Home water treatment
Discussion in 'Environmental Discussion' started by tripp, Jan 22, 2008.
  1. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Alreet lads an lassies...
    So we had somebody from Rain Soft come by our house last night and look at our water and do the song and dance about whole house water treatment. Seemed pretty cool, but it ain't cheap (though they do point out ways that you save money with filtered water). I never like to just dive in so I wanted to do a bit of research on the subject and naturally thought of PC'ers. Does anybody have first-hand experience with this sorta thing? I'd love to hear your comments and suggestions.
    Thanks.
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I have had extensive experience with several water softening companies.
    Most of them, not that impressive.
    The only softener I would recommend is Kinetico.
    I used to live on a farm where the water was harder than the ground...
    Culligan, Rain Soft, and one other I can't pull up now could not even begin to touch it (and, the Rain Soft system corroded within weeks).
    The Kinetico worked, and worked flawlessly, for over 5 years.
  3. tripp
    4,717
    79
    Denver, CO
    Thanks Rae Vynn. That's good to know. Do you know what the hardness was, out of curiosity?
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I noticed that Kinetico uses the water flow to power the electronics. I like smart engineering.
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I much prefer water you don't have to chew first. After moving from the Prairies to the coast, I have no complaints at all with what comes out of the tap. Do you get enough real rain water to store in barrels, at least for the plants?
  6. tripp
    4,717
    79
    Denver, CO
    I'll probably do rain barrels at some point. Technically, they're illegal in colorado but I doubt that anyone would gig me for it.
    I'll have to check out Kinetico. Thanks for the tip guys.
  7. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    our hardness level was 52,000 PPM.
  8. Rotorhead
    Rotorhead New Member
    79
    Kalamazoo, MI
    Kinetico gets my vote. We have their water softner and their RO filter for our drinking water.
  9. tripp
    4,717
    79
    Denver, CO
    Is it something that goes under your sink? Can you tell me what the model number is? I'm intrigued by the whole house setup, though they all seem to be pretty pricey.
    Rae vynn, that's WAY off the charts!!! 10.5 grains/gal is "very hard" water. 3034 grains/gal is, uh, quite hard. Are you sure you weren't drinking limestone?
  10. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    Tripp - it depends on what you are trying to solve for.
    It sounds like hard water for you. While I can't speak for softeners, we have a whole house filter that filters for basic particulate and chlorine. This is nice because it keeps chlorine off your body in the shower and also out of the air from the steam in the shower (ie - inhalation). Then on our kitchen sink I have an additional GE filter that filters pesticides, etc.
    I really wanted a water a whole house filter that could do it all, but sadly couldn't find one. There are basically 2 NSF standards - one for odor and taste and one for chemicals/purity. The throughput on the chemical/purity filters is apparently so low that you really can't get it for whole house (at least not that I could find for our water volume).
    Anyway, here are a few of the more interesting bookmarked webpages I saved. Use at your own risk / discretion...
    NSF Certified Products - Drinking Water Treatment Units
    A guide to help select the best drinking water treatment methods to treat tap water
    Water pseudoscience and quackery
    Drinking Water Treatment Methods
    Good luck!
    PS - although for drinking water I think reverse osmosis works the best (in terms of taste) you are probably aware they waste several gallons for every one purified.
  11. tripp
    4,717
    79
    Denver, CO
    Tim, thanks m8! I'll have to dig in. Didn't get a chance last night, USA v Sweden replay was on. Gotta have your priorities.
  12. etyler88
    etyler88 etyler88
    450
    Dover, DE
    I did a standard soft water treatment system, using salt, from this place:
    Water Softeners - Water Softener - Commercial Water Softeners - Saltless Water Softner - Water Conditioner Purifier
    I've got medium hard water, 9 grains? memory is foggy. Did research and the Fleck brand valves were mentioned to be much better than stuff sold at big box stores. Website above sold Fleck and was very easy to deal with. My house is 4 bedroom 2 1/2 bath and the system cost about $500 installed by me. Six months and no issues, works great, I'll probably use one maybe two bags of salt a year @$5 a bag.
    Salt soft water systems do alot of filtering but they also sold an add on fancy filter which I did not buy. Calcium was my problem and it is gone.
  13. viking31
    viking31 Member
    515
    22
    West Central Florida
    One thing I noted on the page directed above is that it is a clock system. In other words, it regenerates the resin bed on a set time regardless of use (every three days or every four days...). For a somewhat more, but I think it is well worth it, get an 'on demand' system. It only regenerates when a certain amount of water passes through the system (depending on the hardness setting you program into the softener) and therefore is much more efficient at its salt use. The on demand system still has a clock but it uses it only to regenerate the bed in the middle of the night when it is unlikely you will be using any water (regeneration usually takes a few hours).
    Rick
    #4 2006
  14. FailedExistence
    FailedExistence New Member
    Arizona
    We have a Rayne Water system ... had multiple people out and weren't as impressed with any of them as much as we were with Rayne. Their equipment also comes with a lifetime warranty which helps to put to ease the pain of the initial cost.
  15. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    huh? whats that about? why on earth would rain barrels be illegal?
    i have several hooked up - they're great for the garden.
  16. tripp
    4,717
    79
    Denver, CO
    Because of the way western water law works. There are water propriations on pretty much every watershed in the state. By storing water in rain barrels, you're making an illegal appropriation in the water shed. It's the same reason that you can't take rain from your roof in store it in cisterns for domestic use. The appropriation system is based on seniority. "First in time, first in right" about sums it up. Mind you, no one would gig you for it, but technically, it's illegal. Stupid, ain't it?
  17. GreenLady
    GreenLady Member
    163
    Denver, CO
    Gotta love the "first use" doctrine (or whatever it's called; my memory is foggy of my environmental law class......) A way a friend explained it to me is that somebody else already owns a drop of rain that falls on your property. :eek:
    Anyway, do you know what substance is used to soften the water, Tripp? I'm sure the technology has advanced since I took my freshman chemistry class, but I seem to recall that water softening systems increase the amount of sodium in your water, which is a concern to some.
    I've lived on the Great Plains for pretty much my entire life, so I'm used to hard water. I actually think soft water feels slimy.
  18. tripp
    4,717
    79
    Denver, CO
    They don't own it. In western water law no one owns the water. They just have rights to apply a certain amount of water towards a "beneficial use", you know, like 400 ft tall water fountains in Vegas. Everyone benefits from that. :rolleyes:
    Yeah, it's sodium (NaCl) that replaces the Calcium. I've defo got mixed feelings about it and have decided to not go forward at the moment.
  19. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    There is the potassium chloride option instead of regular salt.
