TPM Sensors on winter snow tires on replacement alloy rims
Discussion in 'Gen 2 Prius Main Forum' started by chrisslondon, Sep 21, 2007.
  1. chrisslondon
    chrisslondon Junior Member
    Kingston, Ontario, Canada
    We are waiting on delivery of our new 2008 Prius which hopefully will arrive in late October though we are not holding our breath waiting. We use snow tires on our old Honda Civic and will do the same with the Prius. After shopping around I found alloy wheels and snow tires at a much better price than the Toyota dealership could even dream of selling alloy wheels and snow tires for. My question is about the Tire Pressure Monitor Sensors that the tire company will install in our snow tires on our replacement rims. Since the TPM sensors will have different ID numbers than the factory installed wheels and tires, is there a way that the tire company can reset the computor when the snow tires are installed for winter use and when the original tires go back on in the spring. I don't want to be paying the dealership twice a year for that service. Also, if I were to change the tires is it something that I could do myself.
    Thanks,
    Rob
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    <div class='quotetop'>QUOTE(chrisslondon @ Sep 21 2007, 06:26 PM) [snapback]515963[/snapback]</div>
    As far as I know, you have to take it into the dealer. I have heard it's about 50 USD to reprogram the TPMS for the different sensors. Plus the sensors coat $85 EACH. After considering it all, if I can find the wheels, I will mount them without the sensors, since I regularly check my tire pressure. The only downside is that another light will be on my dashboard. Will use the CarTalk fix on that (black electrical tape).
  3. chrisslondon
    <div class='quotetop'>QUOTE(Doc Willie @ Sep 30 2007, 05:45 PM) [snapback]519557[/snapback]</div>
    Thanks for the help Doc. I was wondering if it was a Canada Transport or other Government agency which required the sensors on 2008 but I am getting the impression that it is another feature of many new cars which won't get me in trouble with the law if I don't install TPM Sensors and program them into the car computer on my snow tires.
    Rob
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Leave the sensors off for the season. All you will get is the idiot light on the dash, which you just ignore until you have the standard tires put back on.
  5. JayGoldstein
    JayGoldstein Member
    120
    Winnipeg, Manitoba, Canada
    <div class='quotetop'>QUOTE(firepa63 @ Sep 30 2007, 05:01 PM) [snapback]519569[/snapback]</div>
    I second the motion. My winter tires are mounted on steel rims w/o the sensors. I expected that having the warning light constantly on would be major nuisance, but after a week or so, it was a non-issue.
    BTW, people have suggested covering the warning light with black tape. I didn't find it necessary, but it's an option.
  6. chrisslondon
    <div class='quotetop'>QUOTE(JayGoldstein @ Oct 1 2007, 05:43 PM) [snapback]519999[/snapback]</div>
    Thanks for the help. I think we will save the expense of 4 tire pressure monitors, put up with the warning light and keep an eye on the tire pressure. Keeping an eye on tire pressure would make my 93 year old father very proud that I would be doing something that he worked hard at teaching myself and my four siblings many years ago. He might even enjoy a spin in the car once we get it.
  7. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    My solution was to just junk the OE tires and put on Nokian WR all season tires. They are supposed to be as good as ice tires, yet they wear like normal tires and work well in summer as well.
    So I don't worry about changing wheels, TPMS, weather, etc. I just drive.
  8. Buckland
    Buckland New Member
    61
    Cobourg Ontario
    Re: TPM Sensors
    I have been running on snow tires this last winter without the sensors. I don't really want to pay the ridiculous cost of re-installing the stock summer tires and would like to do it my self with my new air ratchet. Is there anything I need to be aware of when re-installing the summer tires??
    Buck
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Re: TPM Sensors
    Buck
    Don't use the air ratchet to put the nuts back on. Use a torque wrench at the proper setting. Otherwise you run the risk of warping a brake rotor
    jay
  10. Buckland
    Buckland New Member
    61
    Cobourg Ontario
    Thanks Jayman, I'll do that.
    Buck
  11. Ozzyprv
    Ozzyprv New Member
    39
    Red Deer, AB - Canada
    So, what is the problem with installing the winter tires on the OE rims?
    That is what I did....any known problem with that?
  12. Buckland
    Buckland New Member
    61
    Cobourg Ontario
    Well, I took back my pneumatic impact wrench and bought a torque wrench in stead. It took all my power ( and I'm not a small guy) to undo the wheel nuts. Now I've found that the wheel is seized onto the hub. I'm afraid to hit it too hard with a hammer, but that's about all I can do at the moment. I have put some WD40 on it to loosen the rust. Is there anything else I can do?
