Mpg ?
Discussion in 'Gen 2 Prius Main Forum' started by usinchino, Dec 8, 2007.
  1. usinchino
    usinchino Junior Member
    Queen Creek AZ
    We have an 08 prius with 500 miles,when the dealer filled it he reset the miles so we have 440 on the current tank of gas ,the question we have is it shows we are averaging 50 miles to the gallon but there is only one bar left on the gas gauge and it is a 12 gal tank,so is 50 mpg accurate ? hope its not to confusing Thanks to all:eek:
  2. derkraut
    derkraut Member
    299
    28
    SAN
    The fuel guage on the Prius is famous for not changing, and then changing suddenly. To be on the safe side, I always fill up when I get down to 1 bar, rather than waiting until it flashes.
  3. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi usinchino,
    Welcome to PC. The Gas tank has a rubber bladder which help prevent vapor emissions and limits water condensation into the gas. The bladder is made from rubber, so it expands and shrinks with temperature, and also gets stiffer when cold. So, this can limit how much gas actually makes it into the tank (bladder). The volume of the tank can be as little as 8 gallons in real cold weather.
    If you are at one pip on the indicator, get thyself to a gas station now! Many new Prius owners have run out of gas assuming they have 11.9 gallons and the gas gauge is just wrong!
  4. donee
    donee New Member
    2,956
    198
    Chicagoland
    several people have done long term tracking of mileage. They calculate how much gas the miles driven and the MFD fuel economy result indicates, and compared that against how much gas was pumped over months. And have found it typically within 1% but in some cases 2 %. When the tank stretches, the mileage by distance and pumped volume goes down, and when the tank shrinks the mileage by distance and pumped volume goes up. Only when the temperature is constant for the whole driving period are the mileage from the MFD and by pumped volume similar.
    The conclusion is therefore that the MFD fuel economy is quite close to actual, where by gallons pumped can be well off on any single tank.
  5. Neicy
    Neicy Member
    834
    Wakefield, MA.
    The colder the temperature is the less the bladder will stretch. Get gas NOW.
