When can I wax my new Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mikem13, Feb 16, 2008.
  1. mikem13
    mikem13 New Member
    Tucson
    I searched and couldn't find the answer to this.
    We bought our new Magnetic Gray Prius almost 3 weeks ago and I am wondering about waxing.
    I have had heard in the past that you shouldn't wax a new car for several months so that the paint has time to cure. I have also heard that this is not the case. What is the real deal?
    When should I think about waxing?
    Also, would using a clay bar also take off any dealer wax and would then require a new wax?
    Thanks for any help
  2. darelldd
    6,059
    389
    Northern CA
    You can safely wax the car the day you bring it home.
    Using a clay bar will definitely require a re-wax after use. the clay bar is a mild abrasive that will remove any coating that is on the car. If you think that the dealer waxed it before delivery, I have bad news for you though: I've not heard of that ever happening!
  3. mikem13
    mikem13 New Member
    Tucson
    Thanks for you help!
    Should I clay bar it before waxing it for the first time or should the clay bar be something I do the second time I get ready to wax?
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    wax your new Prius anytime
    You want to do the clay bar before anything else. It will remove all surface grit and give you a perfect surface to apply wax or sealant. I suggest you do a Google search for
    Code:
    polish site:priuschat.com
    and read what people here have to say. Lots of discussion on wax v. sealant v. polish. Many here like Zaino, another good search term.
    Welcome to PriusChat!
  5. Doc Willie
    1,717
    144
    Out there, somewhere
    After reading dozens of pages of stuff on detailing (there is a sticky to one at the top of this forum, or go to the Autopia, Mequiar's or Mother's sites), my take is that you do not need to do claybar on a new paint job. The test is to run your hand over the paint surface. If it is smooth as glass you do not need to claybar. You wash and go straight to a 1-step cleaning wax like Klass All In One or Mother's Cleaning Wax.
    If you feel some roughness in the paint, then claybar, polish, and wax. Persons with OCD welcome.
  6. richard schumacher
    7,666
    1,047
    United States
    You don't need to claybar a new Prius. Look at the surface at a low reflection angle: it's like polished glass. You might as well use steel wool on it.
  7. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Dealers like to use that "Quck Detailer" spray and tell the customer that the car was recently waxed. My suggestion is to put a nice protective coat of wax as soon as can.
  8. Bill Merchant
    4,096
    87
    Clay bar
    May I remind the naysayers that properly going over your Prius' paint surface with a clay bar will in no way damage it, Richard's assertion not withstanding. To get to Tucson AZ, the OP's location, from the port of entry in LA or Portland, required transportation, probably by rail. That long ride gives ample opportunity for rail dust, grit, and airborne contaminants to embed themselves in the paint surface.
    Do you need to clay bar? Probably not.
    Will you get a better finish if you do clay bar? Probably yes.
    And, of course, you want to put on a coating after you clay bar.
  9. mikem13
    mikem13 New Member
    Tucson
    Well I spent several hours today washing, using a claybar and then waxing "The Gray Lady" and it looks great. I ran my hand over the car before and after the claybar and it felt smoother, so i guess it did its thing.
    Thanks for the replies.
  10. Bill Merchant
    4,096
    87
    new Prius waxed
    Congratulations, mikem13! Clay baring your car is tedious.
    So where are the pictures???
  11. mikem13
    mikem13 New Member
    Tucson
    Re: new Prius waxed
    No photos yet.... It took so long that I had to rush to work. I'll snap some tomorrow. :D
  12. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    Sorry, but you clearly don't know what you're talking about. The embedded contaminants that claying removes are too small to be seen. A surface that appears to be flawless may or may not need claying. You have to do the baggie test to determine whether claying is needed. New cars often need claying.
  13. priusenvy
    1,765
    Silicon Valley, CA
    Wrong.
    I've clayed dozens of cars that had sealant on them and their finishes still sheeted water after claying, proving that the sealant remained after claying.
    Wax is not nearly as durable as sealant, and if you use a strong detergent in your clay lubricant, you will strip wax off of a finish, but sealant easily stands up to the fine clays that most people use. Maybe something like Clay Magic red clay could remove a lot of it, but I bet that a sufficiently fresh coat of most sealants would stand up to claying with even an aggressive clay like Clay Magic red.
  14. mikem13
    mikem13 New Member
    Tucson
    Here is a quick picture I took this morning.
  15. Doc Willie
    1,717
    144
    What is the baggie test?
  16. mikem13
    mikem13 New Member
    Tucson
    In the detailing sticky here on PC there is a link to another site, which intern has a link to a video about clay barring. It has a section in it talking about the baggie test.
  17. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Mike the finish looks great. Personally, I never wash or wax my cars because the dirt and grime form a protective layer against UV rays.
