Why is it so hard to locate a car!
Discussion in 'Gen 2 Prius Main Forum' started by gregzgurl, Jan 24, 2008.
  1. gregzgurl
    gregzgurl New Member
    Does anyone living in the southeast area know of an honest dealer who will help me locate a certain car? I found one in the right package that I want on toyotas online inventory and when I called around to local dealers, they ask for a deposit before they will even track the car, and they still are unsure if they can even trade with the other dealer once they find it. So basically they want my money to ensure I buy from them, but what if they cant get it. I called Toyota's corporate office requesting an inventory search, and they told me that they dont keep inventory! Ya, sure they don't. Arg! :mad:
    They shouldn't make it this difficult to buy from them.
    Do any of you nice priuschatters work for Toyota or know someone that does and can tell me where to find it if I give you the specs? ;)
  2. Omi
    Omi Burlap Jockstrap
    47
    Clearwater, FL
    Give Stadium Toyota a try. They are in Tampa, FL. We have bought two Prius from them and have had fantastic luck with them! Their number is 813-872-4881.
    The problem that the online site has is that it does not always show that the car you are seeing might already be allocated to a dealer for a sale. If that is so, then dealers have to "wheel and deal" with each other to try to get the car. That could be why they won't do this for you w/o a deposit. The dealers do have inventory reports though from distribution (which is in Jacksonville, FL), so they can check out that report for you, but this may also be from the deposit angle as well. As I said above, try Stadium Toyota. I have talked to most of the Toyota dealers in this area and they were the best dealer for us.
  3. skguh
    skguh Member
    195
    Montgomery, Alabama
    Did you consider that someone else may have already ordered the one you feel you deserve?
    It took me 5 months to get the Prius I wanted because the entire inventory--at least the part that I was interested in--was spoken for. Supply and demand... Demanding supply doesn't seem to work all that well.
    After you slide down of that high horse, consider working with a dealer to spec out the car you want from the factory. There's a REASON these cars are difficult to buy, and it's not because the dealers are out to get you.
  4. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    If you know where the car is, I would also consider contacting them directly. If they're willing to make a deal, why not just go get it? Plane tickets are cheap, and the drive home makes excellent Prius/Driver bonding time
    Rob (who drove his Prius 1800 miles home from Indiana!)
  5. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Wow, you had the potential for a great post there, let me help you with editting a bit....
    There, informative with little to no vinegar! /puts on best Julia Child voice "Bon appetite!"
    Gregzgurl, I would say that you may have to put a deposit down, but if you opt not to buy from the dealer, you do get your money back (it is refundable). I'm guessing the angle is that if you want them to do the legwork, they'd like to have something "to hold onto" in the hopes that you seal the deal with them (and not another dealership). Just business, nothing more, nothing less.
    I thought (in another thread....) that someone mentioned Costco as an alternative. If you have one near you, you might brave the Costco lines and see if they can give you what you want. I've not done the Costco route, but you might be able to go in and say "I want a package #2, Barcelona Red" and they can go get it from the dealer who has it.
    Just a thought/another avenue to explore.
  6. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Try carsdirect.com. Enter zip code, and options you want and local dealers will notify you. I completed the process the same day I registered. Drove 50 miles, wrote the check and was out of there in less than 1 hour. Easiest car I ever bought, and that was back in '06 when supplies were tighter. My only concession was color: wanted blue, settled for white, no big deal.:D
  7. gregzgurl
    Thank you for your helpful responses. And thanks codyroo for the nice edit. I'm glad you all have had a good experience when purchasing your car. I hope this one will be for me too. I guess I'm just a little nervous about toyota b/c my last camry purchase through my local dealer was horrible....so I started looking elsewhere this time and I've already had a few dealers being dishonest (one told me there was no such thing as a touring).
    I really do like Toyota cars and am in love with the prius. I do understand supply and demand and have been carless waiting for the inventory to grow to buy one. But I'm in no hurry and the right car and deal will come along....eventually. :rolleyes:
  8. LiquidDonut
    LiquidDonut New Member
    Evansville, IN
    This may be a stupid question, but how do you search new car inventories on toyota.com?
  9. rojaygator
    rojaygator New Member
    Life is like that sometimes. Keep a positive outlook.
  10. gregzgurl
    Liquiddonut,
    If you go to toyota.com, click:
    -prius
    -build
    Then enter your zip
    Then select the color and options you want
    you will get a list of what is available at your local dealer and also what is available in the southeast.
    Hope this works for you! :p
  11. donee
    donee New Member
    2,956
    198
    Chicagoland
  12. Thunderbolt
    Thunderbolt Junior Member
    Worthington Springs Fl.
    Gatorland Toyota in Gainesville, talk to Frank Whiteacre. I went in looking at used, finally decided to get new. They had one, then decided it did not have cruise package 2 which I had to have. They had some in Ocala at Deluca, I told them on the phone that I was on the way to Ocala to buy one from them. They paged me while I was enroute and said the would have one in two hours. They did what they said and sold it to me for less than Deluca was going to. Said it was the fastest locate that they had ever done. Tell him to give you the $50 off that he promised me if I send him a customer!! He will know who I am.
  13. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    Gregzgurl, I went thru Costco to Palmbeach Toyota, they gave me a song and a dance back in Aug 2007, saying there is too much demand to make a Costco deal. I went on my own to Lipton Toyota in Ft Laud, they took a deposit, but couldnt deliver. Got my $500 deposit back...Was just nosing around on Toyota.com one day and saw the package I wanted except in a different color, which I'm happier with now, at Delray Toyota. The salesman didnt even know he had it on his lot, so when he confirmed he had it there unclaimed I zipped down and picked it up that night. Now 2 month pround owner of a 2008 touring package 6 in Spectra Blue Mica, the absolute uncontested best color Prius:D.
