Solar panels Up and running
Discussion in 'Environmental Discussion' started by Tadashi, Sep 9, 2007.
  1. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    I also got the Sunny WebBox option so I can keep track of my system. You can see some examples from here.
    So far for a 6.48kw system I am averaging (for the last 5 days) 20 kwh per day with a peak of 27.62 kwh for a sunny day and 21.35 for an overcast day. We get about 12.7 hours of light from sunrise to sunset which equates to about 4.3 hours of usable light.
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    Man. You beat me.
    I'm still waiting for SDG&E to give me "permission" to turn it on. I finally called them on Friday but haven't heard back.
    I'm still sitting on the bill from Borrego Solar because my system isn't on yet and I don't pay until it's on. They're the ones that should be after SDG&E to get my permission.
    I guess you beat me because of the delays in my having to upgrade my electrical system to 125 AMPS.
    Congrats.
  3. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    hahaha I bet I was driving Dave at Earth Solar Group nuts. I was asking if I could turn it on every other day after they completed the installation. It took about a week to get the Elec guy to connect it to the house and the power company to reprogram my meter.
    125v? What was it before? I thought it was suppose to be 110v but the contractor said the voltage runs high in this area (125ish). So I guess I was lucky in that respect.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I think she means 125 AMPs
  5. Godiva
    10,339
    <div class='quotetop'>QUOTE(Tadashi @ Sep 9 2007, 11:08 AM) [snapback]509550[/snapback]</div>
    There's the rub.
    It was 60. And no one told me. Borrego Solar knew it was 60 (probably from the start) but they certainly knew after SDG&E came out to review the project and faxed THEM a paper saying it needed to be upgraded to 125. They didn't tell me and kept working until the final inspection....which failed.
    I made them pay half of the upgrade the inspector demanded. He demanded 125 because of the size of my inverter, not how many panels I had on the roof. So even if I had 110 I still would have had to upgrade.
    Morons.
    Well, they paid $900 for keeping their mouths shut. If they had told me upfront I either would have paid the entire thing, or I never would have started the project. I guess they were afraid they would lose a sale. So their deception cost them $900.
    And a project that was supposed to take 3 days has now passed the 5th week and is going on 6. And it still isn't ON.
    BTW I didn't get the webthing for my inverter. If I want to see what it's doing, I just walk outside and look. Of course....it isn't doing ANYTHING right now.
  6. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Two reasons for getting the web thingie - my OCD :D and since I will be deploying for 15-mo soon I wanted to be able to keep tabs on the system.
    I just figured out how to setup public pages for all to see. The revenue is a little off since they figured it at 0.57 EUR per kwh. I set it to $0.14 USD but it does not recalculate the amount (at least I have not figured out how yet).
    Fixed links:
    Overview
    Daily report
    Monthly report
    Power
    Yield
  7. Godiva
    10,339
    <div class='quotetop'>QUOTE(efusco @ Sep 9 2007, 11:30 AM) [snapback]509565[/snapback]</div>
    Yes. Amps. I keep getting the volts and amps mixed up. Please don't review the water analogy. Just accpet that I'm never going to remember and keep getting them switched. Just watch the numbers and ignore everything else.
    I had 60. Now I have 125. And my PV system still isn't on. And don't hire Borrego Solar. There's the highpoints.
    <div class='quotetop'>QUOTE(Tadashi @ Sep 9 2007, 02:22 PM) [snapback]509659[/snapback]</div>
    Ah. Well, then it makes sense if you want to keep track long distance. I rarely go anywhere so I can just go outside and look.
  8. burritos
    burritos Senior Member
    4,946
    253
    <div class='quotetop'>QUOTE(Tadashi @ Sep 9 2007, 09:58 AM) [snapback]509516[/snapback]</div>
    WOW! That's a lot of watts. I'm jealous.May I ask what you paid?
  9. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(Tadashi @ Sep 9 2007, 08:58 AM) [snapback]509516[/snapback]</div>
    Not to be picky, mate, but both of those values are above 20. Did you mean that your best overcast day netted 21 kWh?
  10. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    No that was just a running average of the data I took before I hooked my system up to the web box. Click the links below in my signature to see the last two days of power. The 30 kwh day was partially cloudy and the 24 kwh day we had a rain storm in the middle of the day.
    The system cost $40k. Unfortunately, I live outside of the area for the $12k rebate, but still get a $4k Federal. I am hoping to break even in 10 yrs.
    Edit: Sorry the above link was to the main acct not the public pages. The two below should work now. For some reason it showed all the power generated prior to the web box install as being in 2000 and 2004. I am not sure how to fix.
  11. Godiva
    10,339
    So far my system is generating.....0 kwh.
    But I know what the hangup is.
    SDG&E has been out twice...to my fenced yard with the locked gate and the dog running loose.
    Uh....DUH.
    So they're coming out tomorrow at 3:30pm and a representative from Borrego Solar is going to be there to explain exactly how Borrego Solar is going to relocate the shutoff box so SDG&E has 24/7 access without getting bit. Should be very entertaining.
  12. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    hahaha they could not just make a reverse dog run and run an interior chain link fence around the inside of your yard to the shutoff box? Luckily they put all my stuff on the outside corner of my house so no need to go into my backyard. However, even if they did they would get a severe lick/droolin' from my jack russell. :p
    So how did the meeting go?
    ooooo I just figured out how to have my solar panels email me with a daily status report. hehehe Heaven forbid I should have to walk around the corner to look at the meter. :D
  13. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
  14. bulldog
    bulldog Member
    224
    CA
    Very cool stuff. Thx for putting up the links to see power generated. Really good to see actual results for these panels.
