Blocking the grill
Discussion in 'Gen 2 Prius Main Forum' started by New2Prius2008, Nov 18, 2007.
  1. New2Prius2008
    New2Prius2008 New Member
    Hey guys -
    I've read several times on this forum that blocking the grill is a way to keep the engine from running so much in the winter to keep the engine warm. Great advice. I'm just wondering how you guys actually accomplish this and have something that is easy to put in and take out depending on the temp and something that doesn't look like crap?
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Crap appearance is relative. If I saw human crap I would be repulsed; however, if I saw the crap of a Tasmanian Wolf (Thylacinus cynocephalus) I would be overjoyed and find it beautiful! :lol:
    The best looking method would be to take apart the plastic facia over the radiator area and put some kind of flat plastic-like panel to block air coming through the openings from hitting the radiator. There are numerous threads in here that show a pic of someone using a yellow panel for such a purpose.
    In on the of the newer threads someone used thinner pipe insulation and tucked it in nice and neat. I thought it looked good myself. I would recommend doing a search and finding the latest thread on the subject. It was only posted about a month ago. :)
    This is the thread:
    Looks good IMO.
  3. john1701a
    john1701a Prius Guru
    12,805
    5,291
    57
    <div class='quotetop'>QUOTE(New2Prius2008 @ Nov 18 2007, 03:16 PM) [snapback]541272[/snapback]</div>
    Misunderstood advice, but still very good.
    Realistically, unless the temperature is well below freezing, you aren't really gaining warmth from blocking. I certainly haven't from my first month's of data... and I've got 4 years to compare back to. When it gets a lot colder, observations from lower-grill blocking may be revealing. But we're talking 20 F at the very warmest.
    At above freezing temperatures, the blocking benefit mostly comes in the form of improved aerodynamics. The sealing of the upper-grill section definitely contributes to higher MPG, especially at highway speeds.
    So regardless of the whys, it is indeed a good thing to do.
  4. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    We use the simple pipe insulation that one can purchase at any home improvement type store. it comes in about 4 ft. lengths. cut is one lengthwise opposite that existing cut so you end up with two long pieces. then you just tuck it in and trim it to fit.
    Its one of the cheapest and effective and safe additions for wintertime. Good Luck!! B)
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(john1701a @ Nov 18 2007, 04:16 PM) [snapback]541289[/snapback]</div>
    Just to counter-point this, I disagree with essentially every point.
    1)Even above freezing reducing the cold air-flow through the engine compartment reduces the conductive heat loss. I, too, have 4 years of exerience and at least 2 full winters where I've had mostly moderate tempertures to compare to as well as additional monitoring equipment to observe engine temp. I can tell you that unequivocably that Engine temps are higher, ICE run times are lower, time to peak temp is shorter, and overall FE is much better.
    2)The aerodynamics statement is pure bunk, and undefensible by any objective data.
    3)The more of the grill you block the less air flow through the engine compartment. In warmer weather it may be advisable, when you can monitor the inverter temp and the ICE temp, to block just the upper grill in order to assure that the radiator for the Inverter gets adequate air flow. Note that grill blocking has nothing to do with the radiators (other than noted above) because the thermostat will stop the coolant flow through the radiators when the ICE is cool...it is all about keeping as much cold air as possible out of the engine compartment itself.
    I do agree that it's a good thing to do.
  6. john1701a
    12,805
    5,291
    57
    <div class='quotetop'>QUOTE(efusco @ Nov 18 2007, 04:41 PM) [snapback]541301[/snapback]</div>
    This has taken a weird turn.
    How could improving airflow not make a difference?
    I live 3 blocks from a 70 MPH highway with an uphill ramp. Only the upper-grill is blocked and the 2 lights are usually green. The first 5-minute segment shows a definite MPG increase.
  7. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(john1701a @ Nov 18 2007, 06:28 PM) [snapback]541331[/snapback]</div>
    Improving airflow, by definition, will make a difference...but my point is that I'm not convinced that blocking the upper grill improves air flow...maybe it makes it worse by not allowing the air that hits that area to pass freely through the grill, radiator and out the engine compartment? Maybe it's a zero affect issue? The point is that that is not the reason for blocking the upper grill.
    I don't know what you're trying to tell us with this sentence.
  8. john1701a
    12,805
    5,291
    57
    <div class='quotetop'>QUOTE(efusco @ Nov 18 2007, 08:48 PM) [snapback]541390[/snapback]</div>
    You seem to be forgetting that my driving style, situation, and fuel is the quite different from yours... I haul nice person onto the highway. I never, ever pulse & glide. I don't have an EV button. Maximizing engine-off means little to me. My efficency aim is simply keeping the current MPG over 50...
    So our basis of measure have little in common. You are that guiding-light for aspiring enthusiasts. I am the representative of joe-consumer-never-participate-online. That's a huge difference.
    I blocked the upper-grill. I didn't witness any temperature difference on the ScanGauge, just very stable as usual. Yet, MPG climbed. Preventing the pass-through/entry of sure makes a heck of a lot of sense as the major influence at temperatures above freezing, since the warmth isn't needed yet. With the upper sealed, the pressure pocket reduces input from the bottom.
    If it was warmth, how does that factor in at 70 MPH? My engine stays at a happy 186^F quite consistently, like before upper blocking. What's different if it isn't aerodynamics?
  9. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(john1701a @ Nov 18 2007, 09:29 PM) [snapback]541402[/snapback]</div>
    I'm forgetting nothing, I just didn't understand what you were trying to say with the sentence (2 green lights?)...but I think I know what you were getting at now.
