Downhill driving question
Discussion in 'Gen 2 Prius Main Forum' started by cyberprius, Feb 14, 2008.
  1. cyberprius
    cyberprius Mtn Bikes don't need foglights
    185
    oregon
    I've read Hobbit's article (a tad too technical for me:confused:), but I'm sure it makes sense to others. And, I've read some posts/threads about the "B" gear and hill driving.
    But, sorry, I am a wee bit uncertain.
    I drive about a half-mile down a hairpin curved dirt road every day to reach the county blacktop. It goes from about 890 feet at the top to about 370 at the bottom, so just over 500 feet or so in the half-mile.
    I just "use the brakes" all the way down. My old car was a manual transmission Corolla, so I was usually in 2nd gear in that car.
    Anyway, my husband says I need to use the "B" gear while descending the hill in the Prius. From what I've read it seems to be a wash, or maybe even preferred to use the brakes.
    Since I do this a couple or more times a day usually, I would kinda like to know what might be right?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Do you have all 8 bars lit green on the energy display when you just use the brakes? If not then you probably don't need to use the B-mode, unless......
    Is the road bumpy? If it is it could be kicking you out of regenerative braking and you may be on friction brakes only for much of the trip down.
    I'm not a big fan of B-mode, but you may have a unique situation where it could benefit you...very steep hill, lack of normal regen if the bumps are kicking it out of that, and a pushy husband;).
    If the road is smooth and you are pretty sure you're getting a good amount of regeneration using the regular brake pedal and you're not maxing out to 8 green bars at the bottom then you can/should continue doing that.
  3. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    You are more familiar than we are about the road you are referring to and the circumstances of your drive.
    If you can safely drive those hills without overheating your brakes, then feel free to do so. Just keep in mind that brake fires are nasty, and you usually won't know it's happening until things are getting out of control.
    The B mode uses the engine to brake the vehicle on down hill runs so you can ease off the brakes and allow them to cool down.
  4. icarus
    icarus Senior Member
    4,884
    976
    earth
    I think that in this unique case, you would be better off using the "B" setting for two reasons.
    First, chances are you are going to be on the brakes some of the time and therefore will get some regen. But more importantly, you will save a ton of wear on the friction brakes over time, at the expense of a little regen gain.
    Second, you will decrease the wear and tear on your gravel road using "B"
    If you can descend the road at a stead speed, without having the brakes grab at the gravel, you will disturb less of it. Also It will save your tires a bit in my opinion.
    In normal driving, I have found that once the bars are fully green the HV battery is 75%. Further charging is available up to 80%. After that point, you are better off saving your brakes and using "B".
    Icarus
  5. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Don't have my Prius yet, but from what I've read, you should use B below 7 mph to minimize wear on the brake pads (no regen below 7 mph, so it is all friction braking).
    Above that speed, you can use B, but your regen would be greater with the brakes. However, if you have 7 or 8 bars SoC at the bottom of the descent using B mode throughout, then there is no reason to use the brakes except as required with B to keep speed safe. Once the batteries are charged (8 bars = 80% max allowed), there is no further benefit to regenerative braking, the car will use friction brakes, and you should use B just as a normal tranny would use L or 1 (to stay off the brake pads).
    By the way, my STATE doesn't have 500 ft elevation change:p (not quite accurate, but it sounds good)
    Corrections, anyone?
  6. cyberprius
    185
    oregon
    It's a very bumpy road, but no one has any issues using brakes all the way down. I do know some roads around here though that will burnout brakes, but this isn't one of them.
    So, based on the bumps, maybe B would be best. But then does that put more strain on the engine?
    I remember being told long ago when I was learning how to drive a 5-sp manual transmission that downshifting to stop at lights, etc. was bad, because it strained the tranmission, and what's cheaper a new transmission or new brakes...so just wondering if any of that comes into play
  7. icarus
    4,884
    976
    earth
    BS!
    In the real world, the engine and transmission don't really care.
    In a clutch car, down shifting to slow down, the wear is on the clutch. You can over come that wear somewhat by double clutching, keeping the rpm up for the lower gear as you let out on the clutch, and THEN get off the gas and let the engine slow you down.
    Use the "B" and it will be fine, IMHO.
    Icarus
  8. efusco
    19,891
    1,196
    Nixa, MO
    Yes, I have corrections. You get no regen braking or any ICE slowing in B-mode below 8mph. You're stopping with friction brakes at that speed regardless. But the amount of wear put on the friction brakes at that speed is very minimal.
  9. icarus
    4,884
    976
    earth
    Not to pick nit with you Evan, as you are really the expert, but,,
    I agree that stopping from 8 mpg to 0 is little wear and tear, but a long down grade @ 5 mph, day after day WILL have significant wear on the pads and rotors. (Not that many of us do that routinely).
    Icarus
  10. efusco
    19,891
    1,196
    Nixa, MO
    Sure, there will be significant wear doing that frequently will wear the brakes. But my point still remains that if you're below 8mph there will be no braking/slowing due to regeneration. There may be some slowing form engine braking... at that speed I suppose... Have to think about that a little.
