Got a dirty key fob? No problem!
Discussion in 'Gen 2 Prius Technical Discussion' started by EarthFriendly, Sep 17, 2007.
  1. EarthFriendly
    EarthFriendly New Member
    Well, I mowed the lawn after driving our 07 Touring, and I left the key fob in the pocket of my sweatpants. My wife was so adamant about doing laundry that she washed my sweatpants without checking the pockets. I am happy to let you all know that a cycle on warm/delicate setting does wonders for getting the key fob "really" spotlessly clean without impairing its function. Our Prius unlocked and started up without hesitation.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    I think I would open it up and make sure it was completely dry inside by leaving it in a warm place overnight. Just to be sure no moisture is in it.
  3. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    <div class='quotetop'>QUOTE(patsparks @ Sep 17 2007, 06:15 PM) [snapback]514028[/snapback]</div>
    That's good advice. And for the OP, if this happens again to any electronic device you should do this before activating it or turning it on.
  4. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Shoot, why not just open it up before washing it.
    Make sure the electronics are equally as spotless. :D
  5. patsparks
    10,664
    567
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Sep 18 2007, 12:44 PM) [snapback]514106[/snapback]</div>
    haha I think you missed the point. haha that much dirty stuff in the washing machine could cause staining of clothing!! :lol:
    Seriously I have saved a couple of phones by doing this, open up and dry out before pressing any buttons.
  6. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    The fob has a rubber gasket for the battery compartment and the battery compartment cover is screwed down tightly. I believe that as long as it is in good physical shape, it is water proof. I wouldn't push my luck with it, but I wouldn't get overly concerned if it took a dunk now and then.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I've accidently washed USB flashdrives as well. I let them sit on a sunny window jambliner all day, and they have always worked fine after
  8. AlbertoC67
    AlbertoC67 Junior Member
    48
    Lombardy - Italy
    Does anybody know the frequency of the electromagnetic waves of the smart entry & start system?
    May that system cause danger for health?
    Sorry for the stupid questions.
  9. n8kwx
    n8kwx Member
    236
    Arlington Heights, IL - NW Chicago Suburb
    <div class='quotetop'>QUOTE(AlbertoC67 @ Sep 24 2007, 03:06 PM) [snapback]517025[/snapback]</div>
    Have you been sitting under the Radio Vatican antennas too long? :)
    The key fobs transmit on either 314 or 433 MHz. They are VERY low power. Your cell phone is about a 1000x (yes, one thousand) times more powerful.
    Don't worry about it!
  10. donee
    donee New Member
    2,956
    198
    Chicagoland
    Speaking of Radio Vatican and their 150 KW Transmitter. Nearly perfect DRM (Digital Shortwave) signal every night. from 6 to 6:45 pm here near Chicago. Truely remarkable. The signal looks like its been through the clothes dryer, but it decodes very well all the time.
  11. AlbertoC67
    48
    Lombardy - Italy
    <div class='quotetop'>QUOTE(n8kwx @ Sep 24 2007, 11:38 PM) [snapback]517079[/snapback]</div>
    Thanks for your reply.
    Good joke about the radio Vatican :lol:
    I see that new has crossed the ocean.
    Here in Italy there's a lot of confusion about electromagnetic waves, one day they are terrible... the next they are not at all...
    Ciao
  12. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    My 3 yo daughter dropped my cell phone into a pan that had been used to roast a chicken which was soaking in the sink. I thought it was a gonner for sure. Much to my surprise after opening it up and letting it dry out for a day, it worked fine. Just a little greasy!
  13. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Next time, batter your cell phone before deep-frying and it will be DELICIOUS! I can't guarantee it will still work though.
  14. AlbertoC67
    48
    Lombardy - Italy
    Key fob
    Sorry for another question in my english...
    So, the key fob is the transmitter and the car is the receiver, am I wrong?
    What kind of batteries are used in the key fob?
    I knew the key fob must be put inside a groove on the instrument panel of the car, is it still right?
    Only Prius use this system instead of the traditional keys in U.S.A.?
  15. hill
    8,794
    Hmmm. Most cel phones transmit less than 50 miliwatts on 2.4 gig's. A thousandth of 50 miliwatts would be less than a half of a millionth of a watt. You'd have to be next to the car to remotely open it.
    To the OP, was it an SKS? . . . or a regular fob.
  16. hermiod
    hermiod New Member
    Crystal Lake, IL
    Off by a factor of 100 or so
    I'm surprised n8kwx let this go...
    I think your math is off by a few decimal places. A milliwatt is 1/1000 of a Watt. A thousandth of 50 milliwatts would be 50 millionths of a Watt, not less than half a millionth of a Watt. Cell phones have been legally allowed to transmit with up to three Watts of transmit power - although most phones these days push out a few hundred milliwatts at most. A key fob remote is likely to be designed to be in the single-digit milliwatt power range in order to get a long life out of its battery, so a 3W bagphone (they're still available, for long haul truckers and others who venture into remote areas) could easily push out a thousand times the power of a key fob remote.
    On top of that, there are two parts to a remote control system - the transmitter and the receiver - if the receiver is sensitive enough it could certainly pick up and decode a sub-milliwatt signal. If I remember correctly, the rule of thumb is that the strength of a radio signal drops off proportional to the square of the distance from the transmitting antenna - so that tiny signal could actually be stronger at the car's receiver than even a broadcast radio station signal, because car remotes are usually used a comparatively short distance from the car, compared to a radio station that could be many tens of miles away.
    Now, I just wish my factory Mercedes remote worked more than 20 feet from the car. It's a bit dismal, especially since I got used to my previous car's aftermarket remote starter with its more than 500 foot range.
    No cellular phones operate in the 2.4GHz band - that band is for unlicensed use for such things as 802.11b/g wireless networks, cordless phones, microwave ovens, bluetooth devices etc... Common cellular phone bands include 850MHz, 900MHz, 1800MHz, and 1900MHz.
    Anyhow, the advice I've always heard and used myself for electronic devices that get wet is to remove the battery as soon as possible, open the device up if possible to air it out, and dry it in a warm area. Removing the battery helps prevent damage from liquid short circuits and prevents electrolytic corrosion from taking place - with the addition of water, the battery power can actually cause electronics to corrode - removing the battery can help stop that from happening.
    About ten years ago I had to wash two office phones in the sink with a scrub brush - they smelled really really bad - it was that or throw them away. I dried them in my mother's convection oven set at 150 degrees F for two hours and they worked great for years, right until I replaced that whole phone system. I'm not sure my mother was too thrilled to see a telephone revolving in her convection oven though.
  17. patsparks
    10,664
    567
    So we wont get cancer in our pelvis from having the remote in our pocket? Cool!!
  18. AlbertoC67
    48
    Lombardy - Italy
    Re: Got a dirty key fob? No problem!
    I red on a website that the cell phones transmit from 900 to 1800 Mhz.
    The power of cell phones transmissions is surely more powerful, but what's the power of the key fob? :typing:
    Thanks
  19. bwilson4web
    16,197
  20. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    that wouldn't work for mine! i'm probably one of the few here who's rubber has cracked and disconnect from the plastic casing.
