Acceleration
Discussion in 'Local Prius Club Main Forum' started by BoilerUp, Feb 3, 2008.
  1. BoilerUp
    BoilerUp New Member
    Hello all,
    I'm very interested in the Prius, and expect to buy a new car sometime in the summer and I've started researching. One of the questions I have regarding the Prius is the acceleration. Now, I don't expect and know the car doesn't achieve sport's car acceleration. I just need the car to merge onto the highway without getting hit.
    We all know that the Dan Ryan can be unforgiving. What are you're experiences with this?
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    From my experience on the Tri-State, I can assure you that the Prius not only accelerates 0 - 60 adequately, it will surprise you how quickly it will jump from 60 - 70 or 80.
    Not that I know.
  3. nitschke65
    nitschke65 Not entirely normal
    28
    Up here in Milwaukee there's no problem with acceleration. Of course, every time I hear a local traffic reporter talk about our "rush hour" I chuckle to myself. I don't think you'll really have your answer until you take a Pri for a test drive or, even better, rent one. I visit Chicago often, and know from experience that, sometimes in traffic, you've got to "drive it like a rental!"
  4. madler
    madler Member
    289
    Pasadena, California
    No problem whatsoever. The whole point of the hybrid system is to give you the performance you expect from this class American automobile by combining a small internal combustion engine for good gas mileage and an electric motor (actually two) to provide the occasional power boost when you need it.
    You could get approximately the same gas mileage with just a small (smaller) internal combustion engine and no hybrid system, but then you'd have the lousy acceleration you're worried about.
    Others will complain about the oversimplified explanation above, so I'll add that the electric motors and battery energy storage also allow for using the internal combustion engine in more efficient ranges of power and RPM, as well as allow for the regeneration of energy when slowing down. Gas mileage is further improved by a low drag body and small, low rolling resistance wheels, but those are independent of the hybrid system.
  5. fred
    fred New Member
    235
    nashville
    technically, 0 to 60 is about 10secs. however, in traffic and merging, it fools you because there is 0 lag. poof its gone. no down shift no hesitation. so , its really pleasantly peppy. not like my vrod harley that does it in under 4 seconds but very good anyway.
  6. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Depends on how much metal you want to put on the pedal. Don't challenge me at a light if I've had a really bad day at work because I'll win (and then curse myself for screwing up my mpg):D.
  7. TonyPSchaefer
    14,816
    2,499
    66
    Been there, done that!
  8. BoilerUp
    BoilerUp New Member
    Thanks for all of the input. I like this car more and more. Can't wait to test drive one.
  9. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I had a similar concern before I bought my car, so I pre-planned my test drive route to include several steep hills and an uphill highway merge. I was very satisfied then and have had no regrets since -- even on the dreaded parkways in the NYC area where you have to merge into 70 mph traffic with virtually no on-ramp.
  10. SyCo
    SyCo Member
    207
    17
    Quebec
    Oh yes... no lag and I love it.
    One thing I've noticed, if you want good response you need to push far enough on the pedal. A bit more then I was used to in my other cars.
    But if you do ....Zooooooooom :D
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Syco's post shows the first 2 seconds.
    This one shows 6 seconds.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ack... double post..
    I'll take the opportunity to point out from the graph that Prius took 5 seconds to accelerate 30mph to 50mph (50km/h-80km/h) the same as 2.4l Camry while the 01 Prius too 6 seconds.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    If I'm on the front line at the traffic lights it is very rare that I'm not the leading car after they change.
    I don't rush to a red light though, as soon as I know I have to slow or stop I lift off, and I look a long way ahead.
