Prius MFD Operating System
Discussion in 'Gen 2 Prius Technical Discussion' started by pkhoury, Nov 2, 2007.
  1. pkhoury
    pkhoury Proud TDI owner
    183
    Here's an interesting question I was thinking of - does the Prius (new or first/second gen) run an off-the-shelf operating system and hardware for their MFD, or is it a custom Toyota-Internal solution? What about the hardware? Being a techie, I've been wondering this for a while.
  2. pigwot
    pigwot Junior Member
    17
    <div class='quotetop'>QUOTE(pkhoury @ Nov 2 2007, 01:02 PM) [snapback]533942[/snapback]</div>
    An interesting question... maybe a derivative of Debian or some other *nix?
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  4. Rest
    Rest Active Member
    1,210
    CA
    I thought it was Linux.
  5. cheule
    cheule New Member
    39
  6. pkhoury
    183
    <div class='quotetop'>QUOTE(Sean Blumenthal @ Nov 3 2007, 12:25 AM) [snapback]534245[/snapback]</div>
    Makes me wonder. At least I've never seen the MFD crash or hang. Unlike my Samsung cell phone (I swear it runs Windows CE or something) which always crashes.
  7. pkhoury
    183
    Also, I take it nobody has really hacked into the MFD, or got a command prompt or anything? Any ideas as to the actual hardware used for the ECU (cpu, etc)?
    Paul
  8. wgary
    wgary Member
    37
    36
    Auburn, Alabama USA
    <div class='quotetop'>QUOTE(pkhoury @ Nov 3 2007, 08:40 PM) [snapback]534482[/snapback]</div>
    Given the tech allure of this care, I am simply amazed that this hasn't been done! Certainly some techie type wants to come up with a FREE way to defeat the "gray" syndrome when in motion, which may be "safe" but is extremely annoying. I mean, 300 is a lot of tamales to pay for LockPick, I'd rather get some speakers...
  9. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I've poked around in the boot file of the Nav DVD. There are references in it to various /dev devices like /dev/cd/cd1/slot0/ and /dev/avc_lan, which is a unixoid sort of thing.
  10. pkhoury
    183
    <div class='quotetop'>QUOTE(alanh @ Nov 3 2007, 09:59 PM) [snapback]534543[/snapback]</div>
    And this is for which year? I once copied the PCMCIA Type III hard drive for a Toyota Sienna
    Nav system while I was in the shuttle van, and the files appeared to be DOS based.
    Anything with /dev is definitely UNIX based. It sounds like Linux, but I'm a Solaris kinda guy.
    But back on topic - has anyone here actually taken apart the ECU? I'm seriously curious in addition to OS what kind of CPU, RAM, etc is in there. Considering that the Prius is esentially a computer on wheels.
    Paul
  11. momanz
    momanz Junior Member
    42
    Oregon
    <div class='quotetop'>QUOTE(pkhoury @ Nov 4 2007, 02:03 AM) [snapback]534560[/snapback]</div>
    Here's an article on the tear-down of various hardware components in the Prius. I'd like to get a closer look at the boards in the MFD anyone have any closeups?
    -m
  12. pkhoury
    183
    <div class='quotetop'>QUOTE(momanz @ Nov 4 2007, 08:55 PM) [snapback]534822[/snapback]</div>
    This is definitely informative. Okay, so we have two PCB's with CPU's. And they mention 16MB of FLASH and 64MB of RAM. I'm thinking maybe a realtime OS like QNX or VxWorks, or the ITRON OS as specified above, in order to fit in 16MB (maybe slightly compressed, since you figure when you start the car, and you have the Toyota logo screen, that's when it's boot strapping).
    Now I wonder if you could technically add bluetooth functionality if you just added the bluetooth board (and if the microphone is already built in).
  13. AnailizeR
    AnailizeR Junior Member
    57
    US - Somewhere....
    Well .. I am always up to spreading "muy love" open ... after I go for my 4000 mile oil change probably this weekend .. i will do some work .. which reminds me .. never got around to posting my dash board pics ... damn work sucks...
  14. pkhoury
    183
    After doing some research for something else, this seems to suggest that my prognosis might be correct:
    http://www.qnx.com/style/_swf/automotive/q...tomotive_v4.swf
    It takes a while for the list to scroll, but very likely the Prius uses QNX (per the above thread that says the nav DVD uses a unix FS).
    Paul
  15. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It will undoubtedly be some embedded system pared down to do the
    tasks it does without general-purpose OS fluff, likely built around
    one of the development systems / kernels mentioned. I hadn't seen
    this thread yet but you can certainly get a look at how the MFD is
    constructed in the page I put together last week. I've also jotted
    down some chip numbers [which you probably can't see from the pix]
    and was going to try looking some of them up, but I think we'll find
    that it's a lot of proprietary stuff or fpgas and uCs whose
    programming you don't have a copy of. No, this probably doesn't
    help much.
    _H*
  16. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I think the Prius isn't a computer on wheels, it's a cluster of computers on wheels, connected by three LANs. For highest reliability, specific tasks, such as braking, are controlled by embedded RT controllers. They talk to each other, of course, since various functions interrelate.
    Data Daedalus likes this.
  17. RonH
    RonH Member
    556
    Another possibility no one's mentioned is that there is no OS. Embedded systems with hard realtime constraints like, say, the ABS system, can't afford to let an operating system kernel fool around with scheduling and priority and what not. The boostrap loads the application which runs a single loop with polling I/O and a watch dog timer to reboot if something goes wrong. Keep it simple and keep control.
  18. Bill Merchant
    4,096
    87
    Didn't I say that?
  19. pkhoury
    183
    <div class='quotetop'>QUOTE(Bill Merchant @ Nov 25 2007, 11:12 PM) [snapback]544171[/snapback]</div>
    Still makes me wonder. I know QNX does tasks like embedded controllers for nuclear power plants, and 911 call centers. Ya never know.
    The people who took the whole car apart (too tired to remember if I posted the link or not) said
    that there is a decent amount of RAM on some of the boards (I think 64 or 96MB of flash), so you figure it has something in there.
    I noticed also a soldered Lithium button cell. I wonder what happens when it goes out? I know the life expectency of those things are only about 5-8 years.
    Paul
  20. patsparks
    10,664
    567
    Adelaide South Australia
    <div class='quotetop'>QUOTE(RonH @ Nov 26 2007, 04:06 PM) [snapback]544161[/snapback]</div>
    That's just what I was about to say. :huh:
    Sorry I'm lost in the geek world (said in the nicest way)
