BT Tech Introducts 2 new products for the Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BT Tech, Dec 6, 2007.
  1. BT Tech
    BT Tech New Member
    885
    South Florida
    BT Tech Introduces 2 new products for the Prius
    After months of egineering and changing designs, I wanted to show everyone our new 2 products that will be ready to ship this month.
    As some as you have guessed correctly, one of our products is called the BT Tech skid plate protector for the 2004-2008 Prius'. It is manufactured out of aluminum and serves 2 functions:
    1: To provide superior protection from road debris against the bottom of the engine and transaxle assembly and provide protection from the front bottoming out and causing damage to the mentioned components.
    2: To provide a smooth aerodynamic transition underneath the front of the car.
    We have designed into or skid plate 3 very important and nice features:
    1: Easy access to remove oil drain plug
    2: Easy access to remove oil filter
    3: Easy access to remove transaxle fluid.
    All of the above functions can be peformed WITHOUT having to take apart the skid plate.
    The picture you see here is my proto-type version and the finished production versions will be powdercoated in a very durable wrinkle finsh black powdercoat. We will also be incorparating strengthening ribs on the production parts to provide superior strength. Fit and finish will be excellent and our new product will come equipped with a complete instructions sheet and new stainless steel fastners.
    This item will be available ONLY in the Prius Chat On-Line store shortly as a pre-buy. I will only be making 10 of these to start off with and will continue with production once I see how these are received on the market.
  2. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Whoa! It must be Christmas!
    Thanks Brian.
  3. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    I'd like to see the painted version... looks clean... my plastic cover is all peeled... the old man used the car for a while and he's a lousy driver:(
  4. Tideland Prius
    16,509
    judging by the bottom of your front bumper, maybe you wanna extend the skid plate just a bit for us poor 04/05 owners lol ;).
  5. Boo
    5,051
    488
    97
    Flushing, NY
    I live in Squirrels Central (seriously), and only recently heard about Rat Away spray.
    Do plates like this provide a nice hiding place for squirrels and other wire eating rodents to nest?
    Guess I can spray the entire subject area with Rat Away before putting the plate on, but I don't know how long that stuff is supposed to last.
  6. Sufferin' Prius Envy
    3,998
    I wonder how well those holes will do at scooping deep snow and packing it away behind the shield.
  7. DaveLadely
    DaveLadely Junior Member
    47
    skid plate
    The skid plate sounds like a good idea. Perhaps the holes could be made of a size that would allow screwing in the same size boat deck access covers as they would keep snow, mud, etc out. The covers are offered in white or clear, usually of polycarbonate so are virtually unbreakable. Also, maybe the covers would allow for larger diameter access holes, which would improve access.
    Dave in Seattle
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Depending on the price...you can put me down for one of those.
  9. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Me too:). It looks like it would help the aero package.
    But the others have good questions, and my main interest would be for snow.
    How will it reacts to driving over the deep stuff, will it protect, or will it scoop and snag?
    If the holes act like scoops, maybe a cover could be made, that fastens with a tab, and one or 2 screws.
    How would it affect engine cooling in summer?
  10. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    It seems like a great idea, but it's not clear whether I'd have enough elbow room to remove the oil filter, especially without spilling oil. Will two (long) arms fit through the hole? I use the cut-off bottom half of a 2 liter plastic juice bottle to capture leaking oil as the filter is unscrewed and to drop the filter in after it's off. Is the hole big enough for that?
    If oil is spilled (which I almost always seem to do despite my best efforts), it would seem like some will almost certainly drip onto the inside of the plate. How do you clean it without taking it off?
    I use ramps, so I don't have as much room to maneuver as if the car was on a lift.
  11. Doc Willie
    1,717
    144
    Out there, somewhere
    I hope it won't cover up the undercar lights -- er, I mean Antigravity Generators.
  12. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    I would like to see one that covers the entire length of the undercarriage, incorporating the chassis stiffening brace as well as stiffening the entire vehicle against buckling in any direction -- not only would the smooth aerodynamics increase our downforce making the car substantially safer at high speeds, they would ALSO increase aerodynamics and overall mileage if the weight could be kept down!
    ~ dan ~
  13. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Awesome!! I remember when we chatted about this a couple of years
    ago, too. The big obstacle as I saw it was how to mount the
    thing, and I assume you've done the appropriately complex amount
    of metalwork needed to attach to something substantial.
    I'm a little concerned about the holes and access too, as when
    I'm doing O/F I like to have everything nice and open under there.
    Is there an easy way to have the brackets holding the plate on
    be the permanently-mounted piece, and then the [solid] plate itself
    relatively easy to remove with a few easily-accessed bolts right
    on the bottom? The bolt holes may need to be slightly slotted,
    but we could certainly live with that.
    Airflow shouldn't be an issue since the whole thing is open at
    the back where the exhaust pipe and suspension are, if you
    haven't left your radiator-blocker in...
    _H*
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    interesting... have to post to keep up on developments, otherwise, i forget...but i do bottom out occasionally simply because the people who design parking lots eat lunch with the people in charge on maintaining parking lots and the entrances and exits are the first to go.
  15. BT Tech
    BT Tech New Member
    885
    South Florida
    Thanks everyone for your comments. Please note that this is only the prototype and we will be making changes to the design to accomodate everyones concerns. At first I was a bit apprehensive to even post this picture as the design is not 100 percent finalized but I wanted to show everyone where we are at with this new product.
    I should have our "finalized" skid plate mounted by next week and will take more pictures for everyone to see.
    Thanks!!
    Brian
    BT Tech
  16. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I think it looks really nice, Brian. If you could actually check with a Toyota dealer, to see if their maintenance people have any issues with it, that'd be my only concern, since at this time I do take the car to the dealership.
    As an aside, I re-torqued my Plate after 1 1/2 years of service; it hadn't loosened appreciably and was showing no other signs of wear. I'm sure this will be up to those high standards.
  17. BT Tech
    BT Tech New Member
    885
    South Florida
    Thanks Pinto for your comments... One of my Toyota buddies who is a tech relly liked our prototype skid plate. One of his first comments was that it was well thought out in regard to easy access for routine maintaincence. Our final version will be ready in about a week and I will post pictures of it here.
    Our production part will be of high quality and the attention to fit and finish will be evident. This is one of the reasons it has taken me so long to finally get to this stage!! :)
  18. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Does the skid plate allow for the small plastic air dam on the 06 and newer Prius? Mine scrapes every day on my driveway, and parking curbs. Maybe if the skid plate could incorporate a small vertical lip in front, it could replace the factory plastic, and be more durable? Just a thought.
  19. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    What I'm thinking is reduction in drag, and increased aerodynamics.... Hmmm, probably not enough to make a great deal of difference, but that plus the protective aspects.... Nice idea BT!! I'll show my wife as the Holidays are approaching!! :cool:
  20. drees
    drees Senior Member
    1,782
    247
    Here's an idea to keep the plate nice and flat (no holes, more aerodynamic) but still retain easy access for oil changes.
    Add a removable plate which is held into place using Dzus fasteners. Here's a pic of what the fasteners look like, they are extremely low profile
    http://www.racerpartswholesale.com/dzus.htm
