parking light on EU models
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Flying White Dutchman, Feb 1, 2008.
  1. Flying White Dutchman
    4,376
    313
    i cant seem to find the parking light
    the us manual i donwloaded from a link here says the parking light is on the light switch
    but in my EU model there is only2 settings
    daylight and nighlight.
  2. The Tramp
    The Tramp Italian Prius Expert
    376
    52
    Turin, Italy
    2020 Prius PHV
    On the right lever - you have three settings: OFF, Park, ON.
  3. Flying White Dutchman
    4,376
    313
    on the ricght is my wiper control
    you mean left?
  4. The Tramp
    376
    52
    Turin, Italy
    2020 Prius PHV
    Yes, I meant left.
  5. Flying White Dutchman
    4,376
    313
    ok
    wel i only have the setting OFF,Dimlight and the biglight
  6. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Dim light is parking light and big light is the headlights. If you are trying to illuminate the parking lights on only one side of the car, i.e., only on the driver's or passenger's side, as I could do with my old MBZ, the Prius does not have the ability to do that.
  7. Flying White Dutchman
    4,376
    313
    wel when i put on the dimlights and shut the car
    the back licence plats light stay on!
    and on the dashboard the dimlight signal stays on!!
    i lockt the door with the remote!
  8. IsrAmeriPrius
    4,333
    Southern California
    You are going to run down your 12v battery. There are numerous threads on that peril.
  9. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    In the U.S. versions, that is what is supposed to happen.
    "Parking lights" turns on front amber (or what ever color they are) "parking lights", rear license plate light, taillights and the instrument panel illumination. Reason for rear lighting: If you are parked and need the parking lights, will you be more likely to be run into by a car from the front, or a car from the rear that doesn't see your's because all rear lighting is off?
    I agree w/ IsrAmeriPrius' statement, that due to the Prius' small (miniature) 12 v battery, leaving parking lights on and car off will quickly run down the battery. (That is unless you perform a LED mod.)
  10. Flying White Dutchman
    4,376
    313
    i am working on the led mod;)
    just waiting for some good led to get here by mail.
    when i put the car in parking light
    i expect the licence plate lights to go of.. when i shut the doors and leave the car parkt over the night.
  11. Jon the Chief
    Jon the Chief Jon the Chief
    Wolverhampton UK
    I think the discussion is at cross-purposes.
    The parking lights being looked for could be the German style were only one side of the car parking lights come on for on-street parking.
    From the off position you turn the switch to the left, the first position is only the right side lights, turn to the left one more and you have just the left side lights on.
    From the off position the turn to the right is the normal sidelights, then the headlights.
    This is the Merc system not Toyota.
    Jon the Chief.
