NAV DVD Upgrade
Discussion in 'Gen 2 Prius Technical Discussion' started by Inches, Dec 12, 2007.
  1. Inches
    Inches Member
    117
    San Mateo, CA
    I just got a v7.1 NAV DVD. I did not get it from a dealer but it is a Toyota part. There is a label on the disk that says "Please follow the instructions on pant bulletin general information 07-37-'07 CY DVD upgrade for navigation systems (see dealer daily)." Is there anything special that needs to be done before this will work??
  2. Sarge
    Sarge Senior Member
    1,324
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Nope... just pop the DVD into the drive under the driver seat, and it will update the firmware and load automatically. The only requirement is that you are using the proper generation of DVD (2007 = 5th Generation).
  3. Inches
    Inches Member
    117
    San Mateo, CA
    That was easy!! I did not loose any of the stuff that was stored. I see the same errors have not been fixed but at least the "I AGREE" IS GONE...
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    So, where did you get it and how much? ;)
  5. Inches
    Inches Member
    117
    San Mateo, CA
    I got off of eBay for 175 FRNs, delivered.
  6. DavidNBerg
    DavidNBerg New Member
    Maine
    I got a copy of an OEM Generation 5 Version 7.1 disc from someone on CraigsList. I checked with Toyota before ordering and was told that my 2006 Prius took the Generation 5 disc. However, with each of the attempts to upgrade (he sent me three disc -- a new one each time the previous one failed) I got an error message saying that the system could not read the data on the disc and to check that I had the correct disc installed. Does anyone have any advice for me?
  7. Inches
    Inches Member
    117
    San Mateo, CA
    When I had a 6.1 I tried several times to "copy" the image on to a DVD+ DL without success, wound up with coasters. That was when I decided to just get one off eBay with the proper part number, it's not worth the hassle but less that from a dealer. Also you might check a junk yard...
  8. dogfriend
    7,512
    1,189
    Carmichael, CA
  9. Dawveed
    Dawveed New Member
    West Texas
    I felt that the 7.1 version was still at least two years out-of-date. I wish this had a way to somehow automatically update on-the-go. Any money that you are paying is too much for an out-of-date navigation map. I have a 2008 Prius and wish Toyota would provide one free upgrade within a specified number of years of ownership.
  10. doubleg2005
    doubleg2005 Member
    236
    what about a 5th gen, v5.1 for $30? ;)
  11. Rest
    Rest Active Member
    1,210
    CA
    I agree! Toyota should provide at least one free upgrade disc. Map data information changes frequently and as you stated an outdated map is useless.
  12. ze_shark
    ze_shark Junior Member
    SF Bay Area
    Has anyone ever tried to put a European DVD into a US car ?
  13. josharmour
    josharmour Junior Member
    28
    The Dalles
    I have an 08 touring prius that has out of date roads and cafes. I went to olive garden in seattle only to find that it already closed a year ago. Why cant we just burn a copy of the new dvd and put that into the unit?
  14. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    If you have an 08, you already have the newest version.
    The data tends to run at least a year behind, sometimes much more.
