Is this unique to the 08's or is it just mine?
Discussion in 'Gen 2 Prius Main Forum' started by paprius4030, Oct 20, 2007.
  1. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hi gang. I unexpectadly traded in my 05 for an 08 Seaside Pearl Pkg.#2. I love the new color and the subtle differences. But looking at the fuel gauge is seems it's sloped slightly downhill. The E if very slightly higher than the F. Does anybody else notice if theirs is like that?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Was expecting a picture of the fuel gauge...can you help us out with that?
  3. paprius4030
    2,077
    296
    York,Pa.
    LOL see you should be careful what you expect....But your right I'll take a pic of it .
    Here's a pic of the fuel guage, I don't know if you can see it but it looks like it's sloped downhill from E to F
  4. efusco
    19,891
    1,196
    Nixa, MO
    Interesting...
    Remember that what you're seeing there is a reflection off a mirror sitting just in front of what you see.
    I'm pretty sure the mirror is glass, and therefore it isn't likely that it's bent or that the reflection is the problem. So, it makes me wonder if the dark background that the light reflects off of is warped slightly giving that appearance.
    To me it also looks like the left side of the display has a slight curve/warp to it. My guess is that whatever that black thing is isn't quite snapped into place perfectly.
  5. paprius4030
    2,077
    296
    York,Pa.
    Yeah Doc it sounds like a Fuel guagedectomy might be required, but if nothing else changes I'll just leave it alone, I don't wanna risk a post op fuel infection LOL
  6. efusco
    19,891
    1,196
    Nixa, MO
    Just point it out to the service guy at your first oil change...they may be able to pop off a panel or two, snap it in and fix it just that quick.
  7. jk450
    jk450 New Member
    55
    <div class='quotetop'>QUOTE(efusco @ Oct 20 2007, 07:13 PM) [snapback]528285[/snapback]</div>
    The fuel gauge and the other reflected blue indicators are all part of the same mass-produced vacuum-fluorescent display, which is mounted on a circuit board. Toyota calls the assembly a combination meter. You will have disassemble the dash to get at it. There is nothing to adjust.
    It's possible that the prism may be incorrectly installed, but I'd expect it to rattle, and jiggle when going over bumps. And the whole combination meter would then be skewed - not just the fuel gauge.
  8. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Mine's like this, in my '06. Almost exactly like your picture, but even worse. The 'gear' position indicators are actually slightly distorted and not quite rectangular.
    It seems to me like something is just a bit warped, somewhere, but I've not noticed anything lose...and I certainly wasn't going to have them take apart my new car for something that minor!
  9. paprius4030
    2,077
    296
    York,Pa.
    Well now the car has 1,000mi on it and last night it started doing something different. The fuel gauge has stayed the same slightly lower on the F side then the E side but the odometer part stated really tilting so much so that the right hand side of it , the mi part started to dissapear on the bottom. Then it would slowly come back up. Guess I have to take it in before it due for it's oil change.
  10. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I don't know from the photo, but it looks like the whole thing is slanted, not just the fuel gauge part. I'd venture a guess that either the mirror is mounted incorrectly (or loosely, given your new info) or that the whole LED unit itself is either crooked or loose... Or maybe you're just tilting your head to one side while you drive? :p
  11. paprius4030
    2,077
    296
    York,Pa.
    <div class='quotetop'>QUOTE(Ichabod @ Oct 27 2007, 09:59 AM) [snapback]531158[/snapback]</div>
    LOL that's quite possible but then everything would be tilted not just the odometer and fuel guage
  12. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    I think it might be an optical illusion. Look at the series of 'S's below. Don't they look a little wavy?
    SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
    Marvin
  13. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    <div class='quotetop'>QUOTE(Marvinh @ Oct 27 2007, 08:54 AM) [snapback]531195[/snapback]</div>
    Doesn't appear to be an optical illusion. The fuel gauge portion is definitely tilted.
    [attachmentid=12225]
    My guess is it was assembled that way in the mass produced vacuum-fluorescent display. It adds to the uniqueness of your Prius :)
  14. paprius4030
    2,077
    296
    York,Pa.
    I'm sure something is loose because since last night the odometer part started really tilting much worse then the fuel guage and then it would slowly come back to almost level.
  15. jk450
    jk450 New Member
    55
    <div class='quotetop'>QUOTE(paulccullen @ Oct 27 2007, 12:48 PM) [snapback]531207[/snapback]</div>
    That's why they are called optical illusions :)
    <div class='quotetop'>QUOTE(paprius4030 @ Oct 27 2007, 12:50 PM) [snapback]531209[/snapback]</div>
    Time to take the car to the dealer, IMHO. I would still be surprised if it was anything but an optical illusion, as the segments are printed on a machine, and must fit a circuit board exactly.
    I'm traveling, but when I get home, I'll post pics of the meter board and the prism. I will guess that your prism is loose. In the meantime, here's a pic of the intended line of sight, not that it helps much:
    [attachmentid=12226]
    The meter is actually facing the FRONT of the vehicle. Left to right, the meter (vertical, tilted to the right) reflects off the mirror (relatively horizontal-ish), which then reflects off the black plastic (vertical, tilted to the left 20º). The latter is what you see. It all hangs off of the underside of the dash plastic.
  16. blamy
    blamy Member
    380
    Central Florida
    Read this thread and checked out my 07 and it does have a slight tilt to it? Had to look real close and if I hadn't read and seen your posting I doubt I would have noticed it.
  17. mjms2b
    mjms2b MJ Green
    349
    Socal
    <div class='quotetop'>QUOTE(BuddyL @ Oct 27 2007, 04:40 PM) [snapback]531346[/snapback]</div>
    :rolleyes: because I"m a little OCD, I will not be checking my 07, ignorance is bliss.
  18. drifty1955
    drifty1955 New Member
    100
    <div class='quotetop'>QUOTE(paprius4030 @ Oct 20 2007, 06:54 PM) [snapback]528279[/snapback]</div>
    Relax...my 07 looks exactly like that.
  19. naterprius
    naterprius Senior Member
    1,843
    Your mirror is warped. Darell's was warped and he got a new one, now it's fine.
    Nate
  20. msirach
    msirach Member
    321
    Southern Illinois
    I checked our 08 yesterday and the dash has a slight arc to it that peaks at car center. I checked it with straight edge.