    So, as you say, It will come.
  14. gregzgurl
    Thanks John and everyone else! I do like the spectra blue, you do not see many of those up here in the panhandle. But red has always been my FAVORITE color. I too looked for black as a second color but after seeing one, it was a little masculine for my taste.
    It's great to hear from all you fellow Floridians. I thought everyone on here was from CA. I'm definitely going to try some of ya'lls suggestions on dealers. I also found a dealer in GA today that seems promising...we'll see!
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I live in the Tampa area. Why would you assume a dealer is going to spend any time helping you with no money down? I wouldn't. Do you know how many jackass tire kickers they talk to a day? Stop whining and slap down some cash. I put $ 500 down with a local dealer (Clearwater Toyota) with the caveat they need to find my car in a few days or money back and they found exactly what I wanted in 24 hours (hint: There's a huge parking lot at the Port of Tampa where there's a big bunch of Prius's looking for a home) yes thats right I rolled out of there the next day with the car I wanted. Package & color. Get it? It ain't magic dude ...its called business
    not please waste my time.
  16. dealerbadger
    dealerbadger New Member
    Chicago
    It is difficult for a variety of reasons. First, they are selling very well right now. As a result, dealers don't have many in stock. Also, if a dealership happens to have Prius' advertised as being in stock, chances are he sold them before the ad was even published. Lastly, many times dealerships will tell you they have vehicles in stock or inbound just to take you off the market. They believe if they tell you they have your car there or coming in soon they will be able to keep you as a customer until they can produce the car because you are under the assumption they have it. I worked in the sales department for Toyota for over 5 years and still have access to manufacturer sites that allow me to check availability of vehicles as well as see the true pricing. I may be able to help you out.
  17. Jiffylush
    Jiffylush New Member
    North Carolina
    I am in the Charlotte, NC area, its the Southeast but not quite as south as you ;)
    Basically I was in a wreck and my car was totalled.
    Here are the steps I went through to get my prius.
    The wreck happened Wednesday night, I test drove a Prius on Saturday. Told the dealer what I wanted (color and package) and he gave me a print out for one that would be coming in soon.
    Found out my car was officially totalled on Wednesday, made a deposit over the phone. Car was in stock at the dealer friday night, I picked it up Saturday morning.
    It seems strange to me that they won't look to see when they can get one in unless you make a deposit first.
    By the way my dealer was Town & Country Toyota, and I just went there because it was right across from the light-rail station that I use.
  18. LiquidDonut
    Evansville, IN
    I tried that typing in a Florida zip code this time and now see what you mean, the southeast gives an entire inventory which is really handy. Unfortunately I live in Southern Indiana which is in the Chicago Region and they don't have an inventory system like the Southeast's, too bad though.
  19. gregzgurl
    Hey Tampa Dude,
    I didnt realize some dealers saw this as a waste of time...I see it as customer service. But yes, I'm not in their shoes, so maybe I wouldnt know.
    And I understood the whole deposit business, but I didnt know it was refundable until another person nicely informed me. I thought I had to pay all these dealers to find a car and never see the money again!
    That's great you live in south Florida, you have a much better market. Up here in the panhandle has been difficult.
    But anyways, I'm not sour anymore b/c I found a WONDERFUL dealer in NC who is actually offering to ship it to my door!
    Sincerely,
    Dudette
  20. MarkMN
    MarkMN New Member
    226
    Downtown Minneapolis
    So that they can make a sell. I expect my dealor to talk to me about the car, show me the showroom car, let me test drive one in the lot, and let me know when and if I can get the car I want before I give them a check. It doesn't matter how 'hot' the car is or how hard it is to find one.
    Then I wouldn't buy from you or your dealorship (or other business) ever. Eventually, you will probably get fired for not making any sales.
    No, its called competition. The dealors should be competing for your money and your business - you should not have to compete for their attention.
    I talked to my sales guy a year ago and asked to see a Corolla and a Prius. He showed me and my wife both cars, showed the features of both cars, let me test drive both cars. After deciding on a Prius, he went through their order list for the next two months and showed me the cars that they were getting in and still had available (and there wasn't much available). I told him I was pretty set getting a Package 2, no more/no less, and wanted the color black. He said that he feels like he could track down that car for me during the next few weeks, and when he found the car, he would call me, I would give them a 200 dollar deposit, and when the car arrived we would close on the deal (and I could back out at any time, and if I wasn't satisfied with the car that they brought me, I would get the deposit back - they wouldn't even cash it). The deposit was just a good faith effort on my part.
    Three days later, they found the car, said it could be in a week. He told me that I could go down to the dealorship, work out a verbal deal on the final price, and give them a 200 dollar deposit. At the dealorship, I told him that I talked to 'so and so' at the 'other dealor' who called me back that week and was willing to give me 700 dollars off MSRP and I would appreciate if he could just match that, He said no problem, I gave them a deposit, the deal was closed the next week.
    Now mind you, I did talk to three internet salespeople and 2 other dealors over the phone the day after I saw my salesman to get a feel for deals and availability, and only one other guy was willing to talk on the phone and look up availability for me (it took him at most 10 minutes), so not everything was easy for me, but do not compromise for crappy customer service.
