Happened to me too: 12v battery died.
Discussion in 'Gen 2 Prius Main Forum' started by paulccullen, Feb 2, 2008.
  1. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    After two and a half years of trouble-free Prius driving, it finally happened to me too :(.
    I left my car parked at SeaTac airport for 5 days, arrived at back the airport parking lot early this morning (after a delayed flight from Chicago, but that's another whole saga :( ) and the battery was so weak I couldn't open the hatch, or start the car. Pressing the unlock button on the key fob would make an anemic buzzing like a solenoid was struggling to close.
    I got a jump from a guy at the ShuttlePark2 lot, it was entertaining to watch his puzzlement when I said the car had booted up.
    Him: "But the engine didn't turn over!"
    - pause for a few seconds -
    Me: "There it goes"
    So now I bought a "Motor Trend Mini Jumpstarter" for $44.99, and attached a bright yellow chord to the emergency release lever below the rear hatch so I can open it from the inside. Just in case this happens again.
    But what caused the flat battery? The car was locked with no lights on.
    I searched thru all the other threads on the same topic for a clue. There doesn't seem to be a clear answer, except that the Prius has a small battery, making it especially prone to being drained.
    I must concur with the many others who've said that the small 12v battery in the Prius is a weakness in the design.
  2. darelldd
    6,059
    389
    Northern CA
    Bummer! But aggh! ANOTHER battery thread to go with the other three?!
    Just for that, I'm going to post my Optima page here too!
    Prius Optima Aux
    That'll teach you.
    I did the Optima swap as a preemtive measure. To hopefully AVOID what others have gone through. We'll see if it works. I'm pretty surprised at the parasitic draw of the Prius. When you first shut it off, it is drawing almost 2 A still. That drops slowly, and after many mintues, I got tired of watching - my Ammeter showed still over 200 mA which is way too much at rest.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Paul,
    Did you leave SKS on? That is the common cause for depleted battery and why they put an SKS switch below the Stearing wheel.
  4. Tideland Prius
    16,469
    wow... yeah mine happened at 3 months lol. Battery's still going after 3 years.
  5. Flying White Dutchman
    4,376
    313
    a lott off people have this problem
    and yes i think its a design flaw.
    i disabled the sks and stil got a drained battery
    its just to small....
  6. darelldd
    6,059
    389
    Northern CA
    I'm having trouble figuring this one out. I don't measure any significant increase in current draw from the battery with SKS on or off. I'm going to keep trying though, because this car does some odd things when parked and seemingly doing "nothing."
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Well, when you first shut off the car car there is the draw of the coolant transfer pump. Then, after a few hours, something else runs (manual is in the garage, too lazy to check what it is). After some time, the SKS will shut off on its' own. I think I read after two days of non-use, but someone else can check - it's in the owners manual.
    While many speculate on what is causing this, I still maintain the charger built into the inverter doesn't have temp. compensation. Pearl runs the 12V system at 13.8 V both summer and winter. While 13.8 V is about right for summer, it isn't going to fully charge a lead acid battery when it's cold (around freezing temps and below). You need at least 14.3 V.
    I haven't been caught yet, with a full week at -25C and below (went down to -35C on monday). Pearl sat for a few days at a time without being used. I do have my "Prius booster cable" in the "hidden drawer" in the console. You don't have to open the hatch. Boosting from the "boost point" on the fuse block works just fine, in fact, it's much safer than from the battery (NO chance of sparks igniting H2 gas).
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Sorry to hear about the flat battery. Please boost the car using the underhood jump start point, far safer than monkeying around in the hatch.
    I would make sure the 12 vdc is in fact fully charged. In cold weather, just driving around won't fully charge the auxilary battery, and you could damage it by keeping it chronically undercharged
    I did post somewhere the genuine Toyota Prius PDI with very detailed instructions on how to properly charge the 12 vdc battery. Toyota is pretty strict about removing the battery first, which I thought was sissyness on their part
    Another poster has commented he had a battery charger in the hatch area, and it got so hot it actually scorched the fabric. Lucky the entire car wasn't engulfed in flames.
    Toyota recommends their own branded automatic battery charger set at 10 amp position. Their charger is a high quality automatic charger made by Associated. Any high quality automatic battery charger should work
  9. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Did you leave the parking lights on all night as you wrote you planned on doing?
  10. Flying White Dutchman
    4,376
    313
  11. paulccullen
    276
    Seattle, WA
    Nope, I always leave the SKS on, I've previously parked for two weeks without incident.
    BTW: The battery isn't getting charged just by driving around (as others have already said). I guess I'll have to get a charger.
    Question to all: What's the best way to determine the health of the 12v battery? I wonder if mine is kaput and needs to be replacing.
  12. icarus
    icarus Senior Member
    4,884
    976
    earth
    Fully charge the battery, and then have it load tested!
    Icarus
  13. David Beale
    5,963
    1,987
    Edmonton Alberta
    Because it isn't a starter battery a load test shouldn't be done on it, unless the tech -KNOWS- what he/shes doing, and most don't when it comes to batteries. A load test on this battery should be at a much lower current draw. I've found if you leave the car off for 24 hrs or longer, and then measure the battery voltage, if you see 12V +or- about 0.5V then you're probably ok. You could then turn on the headlamps and see if it drops 2V. If so it needs to be replaced, as one cell is dead.
    I recommend a "Battery Tender" if you plan on using a charger. www.Batterytender.com
    It won't damage the battery, can be used with the battery in the vehicle, and comes with the cable you can install in the vehicle and just plug in (on the fuse block). I got the higher current version, though I haven't used it yet as my battery seems to be fine (knocking on wood). ;) If you use the cable on the fuse block you open the hood to connect it, so it makes it harder to drive away with it connected. :)
  14. icarus
    4,884
    976
    earth
    As David Beale suggests, load testing properly. Any load test on any battery has to be done relative to the amp/hour capacity of the battery. I would question whether or not a ~2vdc drop with the headlights on indicates a dead cell. A 12 volt battery subjected to the load(s) of the lights (75-100 watts maybe?) would normally drop that much. The bigger question is does if recover when you turn the lights off, how fast and how much.
    The ONLY way to accurately tell the voltage of a battery is after it has stood for at least an hour (preferably 12) with out being charged or discharged. That will give you an accurate voltage, but give little insight as to condition/capacity. The true an proper way to tell that is test the specific gravity of the acid with a temp compensated hydrometer. The problem is that you can't do that with a "sealed/maintence free" battery. The next best is a proper load test
    If your service location doesn't know how to do it, perhaps you should fine one who can.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Any high quality automatic battery charger should work. A forum member almost had a fire in his Prius by leaving the battery charger inside the car. The battery charger got hot enough to scorch the fabric
    If you feel comfortable doing so, it's probably best to just remove the battery and charge it up outside the car. You will lose your presets and have to "normalize" the auto window function, but you probably have to do that anyway due to the dead battery
    The Prius PDI suggests this procedure to test the 12 vdc battery: turn headlights on for 60 secs, then turn off. Wait 60 secs. Measure voltage at battery. If 12.8 or higher, battery is ok. If not, fully charge and retest
    Hope this works out. I'll be leaving for 2 weeks this Thursday, keep me informed