    I drive in a lot of conditions. While my usual commute does, indeed, permit some great P&G/hypermiling opportunity I have many thousands of miles under my belt in highway steady speed conditions as well. And my observations are much different than yours. Just b/c you're seeing a constant engine temp doesn't mean that the ICE isn't running harder to maintain that heat even if you are experiencing 100% ICE-on time. If your fuel flow is .1gal/hr more to keep your temp up then your MPG will be impacted.
    My "evidence", poor as it is, that it's not an aerodynamic affect is that my first year of radiator blocking I actually didn't block the outer grill, I used an old piece of one of those windshield sun screens inserted just in front of the radiator but well behind the grill--thus the grill slats were wide open. And yet I jumped my mpg from about 45mpg the prev. winter to 50 my second winter. My 3rd winter I went to the blocking of both upper and lower grills from the outside and experienced an even greater jump...I attribute that to the fact that the airflow via the lower grill was stopped and the air flow from the upper was more effectively stopped.
    Look, maybe you're right, maybe there's some way to wind-tunnel test and find out... but when I look at my blocked grill I can't imagine that that tiny piece of insulation is having a measurable affect on FE... A 5% improvement in FE based upon aerodynamics alone would require a drop in Cd from the base 0.26 to approximately 0.23 (using Wayne Brown's simulator) at 60mph. Ain't no way you're getting that much from a piece of foam.
  10. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I notice a difference with my blocked grill. The car warms up faster and stays warm longer without the engine running. At an ambient temp close to freezing, so far (hasn't gotten cold here yet), in city driving at 50-70 km/hr (30-45 MPH) the car will not warm up. With the blocking the coolant will reach 70-80C. It gets to 50C in just a few minutes, and will blow nice warm air inside.
    Here's what mine looks like, with 3/4" pipe insulation in the top grill and 1 1/2" to 2" in the lower grill. Bonus, it also protects the grills from winter crud and makes it easier to clean the front.
    [attachmentid=12522]
  11. 80me
    80me New Member
    No worries about over heating?
  12. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(80me @ Nov 19 2007, 09:44 PM) [snapback]541787[/snapback]</div>
    Not really...many of us monitor temps with extra 'toys' and they rarely, even in summer weather, even get near the upper limits of normal. In winter never.
  13. David Beale
    5,963
    1,988
    Edmonton Alberta
    After watching the coolant temp with the Scangauge for awhile, I'm confident it will not overheat as long as the outside temp is below 20C (70F). If the temp goes above 20C it might overheat on the highway, but probably not in the city. At any rate, it's easy to remove the foam. Just cut the two zip ties and pull it out (lower). The upper can be left in until it's 30C (80F) ambient.
    You'll note I left the sides of the foam open. So if necessary the fans can draw air in from there. So far, I haven't see/heard the fans run, even when the ambient was at 21C. So the fans give me an extra "safety factor".
  14. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    John and Evan:
    Let me throw in one fact here regarding aerodynamics. Whenever air is forced to change direction, you have drag.
    So John may be seeing an aerodynamic improvement by reducing incoming air which strikes the engine, gets deflected, and causes drag. This technique has been used to great effect by light-aircraft manufacturers. By redesigning air intakes, cowling shape, and directing airflow, they greatly reduced the drag of air cooling the engine.
    This effect, which may be small at automotive speeds, could still be noticeable on some cars in some conditions. For John, it appears to be noticeable. For others, it may not. Factors such as driving style, tire pressure, vehicle load and vehicle drag contribute. (Some cars may actually have lower drag coefficients than others, based on production variations.)
    So I think you're both right, though the main intent of grille-blocking is to increase temps, improving warm-up times.
  15. New2Prius2008
    I've gone ahead and blocked off the top grill and partially blocked off the lower grill. For now, I'm using the pipe insulation as suggested, but think I will keep looking for a fairly or semi rigid piece of black plastic that I can cut to shape for installation behind the grill(s). Also have my tire pressures @ 42 psi in the front and 40 in the rear. With that, I guess I'm loaded up for a winter in Maine with my new Prius... :)
    Snowing today, BTW...... Too early for this crap just yet...
  16. efusco
    19,891
    1,196
    Nixa, MO
    Thanks Rick,
    But while there may be some slight aerodynamic benefit the point I tried to make above is that mathematically it seems highly unlikely that it would be measurable with any but the most sophisticated tools and certainly not visible in day to day or tank to tank measurements on the Prius.
  17. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    Evan and John: Good thread. Thanks to both of you for your expertise and willingness to share your experiences. And, David, thanks for the photo of your grill blocking. I blocked mine after hearing from you guys with the ScanGauges that the temps would not get too high.
  18. adezj
    adezj New Member
    Santa Cruz, Ca.
    how do you get such great mileage? i'm "only" getting 46mpg.
    alex :blink:
  19. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(efusco @ Nov 20 2007, 09:11 AM) [snapback]542012[/snapback]</div>
    I tend to agree. It's a small improvement in aerodynamics at best.
    Maybe John's MPG improvement is because they've changed the timing on the green lights!
  20. ibmindless
    ibmindless Member
    206
    I'm a new convert to blocking. I'm in Seattle and the temperatures have been heading down the past few days. I only do a 3 mile commute, so my mileage runs anywhere from 41 - 46MPG, depending on how late I slept in. Tires are 42/40PSI. Over the past week, my mileage has been down to 38.8MPG. In the morning, I usually get 25MPG for the 1st 5 minutes, followed by 50 - 70 MPG - again, depending on how cozy my bed felt. Lately, it's been 20MPG for the 1st 5 minutes, followed by 25-35MPG as the temp's have fallen.
    So I bought 6' of 3/4" insulation for $1.19, cut it in half and put 1 strip in the top grill and 2 strips in the bottom grill. I still have about 3'-4' left over. The resulting MPG has dramatically improved. My 1st 5 min. was 25MPG, followed by 50MPG! So there's another endorsement for blocking.