  11. qbee42
    3,082
    Not to put too sharp a point on this, but Evan is correct. Whether to use B mode or not all comes down to whether the HV battery is reaching maximum charge. Just look at the battery display when you go down the hill (not in B mode) and see if you get green bars all the way up. If you do, then you should use B mode for at least part of the descent. If you don't, then B mode serves no purpose other than to waste energy.
    As for bumpy roads, B mode and regen braking both work only through the front tires. In either case, friction braking will be invoked if the front tires loose traction.
    Evan is also correct that friction braking takes over at around 8 mph. This is true whether you are using B mode or not.
  12. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    This all depends on how fast you're able to go down this hill.
    Remember, if you start with the engine off you can stay in "B"
    at less than 20 MPH without the engine coming on, and that
    automagically gives you a little more regen between about 11
    or 12 MPH and up to 19 MPH. That lets you be a little less
    likely to have a bump kick the regen out, too. So there's your
    first level of "holdback" if that's the right speed range.
    Otherwise you're on the brake pedal, carefully and lightly to
    try and collect as much regen as possible. If you start with
    a low SOC at the top, you should be just getting into green
    after 500 feet of drop. The full allowable range of the pack
    is good for about 600 [read the calculations here]. So if you
    manage to get the engine shut down before the descent [look into
    an EV button if you haven't] you'll be able to get down and
    then a respectable distance away from the hill without
    burning a drop of gas.
    Let us know how the practice sessions go; sounds like you've
    got a nice little test environment there as part of your daily.
    _H*
  13. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    From what I've read, these cars don't toast their brakes very quickly, and a brake job isn't a huge expense. Likewise, I'm assuming that Toyota knew what they were trying to accomplish when they put in the "B" feature. If it were me, I'd use both, sometimes one, other times the other. I doubt that you're going to do any major injury to your Prius either way. If you need new brakes at 80-100K miles, big whoop.
  14. sugar land dave
    137
    houston
    "B" is a feature of the Prius designed for safety and to lessen the strain of a relatively steep downhill drop. Why not use it as intended? Further, from a human standpoint, if their were no difference between the two, or even if there was a slight difference in favor of "D" gear, wouldn't the thought of making your husband happy be worth something?
  15. qbee42
    3,082
    Why use it if it does no good and hurts mileage? The Prius gives you the instrumentation to determine whether it's needed or not. If it were a one-time trip down an unknown steep hill, then by all means kick it into B mode, but on a route you drive all the time, use your head and figure out whether it makes sense. As hobbit points out, if your SOC is low, put all of that energy back into the battery. If you hit the top of the hill with a medium to high SOC, then stick it in B. It's not that hard to understand.
  16. patsparks
    10,664
    569
    Adelaide South Australia
    When you have a full green battery on the MFD that is the green light to use B.
    Using brakes lightly on a slope if there is room in the battery for more electron doesn't use friction brakes only regen so brake away. ABS works on the brakes too so it is safer from a cotrol point of view.
    Try stopping at the bottom of the hill and feel the front wheel near the centre, if it isn't hot you haven't used much brake, mostly regen.
    I use B at the bottom of an 80km/h (50mph) 2 kilometre 11% grade but only if my battery is all full green.
  17. efusco
    19,891
    1,196
    Nixa, MO
    I pretty much agree with this but would add 2 points.
    1) I tend to engage B-mode a bit sooner than 'the bottom of the hill' if it's familiar territory and I know the battery will top out. But that's a very minor quibble.
    2) The OP described a dirt road. Rough roads can easily make the car act as if there's an emergency braking situation imminent and can kick out regenerative braking (most of it anyway) with even fairly minor bumps. In those situations I would be inclined to use B-mode the entire time down a hill to try to maximize regen. If you can feel when regen stops you could wait until then to engage B-mode, but on a bumpy road I don't think it's really possible to be sure unless you have CAN-View to monitor regeneration amperage.
  18. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Brake or B?
    Hi cyberprius, welcome to PriusChat! I have a similar situation, but my road is paved and I live at the bottom. I usually just use the brakes and regen, and my battery is usually green and frequently full at the bottom, but that won't hurt anything. Since you're driving further, that full charge will help you save gas.
    One thing you may notice, and it startled me the first time, is that your ICE may cycle on and off when you come to a stop at the bottom with a full green battery. That's the car wasting electrical charge to protect the battery from being overcharged. I couldn't figure out why the ICE was running with the battery charged. In fact, it was the motors spinning the ICE to lose charge.
    If you're in the Portland area, check out the local HSD club in my signature.
  19. captnpops
    captnpops Junior Member
    17
    Salt Lake City
    I agree with Bill Merchant:
    I live on the side of a mountain... it's about 1.5 miles down to the major street... I have been using the brakes down the mountain for almost 3 years, no wear as everyone has mentioned, above 7 mph...
    Control on various turns needs normal foot brake control, not the b option, use that for the 10 mile interstate coming down the mountain..
