Warning buzzing
Discussion in 'Gen 2 Prius Main Forum' started by pipspur, Oct 21, 2007.
  1. pipspur
    pipspur New Member
    Hello everyone
    About an hour ago (21:00 UK time) I started my Prius in the dark. I was driving down the road when suddenly what I think must be the warning buzzing sound started. There were no warning symbols so I pulled up at the side of the road and I started to check everything. Then I noticed that I had put the key into it's slot upside down. I turned off the car and put the key the right way up and started the car again but it was still buzzing though it was no longer buzzing the whole time now it was buzzing intermittently.
    Does anyone have any ideas about what I should do and if it was the keys being upside down that may have started this problem?
    Regards
    Pipspur
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    How in the world did you get it in upside down?
    Only thing I'd worry about is if you could have damaged the slot itself. Just suprised it ran or that you got it in the slot at all.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(efusco @ Oct 21 2007, 02:26 PM) [snapback]528546[/snapback]</div>
    There is no upside down the fob works either way. do not know about the buzzing but doubt that it has anything to do with the key fob.
  4. richard schumacher
    7,664
    1,046
    United States
    Where was your cell phone?
  5. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    The prius doesn't buzz if theres a problem. It beeps.
    Perhaps your referring to the brake pump hum? It may sound like a buzz of some sort.
  6. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    buzz or beep? i know there are differences in the way we relate across the pond ;) just want to be clear here.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    All doors closed properly including the hatch? Seatbelt on? Park brake off?
    Is it your keys against the dash?
  8. pipspur
    pipspur New Member
    <div class='quotetop'>QUOTE(patsparks @ Oct 22 2007, 09:43 AM) [snapback]528719[/snapback]</div>
    I have been to my local Toyota service centre this morning and they have discovered that it is my front parking sensor malfunctioning and it is will be fixed tomorrow.
    Thank you for your help.
  9. richard schumacher
    7,664
    1,046
    United States
    <div class='quotetop'>QUOTE(pipspur @ Oct 22 2007, 09:22 AM) [snapback]528802[/snapback]</div>
    Huh. Odd that this created a buzz and not some beeps, and no warning lights on the dash. Still, all's well that ends well.
  10. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(pipspur @ Oct 22 2007, 10:22 AM) [snapback]528802[/snapback]</div>
    What is a front parking sensor?
  11. Tideland Prius
    16,558
    <div class='quotetop'>QUOTE(PriusRos @ Oct 22 2007, 08:53 AM) [snapback]528856[/snapback]</div>
    Same as the back but for the front of the car. Depending whether it's 2 or 4 sensors, it can help with the two front corners of the bumper as well as pulling right up to the rear bumper of the car in front when you parallel park.
  12. PriusRos
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 22 2007, 12:07 PM) [snapback]528869[/snapback]</div>
    Huh? I must have missed something completely. Do all Prii come with parking sensors? What do they do and how do they tell you they've sensed something?
    2004priusgal likes this.
  13. Tideland Prius
    16,558
    <div class='quotetop'>QUOTE(PriusRos @ Oct 22 2007, 09:13 AM) [snapback]528871[/snapback]</div>
    No. Note that the OP is from the UK.
    Parking sensors are those ultrasonic proximity sensors that beep and (in some cases) give you a visual warning on how close you are to an object.
    In NA, they're mostly mounted on the rear bumpers (those are the little dots you see). I don't remember what waves they use for sensing but basically the faster the return signal, the closer the object (that's how the computer tells how close you are).
    On higher end models (like the Lexus here in NA), they also put the sensors in the front bumpers.
  14. qbee42
    3,079
    <div class='quotetop'>QUOTE(PriusRos @ Oct 22 2007, 12:13 PM) [snapback]528871[/snapback]</div>
    In Chicago the bumpers serve that function. A slight scraping sound means you are getting close, a good solid crunch indicates you are there.
  15. PriusRos
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 22 2007, 12:34 PM) [snapback]528891[/snapback]</div>
    Okay, now I feel much better. I thought for a minute that my Prius comes with a feature I was ignoring because I knew nothing about it.
    <div class='quotetop'>QUOTE(qbee42 @ Oct 22 2007, 01:19 PM) [snapback]528912[/snapback]</div>
    :lol: That's what the sound is for! I just thought it was warning me that paint is being stripped off my bumpers. I've always just waited to feel a bump and see the car in front or behind me suddenly move out of my way.
