Corolla wheels for Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Doc Willie, Sep 11, 2007.
  1. Doc Willie
    1,717
    144
    Out there, somewhere
    I am considering getting another set of wheels to mount winter tires on for my 007 Prius. I have read that Corolla wheels will work. Are there any years that we know will fit? or All of them. And will they take 195/60R tires?
  2. Doc Willie
    1,717
    144
  3. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Not sure about Corolla, but I have heard of using Matrix alloys, which should be same as corolla. Tire rack should be able to tell you.
  4. subarutoo
    1,213
    Chatsworth, CA
  5. Doc Willie
    1,717
    144
    <div class='quotetop'>QUOTE(subarutoo @ Sep 12 2007, 05:24 PM) [snapback]511558[/snapback]</div>
    Don't see nuthin' there that answers the question. I wanna be able to walk into a junkyard and ask for 19xx - 2xxx Corolla wheels.
  6. Doc Willie
    1,717
    144
  7. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Here is the response mrv gave me on PriusOnline last winter when I posed a similar question. I was looking for wheels for snows, but ended up getting a set of original Prius allows cheap on eBay.
    PA P
    You could try giving Ryan at tirefactory.net a call, see if he still has the 15x6" 5x100 steel wheels available (as seen on http://www.tirefactory.net/Specials.htm ) When I had bought some from him last year, they were $60 each but with free shipping. Last I checked he was still offering a discount on Nokian tires to people who identified themselves from a Prius group.
    Ryan
    Tire Factory, Inc
    [email protected]
    800-576-1009
    (also, note that this is the same wheel as the Matrix and the newer (2003-?) redesign of the Corolla, so even some scrapyards may be a source of inexpensive steel wheels...)
  8. PA Prius
    762
    251
    SE Pennsylvania
    PA P
    Ryan
    Tire Factory, Inc
    [email protected]
    800-576-1009
  9. Tideland Prius
    16,558
    if you're talking about 15" then...
    the 9th Gen (03-08) will work. The steelies are mounted with 185/65R15 and the alloys (on the S and LE models) are mounted on 195/60R15 so either one should work (esp. since the wheel lugs are the same design I believe).
    Older Corollas used 14" steelies with wheel covers.
  10. Tideland Prius
    16,558