    Buck
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Buck
    On both the FJ and the Prius, the very first time I took off the lugnuts they were fairly easy to loosen. I used a 24 inch breaker bar, and although the nuts "squeaked" coming off, no issues
    On the Prius, only one wheel was "stuck" after all the nuts were off. On the FJ, for some reason *all* the wheels were rusted to the flange. Making sure the vehicle was solidly supported, I just gave the tire a damn good kick.
    That taught it a lesson
    I'm guessing the liberal application of road deicing salt caused your trouble. Go easy on the wd-40 in case you get any on the brake rotor. Just make sure the Prius is solidly supported, and then with the tire off the ground, give a very firm kick
    You obviously don't want to try the kick with just the jack holding up the car. Otherwise the car could slip off the jack and you'd have damage
    I always put a dab of anti-seize compound (Locktite Nickel Grade) on the studs and smear a *very* light coating on the flange.
    Not sure if I mentioned this, but if you're using steel wheels, do *not* use the Toyota lugnuts that came with the aluminum wheels. I've found they dangerously loosen up. I went to Napa and got proper "acorn" or conical seat lugnuts, cost a whopping $20
    jay
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, at one time it was pretty common to take off the "all season" tires and slap on the snow tires, on the same rims. It's thought that repeated mounting/dismounting can damage the bead area of the tire, and the rim itself. You also run the risk that - sooner or later - some doofus won't properly balance the wheel and you'll have vibration
    I prefer steel wheels for winter. That way, the road salt doesn't have a chance to turn my nice looking alloy wheels into pieces of crap. I do know with the huge factory tires on my FJ, I'd hate to trust anything but a Hunter Road Force balancer, it's hard to balance such big tires
    You also have control of when to swap tires. If you have to have them mounted/dismounted, you have to make an appointment and hope you haven't underestimated the weather
  15. Buckland
    Buckland New Member
    61
    Cobourg Ontario
    Hey Jayman,
    I was very careful not to get WD40 on anything but where I wanted it to to, but the wheel just did not want to come off. Instead I took off each nut, one at a time and put some special goop I got from an old engineer. I've used the stuff before on stubborn nuts and it works like a charm. It allows the nuts to be tightened right up, but come off easily without loosening. The manual says to set the torque wrench to 75 foot pounds, but I'd be darned if I could get it to click. I was putting almost everything I had into it, but it just didn't want to click over. I have decided to leave it to the "experts" at the dealership to deal with them. When I get them back I'll prep them for next season. I'd like to be able to save myself some coin now that I'm retired.
    Buck
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Buck
    Nope, that doesn't sound right at all. Once you're used to what 75-80 lb ft "feels" like, you realize that it isn't a lot of torque. Maybe you have a bum torque wrench.
    Set it for some very low value, say 30-40 lb ft. If it doesn't click then, return it. If you live in a metropolitan area check the yellow pages for shops that calibrate torque wrenches.
    If you paid less than $50 for the torque wrench, it's cheaper to just return it or throw it away and get another one. Not worth snapping a stud or warping a rotor
    jay
  17. Buckland
    Buckland New Member
    61
    Cobourg Ontario
    Hey Jayman,
    I just came back from getting my snow tires taken off and the summers put back on at the dealer. For some reason I though it was going to be a lot more expensive, but it was only $20!! So took my torque wrench and floor jack back to the store where I bough it and saved almost $100!. Incidentally, I watched the mechanic remove my tires. He too had a bit of difficulty taking the snows off as they had become rusted to the hubs. But a good couple whacks with a big sledge and they came loose. I did note however that he re-mounted the summer tires with a pneumatic nut driver. I don't know if they can be calibrated to a certain torque or not, but he reefed them up pretty tight. I'll keep an eye on things and see how they go.
    Buck
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    Buck
    Geez I *hate* it when they use an impact gun to *tighten* wheel nuts! Yes, they might be using a special torque-limiting adapter
    Professional torque sticks, sockets, multipliers and extention bars - 10 PC (TIRE SERVICE-MASTER KIT) 1/2" DRIVE TORQUE EXTENSION BARS SET 65-75-80-90-100-110-120-130-140-150
    Of course, the real test will be at 2am somewhere in BFE with a flat tire. Let's hope you can get the nuts off
    jay
  19. Buckland
    Buckland New Member
    61
    Cobourg Ontario
    Jayman,
    You got that right! I had a heck of a time getting the nuts off to lubricate them. But what I did might save in in the long run. Incidentally, the flat indicator on the dash went out when the summers were re-installed.
    Thanks for your help.
    Buck
