TV has mind of its own
Discussion in 'Fred's House of Pancakes' started by hycamguy07, Aug 23, 2007.
  1. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    Ok for the last two months I/we would turn off the TV & cable box and go to bed. I would wake up hearing voices and do my best groggy tactical moves with my side arm down the hall only to find the damm TV on and the cable box on too.
    I would turn it off and return to bed. the next day I would come home and find the TV and the cable bo on and the TV at full vol.?
    I turned them off and they stay off while Im in the room. Well last night we are sitting there with guests and the TV clicks on then the cable box turns on and the TV turns its self up to 100 on the vol..??
    I grab the remote and turn the TV back down and then off, I then emptied the batteries out of the remotes, in case one of them is going bad.
    10 mins later only the TV comes on and its at 100 on the vol.
    I got up and tried to turn it off but it wouldnt...... So I pulled the plug and it shut off... :angry:
    Any ideas????? :huh:
  2. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    Shoot it with your sidearm; it's obviously an intruder! :lol:
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Check the neighbors, they may have the same brand of TV, and same cable box (being from the same cable company) with a universal remote with some great range. I'm reminded of the scene from Grumpy Old Men (or was it the sequel... can't remember) where one of them stood outside the window of the other guys house and changed the channels on his TV for the fun of it.
  4. echase
    echase New Member
    227
    Run, do not walk to blockbuster, and rent "Pulse" immediately.
    Here's info, so you make sure you are getting the 1988 version, not any of the newer crapfests by the same name:
    IMDB: Pulse (1998)
    Also, make sure your Prius doesn't see this movie... wouldn't want it getting any ideas.
  5. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Obviously, it's possessed. Either that or you're losing it. Wasn't that helpful? :)
    Umm...I'd say it's time to call the TV repair shop. Something's fused or shorted out. A liberal application of contact cleaner may do the trick.
  6. NoMoShocks
    1,292
    82
    Camas, WA
    What type of equipment, brand name of cable box and TV?
    It does seem strange that they both come on.
    You will want to find out if the cable box has an IR Blaster to turn on other equipment.
    If the Cable Box is UHF remote, your neighbor could be opperating it, but why are they up in the middle of the night.
    Could a friend be pranking you? Anyone in your house with an learning IR remote could lean the codes for your remotes, and then from outside your house, turn them on in the middle of the night and watch your reaction.
  7. eagle33199
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(hyo silver @ Aug 23 2007, 04:00 PM) [snapback]501204[/snapback]</div>
    That would be my guess if it was one or the other... But to have both the TV and the cable box turning themselves on... Doesn't sound like a fuse or short unless one can turn the other on, which you generally only see done through remotes.
  8. TheForce
    3,461
    537
    Wheelersburg, Ohio
    One of your neighbors may have gotten one of these Ninja remotes and amplified the IR for a long range TV snipe.
    http://www.thinkgeek.com/gadgets/electronic/884f/
    What I would do is keep your TV plugged in to make sure it will come on again by its self. When It does come on cover the IR sensor on the TV with a few layers of electrical tape. It it stops coming on by its self someone is sniping your TV. :D
    To find out where this sniper is at use a video camera at night pointed at your windows. The camera will be able to see the IR and you can start tracking down the culprit and prank them back.
  9. koa
    koa Active Member
    980
    45
    Hawaii
    They did say they would be baaaaack.
    If they aren't back, try taking the batteries out of the remotes (TV and cable) and see if the problem goes away. Then you will know if its a faulty remote or coming from the outside. Or they actually are back.
    I just saw you did take the batteries out. Try asking your closest neighbor to borrow their remote and see it it works on your stuff. Ask if they are having a similar problem in case someone is pranking the whole neighborhood.
  10. NoMoShocks
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(hyo silver @ Aug 23 2007, 02:00 PM) [snapback]501204[/snapback]</div>
    If your TV or Cable box has any contacts in it, replace that obsolete set.
    Seriously though, most likely thing is you are being pranked. I would plug your TV and Cable box into a power strip with a switch on it and just turn off the power strip each night before you go to bed. Then turn it on when you wake up in the morning. The TV might take a little longer to come on if you try to rurn it on right after you power up the power stip, but after two or three minutes, it would be ready to start instantly.
    Actually, you might need to leave the cable box plugged in if it does a nighly check in with the cable company, but just unplugging the TV at night will bore the pranker and he will move on to another house.
  11. hycamguy07
    2,707
    Central Florida
    Its a Magnavox 35" and the cable box is a sientific atlanta (DVR recorder) the cable runs in to it and it can record at any time, ie it turns on to record then turns off. However it does not turn on the tv. I also noticed the DVD player does not have any issues.... :mellow:
    I unhooked the cable box and the tv still turns its self on.. only now you get white noise! (dam horror movies) :unsure:
    It turns on then the volume automaticly turns its self up from 0-60 then just cruises up to 100.
    I guess its time for tv repair?.... its only 2 yrs old, & yes the warranty is out of date.. :rolleyes:
    Airport, I remember back in 1987 I was on a vol. fire dept and we had a manniquin, that we used for showing how our bunker gear was worn to the elementry students. Well one night a police officer stopped in the use the bathroom and on his way out, he realized that the front door was open and out of the coner of his eye he saw the dummy... well lets say two shots where fired and the officer had to change his shorts and the police dept. had to replace a dummy... :lol: :lol: :lol:
  12. echase
    echase New Member
    227
    Now unhook the TV and plug in the cable box. If the cable box has a mind of it's own as well then the problem is not the TV.
  13. Dr Ed
    Dr Ed New Member
    188
    Is there a cell phone near the TV when it happens? I have a touch-control table lamp next to my bed. If I have my cell phone within a foot of the lamp the lamp will come on by itself 2 or 3 times during the night. Placing the phone across the room during the night eliminated the phantom lamp activity.
  14. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    It is actually quite likely that you have an unlicensed Ham radio operator in the neighborhood...
    Our next door neighbor is not licensed, and he has a tendency to do side-band skipping, cranking up the power/frequency, and has caused a few interesting phenomena at our house.
    Of course, we just go over, pound on his door, and tell him to knock it off :)
  15. hycamguy07
    2,707
    Central Florida
    Ok its just the TV. No cell phone near the TV. I plugged the TV in and 30 mins later white noise turned the set off and poof it turned right back on.
    the cable box is remaining off for now.. I live on 1.5 acres the nearest nieghbor is 1000' from my property line.
  16. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(hycamguy07 @ Aug 24 2007, 09:09 AM) [snapback]501517[/snapback]</div>
    When I lived in rural Minnesota, my nearest neighbor was a half-mile away.
    Trucks driving by, using their CB radios, would turn on/up my touchlamp.
    You might also check for a timer setting on the TV... one of the shirttail relatives gave our boys a TV because it was "possessed by a demon"... the timer had been set, and every day it would turn on and go to a specific channel.
    However, with the volume control increasing, I'm sticking by my theory of illegal radio waves. You don't have to be close to them, sometimes, depending on what they are doing.
  17. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Hycamguy07
    Have you installed those energy saver flourescent light bulbs in your lamps recently? Believe it or not those bulbs can play havoc with your TV remote signals! Flourescent bulbs pulsate if you look closely. Or you may not see the pulsation. It may as fast as 60 times a second.
    I was in a hotel room years ago and the TV changed channels be itself. I thought the room was haunted.
    I know it sounds a little weird, but its worth a try.
    Marvin
