What does The "B" On The Shifter Mean???
Discussion in 'Gen 2 Prius Technical Discussion' started by UGLYTRUK, Jan 24, 2008.
  1. UGLYTRUK
    UGLYTRUK Rented In Florida For 1 Week
    NE Uppa' US
    I just rented a '08, and it has no manual. Not that I would have' read it! I thought it might be "battery", but it doesn't seem ta change anything...
    See it here...
  2. KMO
    KMO Senior Member
    1,809
    585
    Finland
    2023 Prius Prime
    Quick answer - "Braking". It increases the drag when your foot is off the accelerator - partly by engine braking. Use it to help maintain control and relieve wear on the brake pads when going down a steep hill.
    Someone will come along with the complex answer shortly - but that's for anoraks and efficiency obsessives, which I suspect you're not. ;)
  3. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Here's the complex answer: http://techno-fandom.org/~hobbit/cars/b-mode.html
    One-handed driving w/ narration and controlling a camborder at 100+ MPH? I'm glad I wasn't on the road near you!
    Also, FYI, the Prius has a software-limited top speed, so not much need to test it ;)
  4. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    "B" stands for engine Braking. You might use it like a lower gear when going downhill. I wouldn't bother. Most Prius owners never use it. I've never used it in 11 months of driving my Prius. If you're going forward, just keep in Drive.
  5. moregas
    moregas New Member
    58
    Denver
    Better not use that B mode, the FL police is looking for you...Keep going fast. Go Prius ;)
  6. UGLYTRUK
    NE Uppa' US
    Piece a cake... Wish I could have' gone faster... LOL!!! Ug
  7. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    "B" is for Bad mileage :p
    Its primary function is to make loud noise and waste gas. Funny they didn't label it "V8" :D
    Rob
  8. GreenLady
    GreenLady Member
    163
    Denver, CO
    Thanks for the link! The take-home message I got is to use the "B" mode when highway signs instruct truckers to use lower gear. (Gotta love all those signs on I-70 west of Denver.) :)
  9. Ichabod
    1,794
    Newton, MA
    I-70 west of Denver is EXACTLY what B-mode is designed for. I was actually going to write about that stretch as an example. ;) It's pretty fun flying down that road into Utah, but I haven't driven that one in the Prius yet. That'd be a nice 90 MPH warp-stealth glide... maybe it's time for a road-trip!
  10. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    'B' works so well there!!! Hwy 119 west of boulder is another great place to use it. It's useless in Florida!
  11. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    "B" means BEWARE!!
    BayPrius likes this.
  12. Ichabod
    1,794
    Newton, MA
    B means "Bewitched" mode. It's great for when you find yourself low on mana.
  13. jrfaris
    jrfaris Member
    352
    Windward Oahu
    When I was young, we had a 57 chevy that had a GR shifter position which stood for Grade Retarder. Folks said it was for the noise it made when we used it.
  14. DC Prius
    DC Prius Ganzo's Driver
    Washington, DC
    A comment and a question on the B shift issue:
    1: Coming down a long and winding mountain road in Shenandoah National Park, I used B the whole way down. Then, for a few days, every time I let up on the brake pedal, there was a squeak. Sounded like the car needed WD-40. After a week or so, it went away. What's the deal?
    2: When the engine turns on and off for no reason (other than to charge the battery, I suppose) does it use gas? (This may be a really stupid question...) If so, is there a way, during hohum city driving, to force it not to do this?
  15. Ichabod
    1,794
    Newton, MA
    1. I doubt if there's any causal relationship between a braking noise and the use of B mode.
    2. Don't worry too much about it. You can make yourself familiar with the warmup stages of the Prius, which require different behaviors from the system at different times. Your best bet is to get yourself into stage 4 of the warmup cycle as early in the drive as possible. Then you can minimize engine use. The engine cycling is really never for "no reason," even though sometimes you don't want it on ;)
  16. qbee42
    3,076
    The squeak was probably from extended use of the friction brakes coming down the hill. Regen and B mode can only do so much; after that it's friction. You probably polished them a bit, and they squeaked until the glaze wore off.
