....?
Discussion in 'Gen 2 Prius Main Forum' started by FL_Prius_Driver, Aug 18, 2007.
  1. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    One of the most agitating aspects of the Prius dash is the orange airbag light. Why idoes it have to be the international color for a bad condition? Due to previous jobs, I am trained to react to orange or red warning lights as a serious situation. Now here is this PERMANENT orange light on the dash that I must go to great efforts to ignore. It appears that cars (with the Prius in the lead) are heading to the same situation that aircraft cockpits and nuclear control rooms are experiencing. Namely too many warnings, alarms, and indicators that confuse more than anything else. (There are more beeps codes and stuff for alerting the driver of every possible condition, yet it is still trivially easy to drain the Prius 12V battery with one mistake.) Every year some very strange symbol is added to the dash that requires a secret decoder sheet to figure out what it means (e.g. TMPS). Heaven forbid that the MFD reports the problem in clear English (or whatever language the driver wants.) I think this needs some attention. Am I alone in this?
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    This cries out for the Car Talk solution:
    Cover it with black electrical tape.
    Problem solved.
  3. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Aug 18 2007, 01:14 PM) [snapback]498361[/snapback]</div>
    To get your attention!
    Sorry to sound ignorant, but the 2001 has a permanent airbag light? That's dumb. The 05 has it come on for a few seconds when the car is started. Normal running conditions does not display this.
    Oh, how I loath TPMS. What a stupid system.
  4. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(oly_57mpg @ Aug 18 2007, 01:23 PM) [snapback]498365[/snapback]</div>
    The 2001 does not have this light. The 2007 does. The "AIGBAG" part of the light is always lit. The "ON" part of the light is what changes. Now why does this need my attention for every second of driving?
  5. msirach
    msirach Member
    321
    Southern Illinois
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Aug 18 2007, 12:14 PM) [snapback]498361[/snapback]</div>
    I have to think about where I'm at in regards to red/green.
    At a stop light, red is stop. Green is go.
    I work at a power plant and red is run, green is stopped for all equipment.
  6. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(Doc Willie @ Aug 18 2007, 01:16 PM) [snapback]498363[/snapback]</div>
    I'm looking for a vastly better solution than that.
  7. oly_57mpg
    360
    <div class='quotetop'>QUOTE(msirach @ Aug 18 2007, 01:45 PM) [snapback]498373[/snapback]</div>
    Uh, I really hope it isn't a nuclear plant. What's the reasoning for green means stop, red means a-go?
  8. hoop
    hoop On The South Texas Coast
    69
    middle of south Texas coast
    <div class='quotetop'>QUOTE(oly_57mpg @ Aug 18 2007, 01:05 PM) [snapback]498381[/snapback]</div>
    I work at a nuclear plant, red is for danger, equipment is operating. Green is safe, equipment is not running. :lol: If its glowing and blue, its too late for you and you wont have to worry about it!
  9. Tideland Prius
    16,589
    Well it's amber for a reason
    Red - Immediate Attention Required
    Amber/Orange - Caution
    technically, it's a caution light. I just don't know why we can't have an AIRBAG OFF light only. We don't need a AIRBAG ON one either.
  10. echase
    echase New Member
    227
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 18 2007, 10:35 PM) [snapback]498518[/snapback]</div>
    Airbags are dangerous for small people. I believe AIRBAG ON would be something to be more cautious of, AIRBAG OFF should be green, IMHO.
  11. AussieOwner
    AussieOwner Active Member
    1,091
    67
    Sydney, Australia
    Could be for some US regulation - same as why US cars don't have factory fitted EV buttons. My Aussie 2007 model only has a air bag warning light, and a symbol rather than the word, that lights up during the system startup check, then goes out after about 6 seconds.
  12. oly_57mpg
    360
    <div class='quotetop'>QUOTE(hoop @ Aug 18 2007, 10:10 PM) [snapback]498510[/snapback]</div>
    Ahhh! Right! Run. Not as in running equipment but as in run like hell. When I read the "if it's glowing and blue, it's too late for you" I _almost_ dropped my beer because I was laughing so hard.
    There are several vehicles that do this. The Honda Odyssey lights an amber caution when the airbag is turned off.
    When did Toyota make this change to force the airbag light on all the time? 07?
  13. fo0bar
    fo0bar Junior Member
    66
    Reno, NV
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Aug 18 2007, 10:51 AM) [snapback]498376[/snapback]</div>
    Completely disassemble the dash, desolder the orange LED, and solder a white or green LED in its place. It should only take you or I about 20 hours, but it would be "better" than electrical tape. B)
  14. patsparks
    10,664
    567
    Adelaide South Australia
    Move to Australia, we don't have that light, just one that goes off after a short time.
  15. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(patsparks @ Aug 19 2007, 07:52 AM) [snapback]498607[/snapback]</div>
    Now that's a solution I have not thought about.
    The Airbag lights are not Toyota's doing. This is entirely a US self inflicted pain. I can solve the local problem with tape or LED change or any number of other approaches. My worry is that regulations are starting to specify every single light on the dash, adding every possible indication in a certain color, and making car dashes more dangerous than safe. It really confused the new drivers to the car what all this stuff means and what to do......and the manual says to pay the dealer for everything.
    P.S. Operated a nuclear plant at sea. If there was a big problem, we could run........ but not very far.
  16. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    It's almost as annoying as the time they marked the 55mph with a red mark on US cars, because in 1973 (74?) the national speed limit was lowered to 55 to save fuel.
    It was idiotic to specially mark every speedometer of new cars. After all, they don't specially mark every other speed limit!
  17. qbee42
    3,079
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Aug 19 2007, 11:27 AM) [snapback]498648[/snapback]</div>
    But you did have plenty of cooling water.
