Mileage difference with different drivers
Discussion in 'Gen 2 Prius Main Forum' started by jdbrown, Oct 16, 2007.
  1. jdbrown
    jdbrown New Member
    South Carolina
    I've noticed a few posts on related topic, but I thought I'd share my case.
    My wife and I share our Prius depending on who's turn it is for the school carpool. We've had the Prius since late June and I've noticed a very large difference in mileage at the end of the week depending on who is driving. When I drive it, I get 52-55 mpg without trying very hard, and that is mixed city/highway driving. I think if I tried a little harder I could get it up to 60 mpg, but I would probably be in the way of other cars frequently. When my wife drives it, she gets about 45-47 mpg. Interestingly, we both drive the same routes when we drive.
    Has anyone else experience that much variation when their spouse drives the Prius?
  2. Prius07Pkg4
    Prius07Pkg4 New Member
    <div class='quotetop'>QUOTE(scpilot @ Oct 16 2007, 07:04 PM) [snapback]526639[/snapback]</div>
    Yes, same here. With the Prius 2007 when I drive same route, I get between 54-58 (some time on phone mpg drop). When my wife drive she get 48-50 mpg. Also when I drive 2007 Sienna; I get 26-28 mpg 100% Freeway . When she drive; she get 20-22 mpg 100% Freeway.
  3. mjms2b
    mjms2b MJ Green
    349
    Socal
    pretty easy one actually. lead foot or jumb rabbit starts. Driving style makes all the difference, if you drive this car like other cars the mpg goes down big time.
  4. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Scpilot,
    Yep, I agree with MJGreen. You are more lead footed than your wife, and that is why you are getting better mileage.
    The source of the recommendation to not do quick acceleration with a standard car is the need to give the standard engine an extra squirt of gas to get the engine to ramp up the RPM quicker. This is called "enrichment". This is responsible for that black puff of smoke out the back of that beemer up ahead. Poorly burned gas, is poor fuel economy, however.
    The Prius does not have enrichment, it has a battery and a 60 hp electrical motor. So, the engine ramps up gradually in RPM, as the electric drive gives the torque at low speeds. Of course, flooring a Prius will not give good mileage either. But there is a fuel economy sweet spot for accelleration between 1/3 and 1/2 pedal depression up to the speed limit, then pull your foot all the way off the gas, and bring it back up to cruise power. Which is usually a little quicker than other cars in the morning, and about as quick as 80 % of cars in the evening. At least around here.
    So, at the optimum quickness, the extra gas used to get to speed quicker, is offset by the extra time cruising with the engine off, and the higher efficiency of the engine at higher loads, both accellerating, and while cruising charging the battery for part of the cruise.
    If you gradually accellerate, even if you keep it in electric, the mileage will be worse. Because the electricity needs to be replaced and unless you have a big hill to coast down, that costs gas. The Prius engine to wheels efficiency is better than than the engine to generator to battery to motor to wheels efficiency. Trying to stay in electric forces most of the energy to go through the latter (series hybrid) path.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yes differences in driving technique can and certainly do account for the differences.
    But I don't think we have enough data at hand to determine what it is about each of your techniques accounts for the difference. Rather than acceleration rate I think it's more likely that the difference is due to anticipation of stops. Does your wife stay on the gas and brake late at lights? Does she follow other cars closely? Does she run the AC colder than you? There are a lot of possible things.
  6. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Washington State, (Near Portland)
    I've driven a lot of automobiles in the last 30+ years. The Prius is by far the most sensitive (in terms of mileage) to driving technique of any automobile that I've ever driven. It is also the most fuel efficient automobile that I've ever driven.
    Keith :unsure:
  7. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    I typically get 10% better mileage than my wife in any vechile we drive. I noticed she drives with a 'choppy' right foot. In other words, she is constantly tapping the gas pedal and not being gentle with it. I always tell her to drive as if there is an egg under your right pedal. I don't think she understands. :)
  8. McShemp
    McShemp New Member
    371
    SA, TX
    <div class='quotetop'>QUOTE(MJGreen @ Oct 16 2007, 10:05 PM) [snapback]526660[/snapback]</div>
    While I agree that binary pedal operations are bad for FE, I wouldn't say driving a Prius like any other car causes poor FE. If a driver gets poor FE because of their style, it will be show up regardless of the vehicle.
    BTW - I have heard of Prius drivers driving "angry" and getting better than thier normal FE. When I say "angry," I mean preoccupied while driving, aggressive, or not caring about anything but getting to their destination (mad at a spouse, late for a meeting, etc).
  9. jdbrown
    jdbrown New Member
    South Carolina
    I think it is largely tied to our stopping technique, although I think she is running the A/C a lot more than I do as well. I frequently don't even use the A/C.
    I've done a bit of experimentation on my own and find that gentler accelerations give me a few mpg more than with the heavier acceleration. I try to time my accelerations with going down hills when possible.
    I am more consistent in maintaining speed than she is as well.
    The Prius has been a great car so far. I was skeptical at first, but have really enjoyed it and am having fun trying to get higher mileage. One of these days, I will get to drive it myself for an entire tank.
    <div class='quotetop'>QUOTE(efusco @ Oct 17 2007, 12:35 AM) [snapback]526701[/snapback]</div>
  10. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(scpilot @ Oct 26 2007, 07:15 PM) [snapback]530942[/snapback]</div>
    Don't count on it. The only time I've driven my wife's Highlander Hybrid a whole tank was through an ice storm on a cross-country trip to Colorado....got about 20mpg...
