I hate the smell of mildew in the morning ...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vic Doucette, Oct 9, 2007.
  1. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    For the last couple of mornings, I've noticed a whiff or three of mildew immediately after start-up. My car has been garaged since I bought it, and there was no rain in the area yesterday; it rained last night, but the car was dry from being inside the garage, of course.
    The smell goes away after a few moments, but returns the next morning.
    About 6,500 miles on the car, FWIW.
    Any ideas?
  2. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    <div class='quotetop'>QUOTE(Vic Doucette @ Oct 9 2007, 07:25 AM) [snapback]523040[/snapback]</div>
    If you use recirculation a lot, that may be the problem. I use it a lot and used to have that problem. Leave the windows open a little when it's parked to air it out and shut off recirculation when you don't need it.
  3. viking31
    viking31 Member
    515
    22
    West Central Florida
    Check your cabin air filter (it's right behind the bottom glove compartment; you will need to remove the bottom glove compartment but it is easy to do). I had the same problem with the mildew smell at startup too; especially after it rained and as in your case even if the car was garaged and dry. Turned out for me a critter (mouse??) started to build a nest on top of my cabin air filter.
    Rick
    #4 2006
  4. richard schumacher
    7,664
    1,046
    United States
    Ask your service shop to make sure that the A/C evaporator drain hole is not plugged.
    If you use recirc a lot it can help to run the heater for a minute just before parking the car to help dry out the evaporator.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
