What kind of gas do you use for your prius?
Discussion in 'Gen 2 Prius Main Forum' started by bluemoonseller, Sep 6, 2007.
  1. bluemoonseller
    bluemoonseller Junior Member
    26
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Regular. Premium offers absolutely no advantages amd may, in fact, be detrimental.
  3. SureValla
    SureValla Member
    590
    Shelton, CT
    <div class='quotetop'>QUOTE(lenjack @ Sep 6 2007, 09:05 PM) [snapback]508240[/snapback]</div>
    try to find one without ethanol if you can, it hurts mpg
  4. patsparks
    10,664
    567
    Adelaide South Australia
    I use only E10. I'd rather use a renewable fuel as much as I can. I think using carbon which has been captured from the atmosphere means I am contributing slightly less carbon to the environment. I think this is more important than the number on my display.
    I haven't noticed an increase in fuel consumption on E10, maybe if I switch to standard petrol I might.
    E10 is 3c per litre cheaper than straight petrol which is due to lower duty on it.
  5. darlenegalik
    darlenegalik New Member
    30
    <div class='quotetop'>QUOTE(SureValla @ Sep 6 2007, 09:06 PM) [snapback]508242[/snapback]</div>
    I always use E10 - because I support renewable fuels - and I still get 55 MPG in my Prius. If that's a sacrifice, I'll take it.
    :lol:
  6. Tideland Prius
    16,504
    regular. E10 if I head down to the States.
  7. arolf
    arolf New Member
    why does E10 lower the MPG?
  8. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Regular. 87 octane. I think, but I'm not sure, that it's always E10. I think E10 may be the only kind of regular I can get around here (NY)?
  9. patsparks
    10,664
    567
    <div class='quotetop'>QUOTE(arolf @ Sep 7 2007, 01:20 PM) [snapback]508357[/snapback]</div>
    Ethanol has a lower energy density than petrol
    Energy density of Ethanol = 24 MJ/litre
    Energy density of petrol = 34.6MJ/litre
    Energy density of E10 = 28.06MJ/litre
    From http://en.wikipedia.org/wiki/Energy_density
    I have my doubts about these figures as they indicate ethanol has negative energy when added to petrol??
    This may be more acurate
    Ethanol = 84,600BTU/Gallon
    Petrol = 125,000BTU/Gallon
    E10 = 120,900BTU/Gallon
    Less than 4% less energy in E10 than in petrol
    From http://en.wikipedia.org/wiki/Gasoline
  10. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    The cheapest 87 octane I can find- 64K miles and runs perfect w/o any troubles.
