What ICE would you pick(or wish) in '09 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by holycow99, Nov 3, 2007.
  1. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(holycow99 @ Nov 3 2007, 06:51 PM) [snapback]534506[/snapback]</div>
    The Civic's 1.3 litre doesn't produce 110hp. It's the net hybrid system that produces 110hp.
    Their rationale is that a 2.0 litre won't get the mpg they want and a 1.0 litre is deemed too small for a car of that size (we're talking about the old Prius). Their initial range is 1-2 litres so 1.5 litre was a compromised. It also so happened that they were making a 1.5 litre engine for their new subcompact - the Echo/Vitz/Yaris for a 2000 launch.
    I for one wish that the new 1ZR 1.6 litre Dual VVT-i engine will be used.
  2. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    <div class='quotetop'>QUOTE(Graz @ Nov 4 2007, 03:13 PM) [snapback]534701[/snapback]</div>
    I just read this which makes me think E85 is evil...
    "The apparent motivation is the nature of U.S. Corporate Average Fuel Economy (CAFE) standards, which give an effective 54% fuel efficiency bonus to vehicles capable of running on 85% alcohol blends over vehicles not adapted to run on 85% alcohol blends." from http://en.wikipedia.org/wiki/Ethanol#Controversy.
    A free 54% CAFE standard boost being able to run E85 sounds like complete BS. You get less mileage per gallon w/ E85, ethanol production is not efficient, and E85 isn't widely available.
    <div class='quotetop'>QUOTE(Husker4theSpurs @ Nov 6 2007, 02:42 PM) [snapback]535728[/snapback]</div>
    But it requires tropical/subtropical climate, of which there isn't a whole lot of in the U.S.
  3. holycow99
    holycow99 New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 6 2007, 05:11 PM) [snapback]535792[/snapback]</div>
    What HP and torque are this engine?
    Or how about Camry hybrid's 2.4 litre ICE (146 HP)?
    While most Prius owners describe Prius' power being "adequate", the Prius is still perhaps the slowest $25K sedan in the market today.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Compare our cars to those in Europe where anything > 2.0L is a luxury and we're doing just fine. The American "need" for faster cars is exactly what's driving fuel economy averages down.
  5. holycow99
    <div class='quotetop'>QUOTE(htmlspinnr @ Nov 7 2007, 07:43 AM) [snapback]536090[/snapback]</div>
    Good point, I totally agree with you. We Americans are spoiled. But the fact that the Prius is still serving a niche market needs to be addressed. It is ~$2K more expensive than the comparable non-hybrid versions and Its performance is slightly lacking as well, both have combined to limit its market penetration. I think it is a worthy goal to keep the great fuel economy while keeping cost and performance in par. By improving the performance, more people will buy, which in turn brings down the cost by virtue of economy of scale, which in turn will allow more people to buy...etc.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I would pick the same 1.5L ICE with higher 6,000 RPM making about 90hp. The Camry hybrid's 2.4L also goes up to 6,000 RPM so why not?
  7. douglas001001
    douglas001001 smug doug
    222
    Chicago
    <div class='quotetop'>QUOTE(holycow99 @ Nov 7 2007, 10:23 AM) [snapback]536106[/snapback]</div>
    The number of wheel turns per drop of fuel is much higher than any other car, that is more performance.
    I can't think of a situation where if you get the rpms up to 3500-4000 that the car won't perform within the limits of what anyone would need in terms of emergency speeding up or merging onto the highway. If you want more responsive handling there are modifications you can make.
  8. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(holycow99 @ Nov 7 2007, 05:28 AM) [snapback]536085[/snapback]</div>
    124hp and 116lb-ft (don't know if it's the old or new SAE). That's almost the same hp as the 1ZZ 1.8 litre VVT-i engine but down about 10lb-ft compared to that same engine. Even if we de-tune it and run it on the Atkinson, it'll be a bigger improvement over the 76hp of the 1NZ 1.5 litre we have now.
    Ideally, it'll be nice to have the 3ZR-FAE 2.0 litre dual VVT-i valvematic engine but I think it'll be too costly to put in a Prius. Plus, it's only available on the Noah and I think Voxy too in Japan.
  9. holycow99
    <div class='quotetop'>QUOTE(douglas001001 @ Nov 7 2007, 11:17 AM) [snapback]536193[/snapback]</div>
    Hey, what we're talking about in this thread is how Toyota can make a great car better in the third generation Prius that will come out in '09. I can readily agree that Prius is king in fuel economy but clearly lacking in power (compared to other $25k sedan).
    To me, I'm 100% satisfied with 48/45 mpg fuel economy. What I hope Toyota could do is to give Prius more power (in line with other $25k sedan) than just being "adequate".
