Need help quick with dash/error light
Discussion in 'Gen 2 Prius Main Forum' started by treehggr, Aug 23, 2007.
  1. treehggr
    treehggr New Member
    230
    I have a quick question about a dash/error light that came on this morning. Unfortunetly I do not have my owners manual here at work to look up the problem/error. The light is orange and if you have your headlights on it is the light right below and a little to the left of the headlight "on" indicator. It almost looks like a horseshoe with the open end facing upward with the bottom end looking jagged almost like water and an "!" in the middle. Please tell me this isn't something bad. :( Any help would be great as I have my manual at home, thanks.
  2. Tom_06
    Tom_06 Active Member
    609
    143
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(treehggr @ Aug 23 2007, 09:04 AM) [snapback]500943[/snapback]</div>
    From memory (my manual is out in the car) it sounds like the tire pressure warning. Check your tires.
    - Tom
  3. treehggr
    treehggr New Member
    230
    Thanks for the quick reply Tom. God I hope thats the case. A nice and easy fix.
    Would someone be able to confirm this?
  4. freke70
    freke70 Salesman
    93
    super secret
    he's right. it's the tire pressure monitor system.
  5. treehggr
    treehggr New Member
    230
    Awesome, I appreciate the help guys. Thanks a lot.
  6. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    I tried GoogleImages to find a picture of the warning but couldn't.
    Basically, the "horseshoe" is supposed to be a cut-away of the tire with the tread on the bottom.
    This warning is tripped when one of the tires drops pressure by 25% since the sensor was last reset/calibrated.
    For the record, you should inflate the low tire back to its previous pressure; lowering the other three doesn't work well. :D
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Aug 23 2007, 09:47 AM) [snapback]501049[/snapback]</div>
    Here is one that's close:
    <div align="left">[​IMG]</div>
