lost front brakes completely
Discussion in 'Gen 2 Prius Technical Discussion' started by statultra, Oct 28, 2007.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    ok so my dad being the curious george he is, went to work on the front brakes of the prius,
    i constantly warned him about the car sucking in air through the bleeder plug,
    so we went taking out the brake pads, and he asked me to go press on the brakes, again without brake pads. so i pressed the pedal down all the way, and bang the piston flew out the caliper, including the dust boot spewing fluid everywhere, knowing this was the end of my brakes until i visited the dealer i proceeded to tell him its a lost cause, we put it back together, and i powered up the car and drove it around the block, i never drove with just rear brakes, well never on a 4 door sedan, i had no front brakes what so ever, the red brake light is on, ABS VSC and the other yellow one with exclamation in the middle is on. It feels so weird, but cool none the less, for some reason its a lot more comfortable to brake with the rears only.
    ok important stuff
    is there anyway to bleed the brakes for instance pulling a fuse and bleeding air out?
    if not
    how much is it to bleed air out from the dealer?
    or how much is it to replace brake fluid from the dealer ?
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    This is why I don't let my Dad work on my cars anymore. (Not like he wants to now, he's 78.)
    But a few decades ago when I owned a Ford Pinto he decides to change the oil. After he's done he asks me to get in the car and turn it on. The minute I hear the engine seize I turn the car off.
    "Did you remember to put oil back in the car?"
    "Don't worry about it, I'll fix it."
    And he did. But it took him over a week. I drove his car while he worked on it.
    I make more money now so I can afford to take it to the dealer for servicing. I would anyway. No way I'm letting anyone who doesn't know what they're doing or is just "curious" work on my Prius.
    Will Dad be paying the bill to have the brakes fixed?
  3. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    You dad is a moron. You bleed brakes with everything put together: pads in the caliper, and caliper mounted on the car. Getting all the air out of an ABS system is now beyond the capability of most home mechanics. You can change the fluid if you're careful not to allow any air in the system, but once air gets in the system, it's time to take the car to a pro who has the scan tool to automatically cycle all the valves and pump to get all the air out.
    To change brake fluid, pros use a tool that pressurizes the whole brake system, and supplies new fluid into the master cylinder reservoir at the same time. All they have to do is attach and turn on the machine, and then go to each corner and open up the bleeder bolt and let fluid squirt out until they see fresh fluid.
    You shouldn't be charged more than $50 to refill and bleed your brake system, but I wouldn't be surprised if they tack on some additional charges to inspect your brake system for damage. Hopefully the piston wasn't damaged when it shot out of the bore.
    For reference, replacing every fluid in my SUV costs about $350, and consists of the following:
    Engine oil
    Transmission fluid
    Transfer case fluid
    Front differential oil
    Rear differential oil
    Engine coolant
    Brake fluid
  4. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I've only had my Prius for about 15 hours so I of course haven't tried to bleed the brakes in it. I've read the friction brakes are only even used at slower speeds so for all I know the braking system is completely different. Assuming now they have a master cylinder like "normal" brakes, this is how you do it:
    Top off the master cylinder with fluid. During this process you need to make sure this doesn't go dry.
    Go to the caliper that's FURTHEST away from the master cylinder first. If the master cylinder is on the drivers side of the engine compartment this would be the passenger rear tire. I haven't looked for the master cylinder (assuming there is one) in the Prius and my wife has it at the moment at the store so you'll have to take a look for yourself.
    Locate the bleed screw. It's easiest to use a length of clear tube and attach it to the nipple, then put the other end of the tube in a bottle half full of brake fluid (check to see what the required brake fluid is). This tube isn't necessary, but makes the job not only cleaner but less likely you'll pull more air in to the system.
    Have a helper apply the brakes smoothly. As they start applying the brakes open the bleeder screw. Air may start sputtering out but more than likely if you're starting on a caliper that you didn't suck air in to just fluid will come out. Once your helper gets the brakes to the floor tell him to HOLD THEM there until you close the bleeder screw. Repeat this process one more time if you didn't have air the first time. If you did have air come out keep doing this process until all the air is out.
    Next move to the next furthest from the master cylinder. This should be the opposite rear tire. Repeat the process until you get to the caliper closest to the master cylinder.
    You probably won't have much air come out from the calipers except for the one that you shot the piston out. This one you'll have to do several times.