  10. ryogajyc
    985
    165
    Reseda, CA
    <div class='quotetop'>QUOTE(holycow99 @ Nov 7 2007, 07:23 AM) [snapback]536106[/snapback]</div>
    <div class='quotetop'>QUOTE(holycow99 @ Nov 7 2007, 02:19 PM) [snapback]536342[/snapback]</div>
    Your have got to be kidding. I could out drive 95% of the cars on the road in a my old car, a 1992 Ford Tempo. And both the classic and current Prius is so much more powerful than my old car. The lack of power is a delusion. Only a few people really use it and the Prius does not need to bother to satisfy that small segment of the market. Performance measured as horsepower is a marketing delusion. What matters is torque and the Prius delivers plenty as it is. Market the torque as the measure of acceleration/performance!
    Look at other vehicles which focused on performance rather than fuel economy. The Accord Hybrid is or already has been discontinued. The RX400H doesn't sell particularly well. The Prius does great because it does fulfill most people's needs well and with great fuel economy. Most people just don't realize it yet. The entire point of the hybrid is fuel economy. Increasing the fuel economy will make the Prius an even more appealing choice.
    Now if you want to do something like add a turbocharger which improves fuel economy and performance, that makes sense. But the fuel economy is what should drive it. The performance is just bonus.
    What people think they want and what they actually want can often be two different things. You have something like the Accord Hybrid where people buy it b/c it's a hybrid that has great performance, but then they have buyer's remorse when the fuel economy stinks. You have Prius buyers who buy the car despite some nagging concerns about performance and after driving it a bit, they love it for the fuel economy and try to get great mileage out of it. Everyone I know who has been in a Prius is surprised by how well it performs. You want to take care of those performance concerns of the mainstream market? Have them test drive a Prius.
  11. dipper
    dipper Senior Member
    1,242
    252
    How about an HCCI engine with the EV motor?
  12. douglas001001
    222
    Chicago
    <div class='quotetop'>QUOTE(holycow99 @ Nov 7 2007, 05:19 PM) [snapback]536342[/snapback]</div>
    Well the torque of the electric motor is sitting there relatively unused, if you could get all of that torque to the ground you'd have some fun next to a lot of cars launching from stop lights.. but I don't think the computer is programmed to let you use it.
    We're all wanting standard EV mode available, sounds like you'd like a SPEED EV switch.
  13. ryogajyc
    985
    165
    Reseda, CA
    <div class='quotetop'>QUOTE(dipper @ Nov 7 2007, 04:38 PM) [snapback]536405[/snapback]</div>
    I'm no automobile expert, but from reading the Wikipedia article (http://en.wikipedia.org/wiki/HCCI), it looks like HCCI isn't ready for commercial use yet. The easiest thing to get it working on initially would be a series hybrid where the engine could run at a very limited range of RPM to make the controls problem easier. In a parallel (in addition to series) hybrid like the Prius, I think the controls would be very difficult to work out and that is much further down the line. It does sound cool, tho'.
    <div class='quotetop'>QUOTE(douglas001001 @ Nov 7 2007, 06:59 PM) [snapback]536476[/snapback]</div>
    I don't think that's correct. I spin my tires if I accelerate from a stop too quickly and I have Goodyear Assurance TripleTreds which have pretty good traction (it's even easier to lose traction with the factory Goodyear Integrity tires). I think torque is available, just limited by the traction to the ground.
  14. dipper
    1,242
    252
    <div class='quotetop'>QUOTE(douglas001001 @ Nov 7 2007, 05:59 PM) [snapback]536476[/snapback]</div>
    I think the problem is not the EV switch. The battery needs to perform better (and way better capacity). If more energy is able to be sent to the EV motor, the HP numbers would have been better.
    Try driving up the 11k feet slope on I40 West of Denver, and you will see why when carrying full load. The battery will drain in a few minutes, and you will be running on ICE at full throttle at 50mph.
    But of course, coming down is the real fun part. B)
    Until Toyota will/can do that, getting a better performing ICE is the only solution.
  15. Graz
    Graz Member
    179
    28
    Re: What ICE would you pick(or wish) in '09 Prius?
    MOOT point Gents.
    Nothing is more expensive than sending our petrol $$$ to terrorists. I think a $1.00 a gallon federal tax used to reduce our dependence on foreign oil, is more reasonable than providing Detroit more opportunities to sell us what they want instead of what we need.
    Unless you think the oil companies haven't made enough money yet.
  16. patsparks
    10,664
    567
    Adelaide South Australia
    I would really like to be able to tow a small trailer maybe 400kg. This would allow me to tow my motorbike on a trailer and take some junk to the recyclers. Sometimes I just want to take bottles and cans to the recycling depot and although they would fit in my car I don't want the stains on the carpets if the bags of bottles leak a little.
    It isn't legal here to tow a trailer here if the manufacturer specifies 0kg towing capacity.
  17. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    For all the people that say the prius has no acceleration better drive a big truck for a while. It makes you think twice about cutting into traffic. When you have 10 gears to get threw and 0-60 i after about 3 minutes You don't care so much about the difference in 5 - 13 seconds. And that is if the dangf truck can even hit sixty.:D And some of these are like that even with out extra loads.
