Taking cold showers. Does this help the environment?
Discussion in 'Environmental Discussion' started by burritos, Mar 29, 2007.
  1. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    <div class='quotetop'>QUOTE(tripp @ Mar 30 2007, 12:49 PM) [snapback]414908[/snapback]</div>
    :D
    That's how y'all became parents. hee hee
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    whew... it IS getting hot in here! :blink:
  3. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(SSimon @ Mar 30 2007, 10:59 AM) [snapback]414914[/snapback]</div>
  4. burritos
    burritos Senior Member
    4,946
    253
    So I've still been taking cold showers since I first posted this topic. You get used to it, but the cold shock seems to be more intense in the winter especially if the heater hasn't warmed up the house.(I used not warm it up, but for my toddler, I'll set it up to 69F in the morning.).
  5. Darwood
    Darwood Senior Member
    5,259
    268
    Come and try that cold shower in MN. The tap water is VERY cold. I'd take the time to microwave a bowl of water and a washcloth and use that to get clean or just skip it altogethor before I'd take a cold shower in the winter. Summer's a whole different story. I've taken plenty of cold showers in the summer.
    Multiple people in the shower does not seem to help. Either you get "distracted" or one person is just waiting to get in the stream anyways. I shower with my 4 year and it takes much longer. At least I've gotten him away from baths. I can fathom the whole lather up with the faucet off idea, if you didn't use more electricity in the space heater than you do for the hot water. I would bet it's a wash (Pun intended).
    I'd bet the most efficient way is for the whole family to share one tub of water, as was done in the old days. The parents would wash up, then the kids would go in, and lastly the baby. Hence the old saying "Don't throw the baby out with the bathwater".
  6. darelldd
    6,059
    389
    Northern CA
    69? Are you crazy, man!? Stick a sweater on that kid, and dial the thermostat back down to something reasonable!
    Was talking to a friend who's son has been out of power for a week now. She tells me with great drama that his house gets down to 55° since he has no heat! Gosh... I DO have heat available, and I *choose* let my house get to 55°. As you've noticed, you can get used to quite a lot if you let it happen. My wife, on the other hand, has a comfort range of about 2° In fact I think that number is negative since she tends to like it WARMER in the winter and COOLER in the summer.
  7. galaxee
    9,810
    471
    MD
    we're in a pretty severe drought now, so i only use water to rinse off. it works just fine.
  8. burritos
    4,946
    253
    Our thermostat is off all night. So we do wake up in the high 50's. Then the thermostat will go on at 7 and will heat the house to 69, which takes about 15 minutes. With sunlight that ambient temperature lasts till night, in which the heater might go on again 1 more time for another 15 minutes. The vents are closed in all the rooms except the family room, kitchen, our MIL's bedroom, and our bedroom. My yearly gas bill is about 350-400 a year(for a 2800 sq ft home). Not the biggest cost in the world, and not very damaging to the environment.
    I don't mind my suffering(hence my cold showers and dragging the dirty baby bath water to our compost and lawn), but I'm not going to force my environmental values on my MIL who has graciously taken to task to be our daytime nanny.
  9. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I once had a working heat recovery unit on the air conditioner. (Quick Review - This is just a water pump and a couple of coils that use the heat of the hot freon out of the house air conditioning compressor and transfers it to the hot water tank.) When it is working, I flip off the hot water heater circuit breakers for 8 months and use this. No limit on hot showers....till they are enjoyable. Got to get that thing fixed.
  10. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    great alternative :cool:
  11. WARHORSE
    WARHORSE New Member
    418
    SoBe, FL
    How do you have a solar apartment ?
    I own 3 apartments and I'd love to add some solar panels on them
    my big apt gets a lot of wind and I'd love to find a compact powerful windmill to catch some energy there
  12. galaxee
    9,810
    471
    MD
    these are passive solar apartments- all south facing windows, solar glass (haven't figured out yet what that is), brick floors for heat mass, and a solar water heater setup on the roof.
    they were designed that way, i know nothing of solar panels myself but i'm sure others here can tell you a lot about them. ;)
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i wont give up hot showers completely, but i always run straight cold water for the last minute or so. supposed to be good for you and its very very invigorating in the summer time if its hot out.
    instead, look at low flow shower heads. we installed one and it sprays the water out in a way that makes it not feel like you are being deprived in anyway.
    before we did it, one of us (i take relatively short showers since i have no hair ) would start to run out of hot water if anything else is running. after the shower head ($40 at home depot bought with Xmas gift card) we see no signs of hot water running out (the temp slowly peters out when tank is emptying) even on times when we bring Ryland into the shower which always takes a few extra minutes (dont wanna drop him@!!@)
  14. tripp
    4,717
    79
    Denver, CO
    Dave, what was the flow on the original shower head? I just replaced (about a week ago) our 2.5 gpm (which is the standard size) shower head for a 1.6 gpm (6.0 L/min) one. Cost $12 at the home depot. I take about a 4 minute shower (I timed it, I thought I was taking a 10 min shower...). My wife's last about 10 minutes or so. So we're saving a decent amount of water on showers and the energy (NG) it takes to heat that water. At the same time I bought a blanket (R11) for our water heater (which is located deep in the house). I don't know if it will really do much but it only cost $18 so I figured I have a go and see what it does for us. Unfortunately, I changed two variables at once, but c'est la guerre.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well.... gee. i was gonna say like .8 gpm?? is that right? maybe its 1.8...
    i timed my showers as well and mine were about 5-7 minutes, with SO does about 20...sometimes 30 depending on whether she is shaving anything or whatever else she does.
    as far as the flow on the original shower head, i dont have a clue, but i do know that it was downright painful if you had water on full blast
  16. tripp
    4,717
    79
    Denver, CO
    By the regs show heads are supposed to indicate their flow rates. You've probably already binned it but if you haven't you should be able to find out pretty easily.
    Cor luv a duck! 30 minutes in the shower! How big's your water heater?
  17. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    No, hyo. Just shut up and walk away. Good boy. Whew, that was close. :p
  18. patsparks
    10,664
    567
    Adelaide South Australia
    Main thing a cold shower does for the environment is limit population growth for those in the right age group.
  19. Godiva
    Godiva AmeriKan Citizen
    10,339
    As environmentally conscientious as I try to be I draw the line at cold showers.
  20. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    There is a book by Marjorie Holmes named "God and Vitamins". In it, she proclaims the benefits of not wearing heavy coats, and of finishing off one's shower by turning the water all the way to cold for a minute or two.
    I've done it. Mostly I'll just turn it to mostly cool to rinse my hair (supposed to make it shinier).
    I really do take short showers, anyway. About 10 minutes is a long one for me. I mean... what all is there to do in there? :confused:
