200 psi !?!
Discussion in 'Gen 2 Prius Main Forum' started by PA Prius, Sep 29, 2007.
  1. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    In today's newspaper column Click and Clack talked about the dangers of under-inflated tires. They also said that over inflating 10-15 psi is generally not a problem except for the harsher ride, AND that that a tire's burst pressure is around 200 psi. No, don't try it.
    PA P
  2. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I run at 42-40. I dont think the ride is that bad, even on my dirt road. Now, with the OEM tires getting some wear on them at this point, the ride is loud. I'm going to have to replace them before winter sets in, and I'm seriously looking at the Michelin's. At this point though, anything would be quieter.
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Rangerdavid @ Sep 29 2007, 06:13 PM) [snapback]519243[/snapback]</div>
    If there there is a Costco within driving distance from you, the $60 off a set of four Michelin tires promotion will be in effect from October 8 through October 28.
  4. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Sep 29 2007, 08:31 PM) [snapback]519254[/snapback]</div>
    Read the fine print. Only on select models and none of the tires listed are anything I'd want on my Prius.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I've heard that all tires must be tested to a burst pressure 8 times that of the maximum sidewall pressure by industry requirement.
  6. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    With a friend who has a "trusted source inside the tire manufacturing industry", I was told 4 - 5 times the sidewall suggestion. Even that puts the burst level of a Prius tire around 175psi or so.
    With this new Click and Clack info, I don't mind so much running at 55/53.
  7. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Godiva @ Sep 29 2007, 06:56 PM) [snapback]519267[/snapback]</div>
    I did read the fine print before I posted.
    The offer is for a "set of 4 Michelin OR a set of 4 select BF Goodrich Tires." All Michelin tires are eligible for this discount. The select applies only to the BF Goodrich tires; all the models listed in the fine print are BF Goodrich models.
