12v battery
Discussion in 'Gen 2 Prius Main Forum' started by parky, Jan 21, 2008.
  1. parky
    parky New Member
    51
    montana
    my question, to those in cold climates. My wife ran errands on an Sat and Sun nite the temp went down to -16. Mon morn the battery was dead. Service manager said this is not unusal. The battery only has 300 cold cranking power. Typically 600 is recommended in Montana. No other battery is available. Plus, the battery cables are in the trunk and I can't unlock it with the skinny key which only unlocks the drivers door! Is a trickle charger recommended, and any recommendations? Right now, I am not recharging the battery to see if it comes back, I doubt it.
    Also, we are only coaxing 35mph with our less than 5 mile trips in 5/10 minutes during the cold days. This is not a car on short runs for cold climates.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It's posts like this that make me lose sleep.
    1) it is unusual for it to die that soon, regardless the temps. The battery may be bad/old/nearly exhausted but the cold is not an acceptible explaination.
    2) The 12v battery is not responsible for any 'cranking', thus it does not need any high power high 'cold cranking wattage'...you've got a 201V battery responsible for all the 'cranking'...the 12v mearly turns on the computers and closes the relay that brings the HV battery online.
    3)The trunk can unlocked from the inside, but you need to crawl back there and remove one panel that covers access to the little release. In any case, once you crawl back there you can just grab your cables and not worry about opening the hatch.
    4) With a 5 mile commute that sounds like it's mostly highway it'll be tough to get much better, but it should be doable. If you're in an area that gets down to -16 it's very much worth it to buy and install and use an engine block heater.
    --evan
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My first winter with my Prius, I started to have 12 vdc battery issues as well. I blame that on the -40 temps, constant use of Max heat, auto headlights on, and constant use of electric rear window and mirror defrost.
    It's important to consider how the Prius charges the 12 vdc battery. A conventional vehicle, like my 2007 FJ Cruiser, has electronic voltage regulation and a huge alternator. If necessary, it can pump +60 amps into the battery
    The Prius has a constant voltage source for charging, so once the 12 vdc battery is depleted (Headlights on, Max heat and hi speed HVAC, electric defrost, etc), it's actually very difficult to get the battery up to proper charge. I suspect there are a few Prius cars out there with chronically undercharged 12 vdc batteries
    I solved my battery problem by getting several VDC Electronics Battery Minder float chargers/conditioners at auction. This is the older Battery Minder model that only desulfates once float charge is achieved
    I used the supplied VDC harness to hook up directly to the 12 vdc battery. I used to have a condo with heated underground parking, now I have a house with a heated attached garage. Either case, I plugged in the VDC overnight, or whenever the car sat for more than half a day.
    The Prius PDI is pretty emphatic the car 12 vdc battery be fully charged with the Toyota automatic battery charger. There is nothing special about the Toyota branded charger, it's a 10 amp model made by Associated. Any good automatic battery charger set at 10 amp will work
    Given you have stated in your avatar that you have a 2008 model, I'm wondering if the dealer followed the PDI? If not, this is fairly easy to fix yourself
    You don't have to monkey around with crawling into the rear hatch to manaully release the catch. Pop the hood and hook the battery charger directly to the jump start connection point, as documented in the owner manual.
    This should be a dealer issue though. If they appear incompetent or are unwilling to properly charge the battery, you must do so yourself. It's a very small battery, think motorcycle size, so it won't tolerate much abuse or discharge
    You may still want to consider a battery tender. New, they are around $70 from VDC. Price a brand new battery, and you will find the battery tender is cheap insurance.
    *12 Volt-1 Amp* Charger and Maintainer
    Unlike regular battery chargers, the Battery Minder may be left on indefinitely. I use them on the diesel tractor and Ford plow truck at my hobby farm, they are always plugged in
    As our Grumpy Old Moderator (tm) (c) suggested - btw I'm older than that young whipper snapper - that isn't bad fuel economy for the trip length and temps.
    I used to have a 2000 GMC Sierra with Vortec 5.3. City driving at -40, I was lucky to get 6 MPG. First winter with the Prius, 28 MPG at the same temp. Once I made a winter front for the Prius, that increased to 38 MPG.
  4. parky
    parky New Member
    51
    montana
    Thanks, Grumpy. Are you ABSOLUTELY sure that 12v doesn't turn over the engine. Because if it just fires up the computers then I can understand that the 12v might have a defect. I am only getting a dim light on the ceiling lts. That battery size/design would explain why it is not used to turn over the engine. Dealership will hear from me again.
  5. efusco
    19,891
    1,196
    Nixa, MO
    I'm absolutely sure, MG1 is what spins the ICE and MG1 gets all it's juice from the HV battery.
  6. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Yup,
    There is NO 12v starter on a Prius. The Motor-Generator in the flywheel uses the 200v system to spin the engine up to speed to start the gas engine. As others have said, the 12V battery just boots the computers, then 12V is supplied by the DC to DC converter to run the low voltage systems and charge the battery.
    Also, you don't need to open the rear hatch to jump the car, there are jumper cable tabs under the hood on the drivers side upper corner under a black cover. Check the manual.
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    And just to reiterate what Evan said, I have had NO problems with my 12V battery. This is Pearl's first winter, and I purchased a battery tender, "just in case". I haven't had to use it, so far. Do use the charging point under the hood. Clip the +ve there and the -ve to the bolt just above it on the firewall. Do so asap. The longer you leave a lead-acid battery discharged, the more damage it will suffer. Be aware it's not inexpensive! Somewhere around $300, depending on how greedy the dealer is.
    The 12V battery is charged by a battery charger circuit built into the main inverter, that powers the "electric portion" of the hybrid system. It keeps the 12V system at 13.8VDC, which, at below freezing temps. is not enough voltage to fully charge the battery - you really want around 14 - 14.5V at really cold temps.