    How many square meters of solar panels do you have?
  15. bulldog
    bulldog Member
    224
    CA
  16. Godiva
    10,339
    <div class='quotetop'>QUOTE(Tadashi @ Sep 11 2007, 08:04 PM) [snapback]510938[/snapback]</div>
    Well, apparently Borrego Solar is NOT SDG&E Ken's favorite solar company. They've apparently done this before. But they are also not the only solar company that does this. Ken is their net metering guy and has the final approval before the system can be turned on. He did not approve.
    He gave them a polite butt reaming. The shaking of the head and "you guys know the rules, we've been through this before." He presented several scenarios. All involve SDG&E having 24/7 access to my meter and shutoff. Basically I have to give them an easement.
    #1. Put a fence across the middle of my back yard to keep the dog away from the current location. Probably 300 sq ft or more of easement involved and a butt ugly division in the middle of my landscaping and brick patio. Not to mention no dog to ensure security against breakins for that area. A window in that area was the break in entry point for a robbery before I got my first dog. Cheapest solution. Borrego Solar really likes this and doesn't understand why I object. Detracts from property values.
    #2. Relocate meter and shut off to where the current gas meter is. This would involve an easement of about 100-150 sq feet and cut off the back corner of my back yard and a substantial corner of a second brick patio and a corner where I have a fountain set up. SDG&E likes this best because they can read the gas and electric together. Again, I object. Plus starting next year they're converting all of the gas and electric meters to radio controled reading so I find this unnecessary too. Detracts from property values.
    #3. Relocate meter and shut off to the northwest corner of my garage next to a back gate to the alley. Replace lock in gate to SDG&E approved lock for access. I build a second gate at the next fencepost in to isolate the area and keep the dog out. Only about 40 sq ft and can't be seen from the yard so has no impact on my landscaping or views. This is the only option I will approve. No impact on property values.
    I also won't pay one penny for any work done.
    I also will not allow Borrego Solar or any of their representatives to work on my property without my direct supervision.
    They left yesterday saying they were going to go back to the office and "talk over the options". They said they'd get back to me. Today? No message on the answering machine. No e-mail. When SDG&E Ken left he said to me "would you like to be cc'd on every e-mail?" I said "yes, and I want to have the number of every permit that is pulled."
    If they do not contact me I'll be contacting them. They have until tomorrow because they don't work on Fridays. I will inform them their services are no longer required. I will be hiring an independent contractor to provide option #3 and after it is approved and my system is up and running, I will deduct all expenses from the final payment they are owed.
    If I get any grief, they can take me to court. My first two witnesses will be SDG&E netmetering guy Ken and City Inspector Dale. Then I'll call Michael Turko, our local news "bad business fraud investigator". I really think the practices of the solar market need to make the evening news.
  17. Godiva
    10,339
  18. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Wow sorry to hear about the snafu. That is odd where your meter is placed. How did the meter guy check it before without the dog chasing him? It seems all the meters around here are either located in the easement between house backyards or on the front corner of the houses.
    The relocation of the meter and shut off is not that difficult and should not take that long. My solar company ran steel conduit from the rear of the house where the panels are to the front of the house where the meter is and shut off. I think it took them all of an hour. However, it has to be a certified high voltage electrician. My solar company took a week trying to locate one in my area to do some of the work.
    Hindsight being 20/20 I would have contacted the net metering guy in the area to see what he says about the solar companies. I think I just lucked out. I was worried during the project because there are so many instances things could go wrong.
  19. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
  20. Godiva
    10,339
    <div class='quotetop'>QUOTE(Tadashi @ Sep 12 2007, 09:30 PM) [snapback]511691[/snapback]</div>
    Well if it isn't the original location when the house was built in 1922 it's the location when the house was remodeled in 1949. The reader goes on the balcony of the apartment next door and reads both the electrical meter on the house and the gas meter on the garage will a little telescope. Mine is not the only house in San Diego which SDG&E does this. They've been doing it for the 20 years I've lived there. Even when I didn't have dogs. But now with the PV they are a lot fussier. The SDG&E guy told a story about drug dealers in Clairemont who had PV installed and grew marijuana with hydroponics and grow lights at night. No one had a clue because no one knew how much electricity they were using.
    Well I have a detached garage. And the original circuit breaker box is in a closet in the kitchen. So they'll have to run conduit from the attic of the house to the garage and then to the northwest corner of the garage. While the side of the kitchen where the meter and shutoff currently are will be cleaner to look at with all of that removed, I'll have many holes drilled in my siding that will have to be patched and painted over, plus a hole straight up in the soffit through the roof. I just had the roof done in 2001 with 50 year rated architectural shingles. So the roof is going to have to be patched. Patched all over. I am pissed because if the meter had been corrected relocated when the service was switched from 60 to 125 NONE of it would have happened.
    I would advise anyone thinking of doing this to yes, contact the net metering guy to get any info. I would also get him and the City Inspector out to look at your project before any work is done at all. They can say up front what they want and you can make sure that that is what they get when the work is done. None of this trying to fix it after it's WRONG.
    Found out from my Chiropractor today that she has friends that had grief from Borrego Solar too. And she says NEVER buy Pella Windows. She went through hell with them.
