Who built the motor?
Discussion in 'Gen 2 Prius Technical Discussion' started by bredekamp, Sep 7, 2007.
  1. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    Hi all,
    I was wondering, who makes the electric motors used in the Prius? I have Mitsubishi Heavy Industries in my head for some reason. Please correct me if you know.
    Thanks
  2. jk450
    jk450 New Member
    Toshiba makes the motors. The transaxle itself is made by Aisin Seiki for Gen I, Toyota for Gen II.
    Mitsubishi makes some inverter components.
  3. bredekamp
    bredekamp Member
    569
    <div class='quotetop'>QUOTE(jk450 @ Sep 8 2007, 12:30 AM) [snapback]508764[/snapback]</div>
    Cool. Thanks :)
  4. bredekamp
    bredekamp Member
    569
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(jk450 @ Sep 7 2007, 06:30 PM) [snapback]508764[/snapback]</div>
    Where did you get that info?
    The reason I ask is that Toyota bought and specified all the motor winding machines for MG1 and MG2 as part of their normal practice to make all the major components of the Prius in house. The inverter IBGTs which are the core of the inverter are also made by Toyota with just some of the more generic inverter components supplied by outside suppliers.
  6. jk450
    jk450 New Member
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Sep 9 2007, 09:19 AM) [snapback]509486[/snapback]</div>
    That's not their "normal practice". Toyota goes back and forth on this quite often. For example, Aisin-Seiki made the 1997-2003 Prius transaxles, Toyota made (and makes) the 2004-2008 Prius transaxles. Aisin-Seiki is making the Camry transaxles. Many "major components" are not made in-house.
    Toyota does have a stake in some of the suppliers - Denso, Panasonic, Aisin - which leads some to claim that Toyota "owns" those companies. It ain't so. Corporate cross-ownership is quite complex in Japan.
    Toyota does make more components in-house than the average OEM, but the don't make 'em all.
    Yes, that's correct.
    It's a bit more complex than that.
    Bonus question: Take a long look at an inverter for a Camry, Altima, GS450h, or LS600hL. See if you can determine who made it.
  7. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(jk450 @ Sep 9 2007, 02:02 PM) [snapback]509632[/snapback]</div>
    I am still curious about the first question, where did you get you info for the motor? My reference is the book "The Prius-That Shook the World". Specifically in chapter seven it describes the installation of the high volume motor winding machines in the Honsha plant under the supervision of Ken Tanoue and Takaaki Ikeda. Has this changed? In the same book, Chapter 8 covers the Hirose plant design and fabrication of the inverter, which is where I get most (but not all) of my inverter info. If you have a later or more accurate source of info, I am all ears.
  8. jk450
    jk450 New Member
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Sep 9 2007, 08:10 PM) [snapback]509770[/snapback]</div>
    The book you reference describes the 1997-2000 Prius. It's accurate for that model. Your inverter info is also for that model. Yes, my source is later, and is in reference to the Gen II. You can take apart any inverter and find out who makes most of the components.
    Where did I get my information on the motor? Wish I could tell you, but that would not be considerate to the source. Feel free to disregard it, and don't expect Hitachi to confirm that they make that motor.
    Here's another production hybrid transaxle that they will admit to making, however:
    http://www.hitachi-hap.com/products/Motors/HEVTM/index.html
  9. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(jk450 @ Sep 10 2007, 02:17 AM) [snapback]509913[/snapback]</div>
    The last thing I want to disregard is the truth of the matter. However, I also do not want to put complete faith in info from the internet that results in a dead end. All useful information and clues are appreciated. (Understand promises must be kept, even if frustrating.) Thanks for what you can provide.