    However, even saying this, your battery should not have died. Mine has not, and it's colder here than in Montana. Check all interior lights (the hatch light, for example, can be left on). BE SURE to exit the car from the drivers door, or at least open and close it after you shut the car off. If you do not the headlamps will stay on.
  8. richard schumacher
    7,682
    1,064
    United States
    Parky, a young 12V battery would die only if it had been drained or otherwise abused, or if there were a fault in the charging system (which a dealer ought to be able to find very quickly). At this point your only option is to get a new battery and avoid killing it.
    Always lock the car; that way if you leave a domelight on or the rear hatch ajar (which will drain the battery overnight) the car will give a long warning beep. Also I'd advise not using the headlight auto-off feature. It's too easy to get out of the car in the wrong sequence, which results in the headlights staying on and a dead battery.
  9. parky
    parky New Member
    51
    montana
    Actually, it is the cables that I need (my extra long ones, as the car is in a garage) which are under the floor in the back. Personally, at this point I don't see why people need a trickle charger in cold climates. There can't be that much of a draw on the battery: except for one thing, short errands which don't charge up the battery. Thats me, a mile there, a mile back, etc. By the way I did crawl into the back, rolled the dog bed up, lifted the rubberized (stiff) floor mat, then the rug, and got into the space underneath. I just want to get the battery out so I can go and have it charged completely. My charger is at our summer cabin.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Yes, we are absolutely sure
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I've always had battery trouble in cold temps of -30 C and colder, no matter what the equipment. A lot of that has to do with the fact most batteries will become chronically underchaged at those temps, due to the extra demand
    Once a lead acid battery becomes chronically undercharged, sulfation will occur on the plates. With sulfation, the battery will never become fully charged, will discharge easier, and the cycle repeats until the battery croaks
    I'm pretty happy with my VDC Battery Minder units. The replacement battery on my diesel tractor at the hobby farm is just as expensive as a Prius 12 vdc battery. I've replaced the thing twice over the past 10 years, but this latest replacement I started using the Battery Minder on it
    One thing I immediately noticed - with full time desulfation on the battery - is that the motor cranks *much* faster than before. If the VDC claim of at least twice the usual battery life proves true, the unit will more than have paid for itself
    One thing about short trips: with conventional vehicles like my FJ, the electronic voltage regulator can really pump a lot of amps into the battery to try to keep it charged. A side effect of these fancy new high output alternators is that folks can get away with a marginal battery a lot longer
    But nothing is free. The folks who try to get more life out of a marginal battery in a conventional car/truck end up cooking their expensive alternator instead
    If I were you, I would remove the 12 vdc battery from the hatch, and hook it up to an automatic battery charger set at 10 amps. Don't put it back in until fully charged, this may take a few hours
    Somewhere here I posted the official Toyota PDI on how to properly charge the 12 vdc battery
  12. parky
    parky New Member
    51
    montana
    I am use to conventional engines so this is a learning experience for me, plus I am old school. With a little research I am beginning to understand the mechanics of this machine.
  13. parky
    parky New Member
    51
    montana
    thanks for the info, from your email and another I understand this little
    12v system needs some TC in cold weather. My dealer tells me they get a lot of calls regarding dead batteries (in the winter), "not an uncommon problem".
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    I'm wondering if that dealer is not following the PDI? It very clearly states a Prius must be delivered with a fully charged 12 vdc battery.
  15. parky
    parky New Member
    51
    montana
    Thanks for those numbers. Next purchase is an amp meter. This is like the ol' days when it was possible to work on your own vechicle; then I caried a tool box in the trunk/break down on the road- no problem! I have seen more articles on this battery than anything else - does Toyota read the PriusChat? You say you charge with the Battry Minder (which I now have) on those under the hood terminals. I read that are for jump starting only. Some one else puts a lead on the battery terminals and plugs into that.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    The VDC Electronics Battery Minder comes with a harness to connect directly to the battery. I hooked mine directly the the battery in the hatch. When I plug it in, I open the hatch, run the harness outside the car, slam the hatch shut, and plug it in
    On my FJ Cruiser, I hooked directly to the battery and run the harness out the grille. It's very easy to hook up, and the VDC harness comes with a 5 amp inline fuse as a safety precaution
  17. David Beale
    5,963
    1,989
    Edmonton Alberta
    The problem with putting the leads on the battery is one of access. If the 12V battery is dead, it's a real pain to get at it to plug in a battery tender. The under-hood point is the same as across the battery, just with a 100 Amp fuse in-line and some cable. It can be accessed without worrying about things like leaving the hatch open, releasing an electric lock, etc. You can leave the hood open with no lights on.
    The only thing you should have to worry about is whether your charger will damage any electronics in the car. A battery tender will not. Some other chargers might.
    So it's a matter of convenience. Personally, I think the under hood point is most useful. Plus, as you're nowhere near the battery, you probably will have no chance of igniting the H2 it can generate, if there's a problem.
  18. parky
    parky New Member
    51
    montana
    That's the direction I am going in Thanks
  19. parky
    parky New Member
    51
    montana
    Good point about under the hood because once my battery is dead I can't open the rear hatch. I just wish they had not put the two terminals
    (+/-) so far apart. I have a battery tender made specifically for this motorcycle battery. It may be possible that I have a long enough lead off the battery that I can hang it outside the hatch cover; it also has a cover on the exposed end.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    So it's still dead?
    Right, it's a royal PITA to get the hatch open with a dead battery, especially in the cold. A motorcycle battery tender should work just fine, what is the model?
    If I recall, the harness for my VDC battery minder is almost 2 ft. That is long enough to put the harness out the hatch with maybe 2 inches to spare