    You're done. If you don't get the brake feel you used to have I'd now at least say it's safe enough to make a trip to the shop to have someone redo this for you. ...but if you followed the directions this probably won't be necessary. Again, this is assuming the brakes on the Prius are the same as normal brakes on traditional cars.
    Mike
  5. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    d'oh! you just learned rule 1 of working on brakes.
    no, you can't bleed these brakes on your own. the cost will vary depending on the shop but a bleed will include replacing the fluid. you'll probably be looking at new caliper(s) too.
    get a tow, the front brakes do 80% of the braking force. that's really dangerous to drive as is. good luck.
    <div class='quotetop'>QUOTE(mingoglia @ Oct 28 2007, 04:48 PM) [snapback]531663[/snapback]</div>
    unfortunately, they're a whole different universe...
    <div class='quotetop'>QUOTE(priusenvy @ Oct 28 2007, 04:43 PM) [snapback]531661[/snapback]</div>
    and you need the scantool for the prius too.
  6. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(priusenvy @ Oct 28 2007, 01:43 PM) [snapback]531661[/snapback]</div>
    +1.
    I couldn't believe my eyes when I saw the OP. It reminded me of when my father owned a Diesel Rabbit (I had a 1978, he had to get one when he saw the mileage I was getting, his was a 1979). Unfortunately, he had a penchant for finding the cheapest fuel he could - guess what, he got a load of contaminated fuel. Long story short, after $4,000 in parts (I did the labor) I told him to buy his diesel from Chevron stations. He knew better and lo and behold got another load of contaminated fuel. This time, the repairs were entirely on his dime (including the labor) to the tune of $7,500 for a new short-block plus injection pump. Shortly afterwards he sold the car with about 25,000 miles on it. Sometimes, you can lead a horse to water but you can't make them drink....
    What about the power steering fluid?
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(mingoglia @ Oct 28 2007, 03:48 PM) [snapback]531663[/snapback]</div>
    That is the only part you got right. Please read the attached Adobe Acrobat file from the official shop manual.
    I'm going to repeat this for the general audience of Prius owners:
    Whatever you do, do NOT ATTEMPT TO BLEED THE BRAKES YOURSELF!! The life you save may be your own
    Oh, and I checked my 2007 FJ Cruiser. It has electric assist brakes, but they CAN be flushed/bled the "old fashioned" way. You only need the scantool if the master cylinder solenoid has air in it. Please see the attached pdf for the FJ Cruiser
    <div class='quotetop'>QUOTE(apriusfan @ Oct 28 2007, 04:58 PM) [snapback]531679[/snapback]</div>
    A coworker at the office started off the same way with his now 3 year old VW Golf tdi. Since I'm bigger and stronger than him, and also have his career in my sinister hands, he very much listened to my advice to get diesel from truck stops instead of seldom used stations. His motor trouble went away, he was lucky
  8. priusenvy
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(apriusfan @ Oct 28 2007, 02:58 PM) [snapback]531679[/snapback]</div>
    You got me there. It's not normally replaced as part of maintenance though.
  9. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(priusenvy @ Oct 28 2007, 04:49 PM) [snapback]531712[/snapback]</div>
    True, but if you are an obsessive compulsive maintainer (like I am), you replace all fluids that could have break-in particles floating around. :)
  10. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Wow. That's one hairy tale, and I don't know if anything quite that
    extreme has passed across the forums before. I mean, to the point
    of pistons popping out. You've got my utmost sympathy and I will
    echo the advice that the dealer techs are possibly best suited to
    straightening this out since they've also got the tools to make sure
    the pistons are back in and correctly sealed without contamination,
    at least one hopes. You may find an indie who could deal, but
    there's still a lot they probably wouldn't know about the prius
    braking system. Note the relative complexity of the PDF, and the
    fact that it *DOESN'T* even mention anything about actually doing a
    fluid change.
    However, we must avoid spreading misinformation. The outlined
    "procedure" starting farthest away from the MC might be fine on old
    non-by-wire systems, but is utterly WRONG WRONG WRONG for these.
    First of all, even with the car powered off your foot never generates
    pressure that actually hits the wheel cylinders -- it's all up to a
    rack of solenoids and the pressure accumulator, and without in-depth
    understanding of how that system works you're likely to cause more
    harm than good. Second, if you've gotten air inside the actuator
    block [the thing with all the solenoids and pressure sensors inside
    it, see the diagram under here for details] you'll likely need the
    whole scantool dance done with the three or four hands to unhook
    lines, hold fingers over certain holes at the right times, etc etc.
    We did a set of seminars the other week for a bunch of auto techs,
    and one of the nights a guy asked "so how do we flush that brake
    system?" ... and I had no idea what to tell him. Best answer was
    "look it up", but after a little more research it wasn't even clear
    to me that you *can* look that up because it just plain ain't in the
    service manuals. But DOT 3 brake fluid isn't really one of those
    "lifetime" things, and should probably be largely changed within 5
    years by which time it's probably absorbed enough water to start
    corroding internal parts.
    Maybe galaxee/DH have some better input on flushing/bleeding if DH
    has had the opportunity to do any of those things on a prius...??
    _H*
  11. galaxee
    9,810
    469
    MD
    oh yeah... he's had to open a brake system on a prius and rectify things afterward more times than he can count on 2 hands anyway. well... the scantool gives you the options to do the correct bleed, and also guides you through as it completes the steps it's needed for. hence the absolute need to have one to do any kind of brake fluid work. the upshot is that you only need one person to bleed brakes on a prius.
    sp the repair manual directs you to the scantool because that's all it can do.
    to change the fluid, one simply bleeds the lines while adding new fluid to the reservoir. there's really not much more to say about it, he says.
  12. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    <div class='quotetop'>QUOTE(hobbit @ Oct 28 2007, 07:25 PM) [snapback]531754[/snapback]</div>
    The term "misinformation" implies that I didn't state that I've owned my Prius for less than 1 day and I acknowledged the fact that I wasn't sure how the brakes differed from conventional brakes. Now if I stated that "this is the way to do it" without that disclaimer that would be another story.
  13. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    <div class='quotetop'>QUOTE(priusenvy @ Oct 28 2007, 06:49 PM) [snapback]531712[/snapback]</div>
    No power steering fluid in the Prius - electronic power steering.
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(mingoglia @ Oct 28 2007, 10:01 PM) [snapback]531772[/snapback]</div>
    While the disclaimer certainly puts the proper perspective on how the information should be interpreted and used it doesn't change the fact that the information you provided is wrong...and thus is "misinformation" that needs to be corrected. No insult was intended to you and certainly as a new owner you've a lot to learn about the car. And we appreciate your contribution here. But no matter how you framed it the information is wrong.
    If you'd have said "I've just had my Prius for less than one day and I'm not sure, but I think the Prius breaths air and produces gold from the exhaust pipe." You'd be presenting misinformation, though we'd certainly know why...
  15. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(efusco @ Oct 28 2007, 08:30 PM) [snapback]531787[/snapback]</div>
    Well.... Not to be flippant, but following the theory that a penny saved is a penny earned... an argument can credibly be made that the Prius does in fact produce gold (or copper, or nickel, or cupro-nickel...) from savings on gas purchases.... :)
  16. hobbit
    4,089
    469
    Bahstahn
    Okay, bleeding + adding makes sense simply because that'll push
    enough fluid [sans air] through the entire system to effectively
    flush it, right? Is it relatively easy to tell by color change
    when the new stuff has arrived at the wheel, and how much further
    bleeding is usually needed to try and make sure everything in the
    wheel cylinder has been pushed out too [or is that just impossible]?
    _H*
  17. galaxee
    9,810
    469
    MD
    you can tell by what comes out. that's how one goes about it the old fashioned way at home on a conventional car too... we actually just did a brake flush on a late-90s civic for the upstairs neighbors this afternoon.
    telling the endpoint is the same in all cases, prius or not.
  18. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(Godiva @ Oct 28 2007, 02:38 PM) [snapback]531648[/snapback]</div>
    If it was a Pinto Sprint, boy am I jealous!
  19. Godiva
    10,339
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 28 2007, 11:49 PM) [snapback]531830[/snapback]</div>
    I have no idea.
    It was red. It was a 1979 and it was a hatchback. Then bought a 1984 200sx hatchback. It was totaled when I was rear ended. I then bought a 1996 Saturn SC2 coupe that had a trunk. Lousiest trunk I ever saw. Couldn't hold spit. Had it 9 years. Sold that and bought the Prius in April, 2005.
  20. priusenvy
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(kohnen @ Oct 28 2007, 08:24 PM) [snapback]531782[/snapback]</div>
    We know that. The sub-thread you responded to was not about a Prius.
