BT Tech Stiffening Plate does not improve ride
Discussion in 'Gen 2 Prius Accessories & Modifications' started by John in LB, Jun 1, 2007.
  1. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    While I can't comment on the test, I can say that in my own driving I've found the plate has made a positive improvement with handling. If my next Prius isn't so equipped, I'll get & install another.
  2. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Fascinating to read through the variety of opinions expressed here on PC regarding the merits (or lack thereof) of BT Tech's stiffener plate for the Prius.
    While I personally am sceptical as to its alleged benefits, nowhere have I encountered anyone who has done what to me is obvious. If you really want to stiffen up the underframe, why not install BOTH the OEM plate and the BT Stiffener plate in combination.
    That way, you get double the torsional stiffness and double the tensile strength, at least in that location; or at a minimum, a significant increase over and above the original level. Then go drive the car aggressively!!
    Has anyone tried this solution?
    Ron
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I'm not sure that's actually possible since they use the same holes and different bolts. Plus it definately would not double the stiffness as the OEM plate is so flimsy as to be flexed by hand...I doubt it would add even 1% additional stiffness over the BT plate.
  4. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    This is interesting. The Volvo S60R had a similar bracket:
    The first mod a new S60R owner would do was to remove this bracket completely. The particular bracket was mystery as to why Volvo installed it in the first place. Some said it was to keep the drive shaft from falling off (AWD car) or exhaust in case of catastrophic failure. Some say it was to facilitate the installation of the exhaust at the factory. The problem with this bracket was that it hung low to the ground. It was suceptible to bottoming out. When it did, the bracket would bend upward hitting the exhaust and then push the resonator into the driveshaft. The end result would be $2000 in damage (new exhaust system and new driveshaft). It happened to me.
    S60R ownes would replace the bracket with a cable, thinking that would be enought to hold the exhaust or driveshaft in case of failure.
  5. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    I guess what I am wondering is if the Prius's center bracing is similar to the Volvo's in that it is to keep the exhaust from falling to the ground in the event of failure.
    Here is the bracket before bottoming out.
    Here is the S60R bracket after bottoming out.
  6. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Maybe the center bracing doesn't do anything for stability at all? I don't know, just a thought.
  7. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Maybe. But I think the OEM and BT Tech plates look like stiffening plates:
    PriusChat Shop : BT Tech Chassis Stiffening Plate - $195.00$165.00
    While the Volvo plate looks like a curtain rod bracket.
    In any event, IMO, the BT Tech Stiffening Plate definitely improves the car's handling and stability, most noticeably at highway speeds.
  8. ronhowell
    681
    32
    Cypress, CA.
    If the BT Plate uses the same holes, then all you would need are (possibly) longer bolts. But has anyone tried to combine them? Seems to me such a waste to simply toss the original.
    1% additional stiffness? If that were true (which I don't believe), then the OEM plate was certainly not designed for torsional strength, but tensile strength in the horizontal plane. To which the BT plate adds little in the way of improvement. Not even 1%.
    Bottom line is, BT Tech simply loves all of this publicity for their aftermarket add-ons, from which they make money and put bread on their table. If they have many satisfied customers, more power to them.
    Just label me sceptical!
    Ron
  9. efusco
    19,891
    1,196
    Nixa, MO
    You can, and should be skeptical. But that doesn't mean you couldn't also be wrong. If it adds more than 1 % then it's not more than 5% MAX....and I'd doubt that much.
    Also, it's not as easy as using longer bolts...Unless and until you see how the two plates are made and designed it's difficult to explain, but they will not sandwich together properly and there would be motion between them. I suppose someone might be able to do it, but I still think your premise that it would somehow prove or disprove anything is wrong.
    If maximal benefit from a stiffening is X and the BT plate gives you X+10% stiffening then X+25% (or whatever) stiffening will be no better.
  10. ronhowell
    681
    32
    Cypress, CA.
    Exit subject stage left!
  11. Godiva
    Godiva AmeriKan Citizen
    10,339
    Everyone is entitled to their opinion.
    I *do* feel a difference. And it will be one of the first things I install in my next Prius.
  12. Bobbyb
    Bobbyb bobbyb
    62
    Long Island
    Hi John
    I will not insult nor defend the plate .I will ask one thing of you .Put your words into action put yours up for sale.It would sure make your position
    and conviction more real .I respect the fact you voiced your feelings so well where so many have responded in a not such a nice fashion .Take the higher road .Now take the action to fix a negitive and be done with it .
  13. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Hi Group,
    I didn't read all of the postings, instead jumped to the last page so this may have been covered already. If so I apologize for covering it again. When I got ready to install my plate, I noticed that the stainless washers were a little too big to slide down into the holes. We had to put them on a screwdriver shank and let them spin a little bit against a grinding wheel to slightly reduce their diameter. That could be the reason that two of the bolts are not in the recesses. If so, they are not properly torqued and may be the reason for the plate not doing it's job.
    Both my wife and I enjoy the benefits of the improvement in cross-wind stability provided by the BT plate.
  14. lumpy95
    lumpy95 Member
    420
    72
    Mojave Desert, Cal.
    You should have read the thread, the bolts are loose on purpose to facilitate his test.:)
  15. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    Sorry, guess I missed that one when I read all the posts on the first page then jumped to the last page. We really did have to shave down the washers that came with ours though.
  16. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Taken as a whole, this thread proves only that whether the chassis plate "works" or not is purely a matter of personal opinion.
    Even if there were objective data on the behavior of the plate, it wouldn't put a stop to this unpleasantness.
    What would it mean if the plate stopped 0.0003 in. of chassis flex? What about 0.003? 0.03? 0.3? In the absence of a universally accepted objective performance standard the argument would only shift to whether it was too much, or not enough, or the test was faulty, or the measurement itself was not correct, or as a last resort it cost too much.
    On the road, whether the plate works is a matter of perception, not numbers. And perceptions are as varied as the background, experiences, and even expectations of the buyer.
    Not only is there no one, correct answer, there never can be one. Simply put, "You pays your money and you takes your chances." Get over it, take three deep cleansing breaths, move on.
  17. lumpy95
    lumpy95 Member
    420
    72
    Mojave Desert, Cal.
    :amen:
  18. efusco
    19,891
    1,196
    Nixa, MO
    If it makes you fell better to believe that this is the logical conclusion...then you're absolutely right.
  19. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Indeed, you may be right........
  20. sweetguy
    sweetguy Junior Member
    85
    Maine
    Excellent response -- I concur.
    Perception does not necessarily equal reality
