Average MPG: Reset or Let it Ride?
Discussion in 'Gen 2 Prius Main Forum' started by johnny51981, Dec 26, 2007.
  1. johnny51981
    johnny51981 New Member
    42
    Kent, WA
    Do you reset the overall Average MPG after every fill up, or do you let it ride?
  2. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Let it ride...
  3. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    I just let it ride because it isn't really as useful as my lifetime-MPG spreadsheet.
    Occasionally, I might reset it just to see what I average for a specific trip.
  4. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    I used to reset it at every fill-up to try to get a higher mpg on the new tank, but after several tanks of sub-par mileage (44-45 mpg) I got a 48 or 49 mpg tank and haven't touched it since. That was sometime in early fall, and my mpg since then has been between 47.1-47.3...it varies very little nowadays.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I just let it ride because I don't want to get depressed when I see what my winter mpg's are LOL. Letting it ride gives me a better number since as the car gets more and more miles it takes alot to make it change from the 47.7 lifetime avg. I got now.
  6. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    I use a spreadsheet to track my history and lifetime average MPG. This way I don't lose the information if the car ever needs repair that resets the MFD.
    I use the MFD to keep track of how I'm doing on fuel economy for the current tank of gas so far. It works great to motivate me to keep trying to do better. The only way for that to work is to reset after every fillup. Since the miles resets anyhow, it makes sense to reset the MPG.
    Also since the gas guage doesn't reliably indicate how many gallons are currently in the tank, I can use some quick math:
    (gallons pumped at last fill-up) - (miles traveled since fill-up) / (MPG for this tank) = approximate gallons of fuel until next fill up
    to figure out how much fuel I've got. Additionally I can do some more quick math:
    (approx. gal. of fuel until next fill-up) X (estimated MPG for upcoming trips) = miles until next fill-up.
    This can help me decide if I should stand out in that cold wind to fill my tank now to avoid needing to fill-up during the blizzard predicted for 2 days from now, or if I should put off filling up during the rain, because I can easily make it to the warmer dry weather in a day or two.
    This math doesn't work if you "let it ride":
    9 gallons pumped at last fill-up with 10,000 miles since last MFD reset and 54.5 MPG displayed.
    350 miles driven since last fill-up and MFD now shows 53.8
    If I do the math I get 350 / 53.8 = 6.5 gallons used
    9 gallons pumped - 6.5 gallons used = 2.5 gallons until next fill-up
    estimated 50 MPG for next few trips = 150 miles until next fill-up
    Had I reset at the last fill-up, I'd have seen:
    350 miles driven since last fill-up and MFD would show 40 MPG.
    350 / 40 = 8.75 gallons used
    9 gallons pumped - 8.75 gallons used = 0.25 gallons until next fill-up
    estimated 40 MPG for next few trips = 10 miles until next fill-up
    That's an error in estimated miles left of 140 miles!
  7. ryanschram
    ryanschram New Member
    for me, it doesn't matter when i put gas in, it always resets :(
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i always reset it because i want to know how temperatures, driving conditions and even how different drivers affect the mileage.
    also, a sudden unexpected drop in mileage tells me something is wrong because i KNOW what to expect since i have tracked each tank individually. after nearly 60,000 miles on two different Priuses, there is little surprise for me.
    recently my SO because the primary driver of my Prius and because of her higher comfort needs, our average has dropped 5 mpg!!!
    all because, i rarely use heat, set at 68 if i feel the need. only enough defrost to keep the windows clear. etc.
    she does not want to be bothered with toggling the cabin climate controls like i do, so when i get into the car, the temp is usually set at 80. defrost blasting away, etc...
    so i guess this should be in one of those "why does my mileage suck?" threads... but
  9. Doc Willie
    1,717
    144
    Out there, somewhere
    I ofter reset it each trip. I want to know how I am doing on my hypermiling technique.
  10. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    yeah, i reset every time. i try to improve every tank.
  11. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I have no choice in the matter, either. Is this something that's available now? Perhaps a new firmware? We're talking the MFD average, right?
  12. Rangerdavid
    1,362
    52
    Three Touring
    right, that was my understanding....
  13. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    663
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    The miles will reset automatically, but the MPG Average will not.
    My wife resets at each refill, to check mileage doing here route vs normal.
    So far 30 mpg on the route, & 41 mpg normal, not bad for winter.
    Average 34-35 over all, Double mileage of her last car.
  14. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    Every tank, religiously. I have a spreadsheet for the liftime, and also use greenhybrid.com. Sucks right now w/the cold weather. Well... cold for Orange County... :p
  15. Trevor
    Trevor Member
    352
    Staten Island, NY
    The average MPG resets in the 2005 when you put more than 3 gallons in. In the 2006 the number of miles resets, but the average MPG doesn't reset unless you hit the reset button.
    I found this out a while back when I responded to an '05 owners post and assumed that they had the option to reset or not.
    I used to let it ride, but now I reset every time. I stopped after the first time that I reset it by accident while trying to clean the MFD screen.
